Old 12-07-2011, 12:52 AM   #126
bigblock73
yeller
bigblock73's Avatar
Re: 67-72 cab corner 6x9 speaker brackets
Thanks for the feedback Greg, glad you like them.
I really enjoy seeing the installs of these guys, so when you get them in, please post some pics.
bigblock73 is offline   Reply With Quote
Old 12-12-2011, 08:25 PM   #127
bigblock73
yeller
bigblock73's Avatar
TTT, have a few sets of each left.
Old 12-18-2011, 03:51 PM   #128
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
I'll take a set with holes. PM on the way.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 12-26-2011, 10:06 PM   #129
Hart_Rod
Hart_Rod's Avatar
Here's a few pictures of mine installed. I had to drill some wider spaced holes for the passenger's side lower adjustable bracket, but other than that everything installed fairly easily.
PS Should I drill a hole to allow air to escape from the back side????
Hart_Rod is online now   Reply With Quote
Old 12-27-2011, 12:39 AM   #130
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Jeff, I sent payment tonight for a set with holes. Thanks again, Ryan.
Ryan
1969 Chevy milk truck
Old 12-27-2011, 01:15 AM   #131
bigblock73
yeller
bigblock73's Avatar
Rob, your install looks great! You wouldn't have any pics showing the modification to the lower bracket would you? I am surprised one side had to be modified and not the other, all four brackets are the same, 2 bent one way 2 bent the other.
As far as ventilation, I am not sure. If anyone can chime in I would appreciate it. If I need t provide baffles, so be it...I will do that. I would just like to know. I do know these are not air tight, but kind of close.
Thank you for the pictures and feedback once again.
Old 12-27-2011, 01:16 AM   #132
bigblock73
yeller
bigblock73's Avatar
Thanks Ryan, just came in from bending and boxing yours...they will be in tomorrows mail.
Old 12-27-2011, 01:23 AM   #133
longbed67
longbed67's Avatar
No need to put relief holes in, actually the tighter you can seal them to prevent any air from going in or out, the better as you will get better sound quality and volume out of them.
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 12-27-2011, 07:59 PM   #134
74baggedbug
Any with holes still available? Thanks
74baggedbug is offline   Reply With Quote
Old 12-27-2011, 08:54 PM   #135
Dieselwrencher
Jeff, thanks. You could have taken the day off though man.
Ryan
Old 12-27-2011, 09:19 PM   #136
bigblock73
yeller
bigblock73's Avatar
Yessir, have about 6 left or so. PM sent.
Old 12-27-2011, 09:20 PM   #137
bigblock73
yeller
bigblock73's Avatar
I took off the whole week...your brackets will be there in a few days.
Thanks again!
Old 12-27-2011, 10:59 PM   #138
Hart_Rod
Hart_Rod's Avatar
Tom - There's an deep indention in the floor pan on the passengers side that kept me from using the original two vertical holes. I think it's the storage location for the jack. All I had to do was to move those two vertical holes out about 3/4" so I could catch the flat part of the floor. Here's a some pictures of the indention.
Old 12-28-2011, 12:55 AM   #139
bigblock73
yeller
bigblock73's Avatar
Thanks for the pictures. Let me make sure I understand what you had to do...
On the "L" bracket, the one that mounts to the floor. You had to move both floor mounting holes out 3/4" per side on only the passenger side...correct? The slotted holes on the "L" bracket were fine, as were the corresponding holes on the speaker bracket itself right?
Thanks for the feedback, I will update the next batch I make to reflect this. I am glad this is an easy fix and doesn't affect the overall install, or so it seems.
Old 12-28-2011, 10:39 PM   #140
Hart_Rod
Hart_Rod's Avatar
Yes....
Old 01-09-2012, 11:59 PM   #141
bigblock73
yeller
bigblock73's Avatar
TTT, still have some brackets
Old 01-12-2012, 09:31 AM   #142
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
Hello feller, do you have a set with no holes? If so, what's the total shipped to 37806? I have a PayPal account if you want to PM me your info. These look sooo nice!!!
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011
1989 Chevy Silverado, 4X4 - Daily Driver
1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck
1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original.
Members I've met: BamaBaxter,
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359
Camaro_nut2001 is offline   Reply With Quote
Old 01-12-2012, 11:34 PM   #143
bigblock73
yeller
bigblock73's Avatar
Yes I do, and PM sent
Old 01-13-2012, 12:25 AM   #144
RocketKing
RocketKing's Avatar
Do you have another set with no holes? Price to 72616.
Rex
RocketKing is offline   Reply With Quote
Old 01-13-2012, 01:20 AM   #145
bigblock73
yeller
bigblock73's Avatar
Ye I do, PM sent.
Old 01-27-2012, 12:13 PM   #146
bigblock73
yeller
bigblock73's Avatar
TTT, have a handful of brackets left with holes and no holes, boxed and ready to ship.
Old 01-27-2012, 03:10 PM   #147
425HP409
425hp409
425HP409's Avatar
I will take two sets with holes.
Charles
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
Old 01-27-2012, 05:03 PM   #148
bigblock73
yeller
bigblock73's Avatar
PM sent Charles
Old 02-06-2012, 08:32 PM   #149
weircc
weircc's Avatar
do you still have a set left ill take a set for 65 just give me paypal info thanks
1971 rs camaro under the knife ls3 6 speed swap
1970 396 big block shorty fleet 67 clone
2010 rs/ss camaro
weircc is offline   Reply With Quote
Old 02-07-2012, 01:13 AM   #150
bigblock73
yeller
bigblock73's Avatar
PM sent
