68 Rear Springs and 72 Rear Springs Whats The Difference? LIFT
I have a 68 K10 I am restoring. My goal is to put a 2-3 inch suspension lift on it to run 33's with out rubbing. It has just a mono type rear spring on it. The Skyjacker lift that I am looking at for my model 68 only offers the rear block. But if I fudge my year up to a 72 it offers rear springs. The 72's are a multi leaf spring.
Before I spend the cash will the rear springs fro the 72 kit work on my 68? I know that I am not the first to go through this. Just wanted to swap out the 40+ year old springs. Any Info Would Be Very Appreciated!!! Thanks
Ryan |
![]() Join Date: Aug 2008
Re: 68 Rear Springs and 72 Rear Springs Whats The Difference? LIFT
I haven't *seen* 67-68 leafs myself. But I've read online (where everything is true
![]() How wide are yours? I know the ones on my 66 are 2-1/2" wide, so it seems weird to me that GM would have put a wider spring in for two years only.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
One of the First
![]() Join Date: Jan 2000
I believe the 68's fronts are 3" longer that 69-72, you can have a custom set of 68's made a reasonable cost.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) Last edited by D.PASSMORE; 02-28-2012 at 03:09 PM. |
I measure the 68's today as well as a buddy's 78. They both measured 56" eye bolt to eyebolt. The only thing with the 68 where it bolts to the shackle the spring measured right at 3", then where it bolts to the axle it measured about 2.5". So I think my main issue is going to be where the spring bolts to the shackle?
Ryan |
Young Gun
You could use some sort of spacer between the spring and shackle. This really shouldnt have any negative affects or be unsafe.
1968 chevy c10 soon to have 454 and turbo 4006 1970 custom/20 4x4 454/sm465/np205 around 7 inches of lift with 36's. 1992 ![]() Soon to have a few more upgrades ![]() 2003 ccsb 1500hd |
Tags |
k10, lift kit, rear springs |
