![]() Join Date: Jan 2012
Re: Project MPS ll
been awhile since iv done some work and posted some pics, but spring is here and theres lots to do to my truck yet, I have lots of small parts to install yet but I did order new front fenders and a rear mount gas tank kit from lmc that was used on gearz, I got the fenders and grill just on test fitted right now still need some other parts first. heres some before and after pics of the front of the truck
Re: Project MPS ll
took the box off to put my fuel tank in and found more crappy body work by a previous owner, they put new cab corners on and didn't fuller weld them for starters, then fiber glassed over them to hide the gaps without sanding so it had some to adhere to so it started to come off I ended up illing it off in one big strip
so I can only imagine what the other cab corner is like not to mention the rocker panels. so now I can add cab corners to the list of butchered drip rails, and fiber glass covered cab supports im thinking im just going to find a cab that is at least a lil better shape with good floors and drip rails at least so I need to fix that cab corner an prime the back of the cab and box before I can put the box back on Last edited by 1972BackInBlackC10; 05-29-2013 at 07:03 PM. |
Re: Project MPS ll
got my gas tank put in and fuel line ran, just need to put clamps on fuel line, hook up the vent line for the tank, extend and hook up the wire for the sending unit/fuel gauge then put the bed back on and install my bed mount fuel filler, already drilled the hole for it in the box, oh and I need to hook up the fuel line to the fuel pump
going to be ordering new inner fenders, body mounts, inner/outer grill. hopefully find some good used bumpers and possibly order some new rims next week sometime hopefully |
VA72C10
![]() Join Date: Mar 2008
Re: Project MPS ll
cool! New parts are always fun
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
Re: Project MPS ll
hmmmmm its been 5 years since I posted on this, been a lot of ups and downs since then, i wonder if I should keep posting here or start a new thread all together
Re: Project MPS ll
Just keep posting, to keep it all together, so it can be followed....life happens....
