10-26-2011, 11:09 PM | #1 |
Tranny / tcase problem
Hi all,
my friend has a '71 GMC K1500, 400 sbc, sm465 trans and 205 t-case. Yesterday, the housing between the tranny and t-case split wide open. The trans is still in place but the transfer case is barely hanging on (just by the side mount that bolts to the frame). Has anyone ever seen this before? Does anyone make a replacement housing? It is too dark for good pictures but it's a mess! Thanks for any input, Colby. |
10-27-2011, 01:18 AM | #2 | |
Windy Corner of a Dirty Street
Re: Tranny / tcase problem
I have a 465/205 adapter that you can have for free. Just pay the ride. This adapter is also from a ’71 or ’72 and must have had a small crack as it has been welded. I used it for 10 years without issues and became a shop ornament once I swapped in the NV4500. PM if you want it. I shipped a TH350/205 adapter a while back and the shipping was around $40. PM if you are interested and I’ll get you some pictures of the weld job. '78....no holes drilled in the tcase
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
10-27-2011, 04:18 AM | #3 |
I'm confused! what is it that causes the torque bracket to put more stress on the tailhousing. The only thing I can think of is if you had a broken motor mount or something. Please help me understand this. Frame flex?
1968 K10/30 Frame Off Project "Overkill" My 5 year, $30,000.00 toy |
10-27-2011, 11:35 AM | #4 |
Torsional stress. The engine naturally wants to lift up and twist when under load (even with good engine mounts) then you have the tcase tied to the frame on the passenger’s side. Something in between is going to eventually break. GM later tied the aluminum transfercases (and some 205s) to the bellhousing by way of a long strut rod instead of tying it to the frame, which is fine. Bolting the transfercase to the frame was a bad idea.
10-27-2011, 06:19 PM | #5 |
Thanks for the info dirty larry, never heard that before....just another day of learning hanging around
10-27-2011, 08:17 PM | #6 | |
10-27-2011, 11:07 PM | #7 |
Currently Blazerless
I'm guilty of this myself...I had no trouble or leaks till I replaced my soft worn rubber transmission and transfer case mounts with poly, allowing virtually no movement at all. It didnt take long to develop a nasty leak from a crack in the adapter.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
10-28-2011, 05:49 AM | #8 |
Thanks Larry! It makes sense to me now and Blazerman just confirmed it!
11-10-2011, 02:05 PM | #9 |
Thanks for the info guys, looks like I will be removing the bracket I fabbed because I thought it was missing. My drive train came out of a 74, xfer had the holes drilled and tapped. I drove it for 15 years without one with no problems (did have the engine chained to the frame on drivers side to limit torque) but thought I would make it "correct" this time.
11-10-2011, 05:17 PM | #10 |
That bracket/mount also has rubber bushings? My truck did not have one but I added one during my"rebuild". Sounds like maybe I should take it off....
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job" |
11-11-2011, 07:03 PM | #11 |
This is some good info!
I just placed a NP205 in my 68 burb and was about to drill new holes in the frame for the mount. The truck original came with a NP203 and the mount is in a different location along the frame = 4 less holes to drill and less parts to deal with.
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread Last edited by Mt Man Chad; 11-11-2011 at 07:08 PM. |
11-11-2011, 07:55 PM | #12 |
Hey Larry;
Did you fab up a rod or something that ties the transfer case to the bellhousing for extra support or is it OK not to have anything other than the mounts on the crossmember? Opinions? Thanks
11-11-2011, 08:38 PM | #13 | |
11-12-2011, 12:41 PM | #14 |
I agree because my blazer only has the brace from the motor mount pad (block side) to the bellhousing nothing for the transfer case
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
11-14-2011, 02:51 PM | #15 |
What an interesting thread - when I swapped in an NP205 into my 70 Blazer in place of the broken Dana 20, the side bracket didn't fit and I've been meaning to get around to modifying it or making a new one - now I can forget about doing that. Procrastination paid off!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
11-14-2011, 04:32 PM | #16 |
Yukon, that is funny....procrastination pays off, maybe not, ill want till tomorrow to find out
12-22-2011, 11:37 PM | #17 |
I've got a 700R4 in my '72 K2500. It only has 4 bolts holding the adapter on the transmission. Will that be sufficient to hold it without the side bracket or do I need a brace rod from the bell housing?
12-23-2011, 08:18 AM | #18 |
Grease Monkey
If you do not have the bracket that connects the side of the t-case to the frame you will shatter your trans housing! This is a must!
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
12-23-2011, 11:49 AM | #19 |
I guess I won't remove it then.
12-23-2011, 11:55 AM | #20 | |
No way. The side bracket creates more problems that it saves, which is why GM quit using on trucks build after ‘72. That is information straight from a retired GM truck engineer. The support rod between the tcase and trans bellhousing is not a bad idea to add but still not required.
12-23-2011, 03:20 PM | #21 |
What year vehicle should I look for in the junk yard? I'll get the brace rod just to be safe.
12-23-2011, 03:49 PM | #22 |
What tcase do you have behind the 700R4? 205’s didn’t come behind 700R4’s so you have to modify one to fit. Some 70’s and 80’s trucks had them. Just walk the junk yard until you find one. You’re probably going to need to modify whatever you find anyway. You really don’t need the rod unless it makes you feel better to have one anyway. I never ran a support rod or tcase side bracket on any of my old 4x4’s and never had an issue without them.
12-23-2011, 07:15 PM | #23 |
Grease Monkey
DirtyLarry you can call BS, but this is the voice of experience. I shatter my trans casing and that was with the frame attachment. I was just giving my two cents.
12-23-2011, 08:39 PM | #24 | |
So should I leave the side bracket on or take it off? I am confused. |
12-23-2011, 09:21 PM | #25 |
The frame bracket does not allow the transfer case to flex and thus either breaking the case or the adapter most usually if it were mine i would get rid of it
Clint Youse Paris, MO 1984 Chevrolet 3+3 K30 with Cummins 1966 IH Scout has been a work in progress for 16 yrs |
