Old 02-12-2012, 08:30 PM   #1
CanadaBuzz
1963 4X4 bell housing.
I have a 1963 Gmc 4X4 with a 6cyl 235CI with a 4 speed manual transmission. Is there a bell housing I can use to swap to a SBC?
CanadaBuzz is offline   Reply With Quote
Old 02-19-2012, 02:46 AM   #2
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Re: 1963 4X4 bell housing.
EDIT: See below posts for correct info on 235s. I based my prior response on assuming 235 & 250 shared bellhousing pattern.
The bell housing bolt pattern should be the same. I just bolted up a 97 small block T56 to my 250 with no problems.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
Last edited by lowrollin70gmc; 02-27-2012 at 05:11 PM. Reason: I was wrong, assumed 235 shared housing w/ 250
lowrollin70gmc is offline   Reply With Quote
Old 02-25-2012, 05:27 PM   #3
maxwoof
I would double check in terms of the 235. I would agree with the above If yours was a 250. However, 1963 was the last year for the 235 and then only in the 4x4. It is my understanding that the new sixes that came out in 63, which will interchange with the SBC, are entirely different from the 235.
That said, they did use the same 4 speed until about 1968 or so, so the 235 bell housing may interchange. Or, your tranny may bolt up to a later SBC with a 4 speed bell housing. Good luck.
maxwoof is offline   Reply With Quote
Old 02-27-2012, 02:04 PM   #4
61K10
61K10's Avatar
I had a 235 in a 1958 and the B/H was not compatible with a sbc. any 55 and up v8 truck with side mounts should work. must be a truck! 55-57 cars are similar but use different side mounts. the trans mount on both housings are the same. if using a starter thats bolts to the block some mods have to be done.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
