#76 |
Re: "Sin-thia" My 74 GMC
I just found your build.
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r http://67-72chevytrucks.com/vboard/s...d.php?t=460030 ![]() 97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver 220,000 miles, all stock for now |
#77 |
Buy a tank topper and heat with propane, your truck is looking great!!!
I think I can, I think I can, http://67-72chevytrucks.com/vboard/s...d.php?t=452601 |
#78 |
I have thought about getting one.
Thanks. Posted via Mobile Device
#79 |
hey i have a question about your wheels, what size tires are you running? and do they rub on the inside of the bed.. im thinking about running these on my project..
#80 | |
#81 |
thanks alot for the info.. im getting mine redrilled, and hoping to get them up on my project soon.
#82 |
No problem. You have a build thread?
I did a small amount of work to the truck today. Moved the engine back 1.5", i'll post pics tomorrow. Posted via Mobile Device
#83 |
dont have one right now but i will start one this week. this will be my first truck to mess up.. hopefully i can put it back together..
#84 |
A couple days late but I was having computer problems...........
I made new holes at 1" and 1.5" back, I didn't even try it at 1" and went straight for 1.5" which is only .5" back from the original location due to everything moving forward 1" when I Zed the frame...... ![]() ![]() ![]() Enough room for the drivers side valve cover even...... ![]()
#85 |
Sold my sectioned crossmember, going to make another one this week so I can move the uca mount back and the lca forward to gain caster. I am also going to make some motor mount stands to move the engine back another 1-1/2", it'll be 3" back from the axle center line and 2" back from stock.
I also got the doors, column and master cylinder removed, getting closer to starting the rust repair on the cab. Plus raise the trans tunnel and push the engine recess back 2" deeper into the firewall. Posted via Mobile Device
#86 |
cool post pics of the process on how you make the Xmember bro....
nOtHiNg LiKe ThE gOoD oLe ChEvYs.... ![]() |
#87 |
Cutting another stock crossmember, but i'll try and get more pics this time.
#88 |
Anything on this? I'm digging it.
74 C10 LWB 350/T5 Dropped on 20's Soon to be Bagged and Injected 84 C35 Crew Cab Dually. 454/400 Dropped a lot. Instagram: mmmdropp |
#89 |
Thanks.
Unfortunately not lately, combination of the 2 months of triple digit temps and a lack of time, money and motivation. But I hope to get started on it again soon. Posted via Mobile Device
#90 |
Get to working on that front crossmember! And post lots of pics so I can copy it!
#91 |
Tryin to, working 55hrs a week doesn't leavemuch time or energy. But i'll get to it soon.
#92 |
GoatLube Experss
![]() Join Date: Oct 2009
any thing ? to far along to not finish now ?
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
#93 |
Haven't given up, just haven't been motivated nor really had the time to do much. I plan to get started again once it starts to warm up again. I have came up with a couple changes on how i'm doing some stuff, nothing to drastic though.
#94 |
![]() Join Date: Sep 2009
I like what you are doing. This is going to sound like a broken record but i'm really digging the wheels. You mention they are Dodge. Are they spare wheels or something? I think i'm going to explore that route. What spacer/adapter did you use? My truck will only be dropped 2.5in in the front and 2in in the rear.
Experience is something you gain when you didn't get what you wanted in the first place. No great defeat was ever just possible in the beginning. |
#95 |
The wheels are one of the things changing, just working out the details. The adapters are 1-1/4" thick, but I don't know who made them. And the rotors were redrilled to the dodge bolt circle, yeah they're dodge ram spare wheels.
#96 |
Nice truck you have some nice fab skills I want to see this one done
--------------------------------------------------- http://www.facebook.com/home.php |
#97 |
Still haven't gotten anything done, I have been off work all week but it was raining and cold until wednesday, yesterday being the first nice day since last saturday. Unfortunately I have to get may garage cleaned out and organized in order to get anything done, but i'm feeling the itch to do something again. Hope to have an update within the month.
#98 |
How low are you in the front any rubbing issues?? Did you use spacers all around?? I like the look of the 20s looking to get some for my 84 any advice would b a big help Thanx
Posted via Mobile Device |
#99 | |
a 5/7 drop. Here is a link for the wheels http://www.finishlinewheels.com/DODG...07/S-02166U45/ Posted via Mobile Device
#100 |
Ok Thanx. Wasn't sure if the spacers were gna give it enough room in front of that body style truck. What size tires are you running. I like the stance of the truck.
