Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 01-08-2012, 08:19 PM   #1
blkcorvair
blkcorvair's Avatar
AUX input jack for 67-72 AM radio
Here is my simple install of a Stereo type 1/8” input lack into my stock 67-72 AM Radio. This allows for the use of any low signal output to be played right through the radio without sacrificing the AM portion of the radio. Such devices like an MP3, Ipod, or portable CD player, or in my case my adroid phone with Pandora app. You won’t need any separate switch. The stereo jack used will give priority to any device plugged into it. And when the device is remove from the jack your AM radio will function as it normally would.
This is a pretty basic install and with a few basic tools and a careful approach nearly anyone should be able to do this for about $20 including the 3’ patch cable.
You’ll need to visit your local radio shack and obtain a pack of small resistors 1k or 2k ohms and an 1/8” Stereo Phone jack (Closed circuit) If you don’t have one already grab a 3’ or so patch cable. (This is a standard headphone type end)
Below is a diagram I found very useful that I found out on an antique radio forum. Basically you’ll need to remove the top cover of the radio and locate the blue wire from the volume potentiometer to the circuit board. You’ll be installing the input inline between the board and the pot in this circuit.
First I assembled and soldered my input jack. If you are installing the jack in a ground metal opening then there is no need for a ground wire and the #1 terminal need not be used. The two resistors get soldered together at the #5 and #2 Terminal and then one lead gets attached. The #3 and #4 terminal get “jumped” and than a second lead will be attached. For the leads I used some old thin speaker wire off an other radio I had.
I than removed the chrome face of the radio and located and drilled a 15/64 hole all the way to one side. (I wanted to be sure the AM dial needle would not hit my stereo jack inside the radio once completed) Be sure to carefully de-burr the inside and outside edges of the new hole.
The terminal lugs on the back of the stereo jack are very close to the edge and once installed could ground out on the inside edge of the faceplate. So I slightly bent the terminals inward with a needle nose pliers and put a few small scraps of heat shrink tubing in different spots. Im sure electrical tape would work fine too. I than carefully installed and tightened the stereo jack into the faceplate.
Once I fished the leads into the case and re-installed the faceplate I was ready to connect the leads.
I “de-soldered” the blue lead at the circuit board. The lead without the resistors was than soldered in its place. The lead with the resistors is than soldered to the blue lead going to the potentiometer.
And that’s it! I used a small wire tie to keep all the leads away from the dial and put the top cover back on. Check out the picture below of my Android playing music through my radio.
Just so everyone is aware. Im in no way any kind of electronics wiz. I used all this info that I found on the net and combined it to set up a 67-72 Delco AM radio as shown above. I plan to install this in my truck and don’t forsee it will damage anything but do this conversion at your own risk.
Below are a few links to other people who have posted thier "succesful" conversions and from where all my info has come from
http://www.antiqueradios.com/forums/...p?f=6&t=166720
http://www.spridgetguru.com/TA0041.html
http://autoxer.skiblack.com/nallm/mp3jackinamfm.htm
blkcorvair is offline   Reply With Quote
Old 01-08-2012, 08:55 PM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: AUX input jack for 67-72 AM radio
very cool! recommending for an FAQ!
Old 01-09-2012, 02:08 PM   #3
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
awesome
John
1999 Toyota Tacoma 4x4
Old 01-09-2012, 02:23 PM   #4
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
Great job, I did a similar conversion on the stock BOSE radio in my 2003 GMC Duramax a few years ago using the same stereo jack.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 01-09-2012, 03:19 PM   #5
blkcorvair
blkcorvair's Avatar
I forgot to mention. If you make the wires longer there is no reason you cant install the input jack somewhere on the dash or even in the glovebox out of site. (Just if it is not installed in grounded metal you must add a ground wire to the #1 terminal.)
Old 01-10-2012, 01:30 PM   #6
cjohnson6772
cjohnson6772's Avatar
Very very slick. I am now on the hunt for a stock AM radio and will be selling my ken harrison piece of junk!
cjohnson6772 is offline   Reply With Quote
Old 01-22-2012, 10:02 PM   #7
kvn1011
Kvn1011
kvn1011's Avatar
Nice!
kvn1011 is offline   Reply With Quote
Old 02-05-2012, 02:15 PM   #8
camaney
great.. no i can do it my self
camaney is offline   Reply With Quote
Old 02-23-2012, 12:28 AM   #9
70 supersport
Does it work the same for a factory am/fm radios?
70 supersport is offline   Reply With Quote
Old 02-23-2012, 12:39 AM   #10
70 supersport
Will it work the same for a am/fm radio?
Old 02-26-2012, 09:20 AM   #11
blkcorvair
blkcorvair's Avatar
I would think it would as they were mono as well. If you open the cover and it has three leads into the potentiometer I'd say your good to go. Ive only done this one, but Ive heard it relativly easy to do to a "stereo" radio as well. Never tried....Yet.
Old 02-26-2012, 06:35 PM   #12
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Do you only use "one" speaker with this mod or did you add something for multiple speakers?
Curious......
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 02-26-2012, 08:28 PM   #13
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Curious......
Smitty
It uses the stock speaker and stock radio....just lets you connect an ipod, mp3 player, or cd player to the radio.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 02-27-2012, 03:05 PM   #14
blkcorvair
blkcorvair's Avatar
Old 03-12-2012, 07:29 PM   #15
chevy88
chevy88's Avatar
Will a 3 terminal 1/8" input jack work instead of a 5 terminal? Can't find a 5 terminal, and from my understanding you are just taking the left and right speaker side and putting them into one as you are just hooking up the one original speaker.
Kerry
My build thread.
http://67-72chevytrucks.com/vboard/s....php?p=3657823
1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears
1988 Chev Extendacab
2010 Honda VT1300CS Sabre
2005 Buick Rendezvous wife's ride
chevy88 is offline   Reply With Quote
Old 03-12-2012, 11:23 PM   #16
red71c10
The Red Menace
red71c10's Avatar
Perfect! That is just what I want! To be able to keep the factory radio and have an easy way to run my iPod through it! I know I can do that! I'll have to buy a new speaker to go along with the input install!
Very Cool!!!
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current)
1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former)
1968 C-20 - 307/3sp column (Dad's when I was a kid)
"Driving is like coloring. Things get messy if you can't stay inside the lines."
red71c10 is offline   Reply With Quote
Old 03-13-2012, 12:57 PM   #17
tommyd241
tommyd241's Avatar
Very cool!
'68 SWB Fleetside
'98 K1500 Silverado
tommyd241 is offline   Reply With Quote
Old 03-15-2012, 03:30 AM   #18
chevy88
chevy88's Avatar
To save people looking up parts, here are the part #'s from radio shack.
The resistors in picture are 1k ohm 1/4 watt. part # 271-1321 package of 5 for $1.19
1/8" stereo panel mount phone jack with 5 terminals. part # 274-0246 for $2.69
Original replacement speaker 4" x 10" delco style special rectangular $49.95
Phone # US 1-877-780-2861 or outside US 1-763-780-2861 here is website http://www.turnswitch.com/speakers.htm
I jumped the gun and ordered 2k ohm resistors 1/2 watt before I knew what was exactly in the picture can some one tell me if this matters???
Kerry
My build thread.
Old 03-21-2012, 01:05 PM   #19
Normru45
very cool, just posted somthing kinda on the same page as this but i really like what you have done!
Normru45 is offline   Reply With Quote
Old 05-07-2012, 02:27 PM   #20
claytonisbob
This is too awesome! I am going to do this this weekend.
claytonisbob is offline   Reply With Quote
Old 05-07-2012, 08:20 PM   #21
MistaGavin
MistaGavin's Avatar
This is very cool. I think I will do this as well.
You're not old, it IS loud!
1970 CST-10 BB 400
MistaGavin is offline   Reply With Quote
Old 05-07-2012, 09:18 PM   #22
Kidd-7
Kidd-7's Avatar
It will not matter, they may be a little larger. That rating only has to do with how much power before the smoke comes out of the resistor...
71 C-10 - 307 - 3 on tree
01 Ford Explorer 5.0 v8
96 Mercury Cougar v8
79 Trans Am 403 Olds
Kidd-7 is offline   Reply With Quote
Old 05-07-2012, 10:51 PM   #23
MistaGavin
MistaGavin's Avatar
Just got my parts for this upcoming small project. Resistors and 1/8 jack were a whopping $3.88
1970 CST-10 BB 400
Old 05-14-2012, 11:53 PM   #24
Bassetlounge
I am about to try this myself.. How have the others done implementing this? Anything to watch out for? I assume the radio still works if the aux jack is unplugged?
Bassetlounge is offline   Reply With Quote
Old 05-15-2012, 12:46 AM   #25
BBrendal
Recalculating.....
BBrendal's Avatar
Sweet!
Brian - (BBrendal)
1969 Chevy Camaro Z28
1972 Chevy Blazer CST
2004 GMC Yukon (The truck that pulls the car trailer)
1972 Chevy Blazer CST #2 (Finished and sold!)
Blazer build link...
http://s1213.photobucket.com/albums/...rendal/Blazer/
BBrendal is offline   Reply With Quote
