01-04-2012, 05:24 PM | #126 |
Chevy Enthusiast
Re: Project: B.A.D. 1976 K30 CCLB
Yeah I was going to say ive never heard of that swap before. Im really interested now to see what kind of numbers it will put out. Isn't the record like 700hp on a VE 12V fuel only?
What are you doing for injectors?
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
01-04-2012, 05:37 PM | #127 |
6>8 Plugless........
Yeah, I think it's around there with a 14mm VE. Since this is the wife's truck, it won't be a huge power house. I'd like it to be around 300-350HP to the rear wheels. It has 7x.012 injectors in it that are built in house, and the pump is turned up. I have another pump at the pump shop that has a 3200 govonor spring in it and has been rebuilt. Just have to wait for them to finish it up. My plan for now is to run a HX35W with a 14cm exhaust housing. That will help out top end and won't get as hot either. Should make for a great towing combo too.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
01-04-2012, 05:56 PM | #128 |
Chevy Enthusiast
Well even at 300-350hp its really cool man!
I just did a quick search here's a guy that was thinking about doing this swap... http://www.cumminsforum.com/forum/89...-24v-work.html and maybe another > http://www.dieseltruckresource.com/d...-t288083.html?
01-04-2012, 06:02 PM | #129 |
Some think and talk, some do.
01-04-2012, 06:20 PM | #130 |
Chevy Enthusiast
haha
Wait
01-04-2012, 06:31 PM | #131 |
I wasn't referring to you.
01-05-2012, 04:29 PM | #132 |
I got the harmonic balancer, engine adapter plate, and fuel pump block off plate installed this morning. Then I had to clean up the bay enough to get this thing inside the shop.
Started removing front clip to get ready to set engine in it's new home. We pushed the truck in the shop and rolled the front of the frame right under the engine. Now the fun part comes. I'm going to have to notch my front cross member and brace it according. Then I can start building an engine cross member and get the mounting ears made up. Right now it's just sitting on the cross member and a big jack stand.
01-05-2012, 05:16 PM | #133 |
Wow, now thats tight on clearances. Looks keep up the good work. At the rate you are going you will be driven her by the end of the week.
01-05-2012, 08:34 PM | #134 |
almost looks like mine
Truck: 1972 International Harvester 1210 Engine: Caterpiller 3116 220 HP 630 tq Transmission: Eaton Fuller rt 6610 Axles: Merritor I beam front axle |
01-05-2012, 10:44 PM | #135 | |
Nice to see no one followed through lol And I know Schied said they were the first VE 24V Conversion lines thy had ever bent, and they bend a ton of lines.
1996 Dodge 2500 Ext Cab Long Bed P24V Cummins Turbo Diesel 5 speed 4x4
"STOCK" ASSEMBLY THREAD |
01-06-2012, 03:03 AM | #136 |
WOW Ryan, another wicked build,,,just read about your other build a couple of days ago. Your engine looks great!! How does it feel to be a Pioneer??? Can't wait to see how she turns out!!
Wade , JUST WALK AWAY, AND I'LL SPARE YOUR LIVES!!! , Build thread "TANGERINE" http://67-72chevytrucks.com/vboard/s...d.php?t=498570 Board Members Met: bigblock68, ol_skool_chevy ,68TT,atvpro |
01-06-2012, 03:20 AM | #137 |
Thanks Wade. It'll feel great to be able to pull it out of the shop without a chain or guys pushing it.
01-06-2012, 07:09 PM | #138 |
The last few nights on my break at work I started polishing my intake plate and valve cover. What do you think?
I started to trim my cross member in the front and eventually wacked it out. I was going to try to install this engine with a mechanical fan. However, I forgot that I have a return line that comes out of the back of the head. If I ever want to get it off or repair it if needed, I had to bring the engine forward to be able to do so. Oh well, I like electric fans any how. I put a bare trans housing in there to see how it's going to fit. I'm going to have to either cut and modify a floor pan brace, or lower the rear of the engine to be able to install the over drive housing and transfer case on the transmission. We'll see what I come up with. I also have to watch the front differential because this engine has a huge oil sump on it. I may have to add a 4th leaf to these springs if they don't like the weight and I'm not happy with the clearance I'll have after the weight of the power train is on the chassis. Tomorrow I'm going to start building the engine cross member. It's going to be a PITA because this oil pan is deeper through out the entire length compared to 2nd gen dodge pans. I'm also going to redo the front cross member and build a steering box brace and integrate it into the front cross member some how.
01-06-2012, 09:49 PM | #139 |
MMMMMM,,,polished parts!!! Looks real good! Nice tight fit on that engine.
01-06-2012, 11:25 PM | #140 |
Looks like you were busy today. The polished valve cover will be cool! Looking good man.
1980 K10 - 6.2L Diesel/SM465/NP205 Build Thread 1984 K30 CC Dually - "The Tank" 12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's Build Thread 1960 C-60 Dump Truck Make it road worthy! Thread |
01-07-2012, 12:16 AM | #141 |
Yes it is a tight fit. I need a magic wand.
01-07-2012, 12:16 AM | #142 |
Junk Yartist
I just realized I was drooling...
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
01-07-2012, 12:17 AM | #143 |
Yes I was and will be all weekend trying to make this less of a yard ornament.
01-07-2012, 12:19 AM | #144 |
tell me what the secret to squeezing it in is
Truck: 1972 International Harvester 1210 Engine: Caterpiller 3116 220 HP 630 tq Transmission: Eaton Fuller rt 6610 Axles: Merritor I beam front axle Last edited by tecky11; 01-07-2012 at 12:25 AM. |
01-07-2012, 01:02 AM | #145 |
Looking good, moving along nicely. VE 24v? Some would say you need to have your head inspected, others will say how unique, way to think outside the box. I would love to sell my Dmax and build a daily driver like such with a P-pumped 24v with a 6spd handshaker, but I dont have the time and these newer diesels move pretty well stock and with a plug in can move even better for a 7500lb vehicle.
Name: Les ---------------------- Couple 80s Couple 70s One 68 |
01-07-2012, 09:54 AM | #146 |
The motor Looks good. You must have moved the motor forward quite a bit I just trimmed like a 1/2 unch off my front crossmember to get tthe motor to set down. Looks good. Now you are down to the stuff that seems like you never accomplish anything because it is all smalll and no real visual progress or at least that is the way mine seemed. Course I just had a P[-pumped 12 valve
Clint Youse Paris, MO 1984 Chevrolet 3+3 K30 with Cummins 1966 IH Scout has been a work in progress for 16 yrs |
01-07-2012, 01:28 PM | #147 |
Currently Blazerless
Your really moving along on this one! Great work and love the polishing..you gonna share the process? what do you do after its polished..just spray can clear coat?
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
01-09-2012, 02:23 AM | #148 | |
01-09-2012, 02:44 AM | #149 | ||
Patience and a plasma cutter and welder.
If I start with a rough casting piece, I use a corps disc scotch brite pad, red medium grit on a die grinder. I smooth up the surface best I can. Then I sand it starting with 180 grit. Then 220, 320, 400, 600, 800, 1000, and then 1200. I then use a polishing wheel with aluminum polish and buff it up. On these parts I only had 220, 400, and then ultra fine gray scotch brite pad. I will go back over these parts with finer sand paper and re polish it later. The valve cover is going to be a real PITA!
01-09-2012, 02:51 AM | #150 |
I wasn't happy with how the engine sat in the chassis so we re positioned it and then I started building the engine mounting brackets.
Tomorrow I'll wrap up the LH engine mount. The energy suspension bushings don't fit worth a crap. They're extremely tight and in their instructions they tell you to trim to fit according to your mount. So I have to trim the ears some more so the bushings will stay in all the way so I can tack the upper portions of my mounting brackets other wise it will be a fight every time I want to install or remove it. Then I'll get on to the cross members.
