Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 04-09-2012, 11:38 PM   #1
mosesburb
I had a V-8
mosesburb's Avatar
Remove Overspray From Brand New Tires??
I got some overspray on a brand new set of tires. Single stage urethane (mean stuff). It is very dry now as I did not realize I did it until now. I know some chemicals that will take it off, but I don't want to ruin or reduce the life of the tires by using it.
Anybody know a safe way to remove overspray from new tires??
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE.
mosesburb is offline   Reply With Quote
Old 04-10-2012, 12:22 AM   #2
BruthaMan
US Army Veteran
BruthaMan's Avatar
Re: Remove Overspray From Brand New Tires??
Not sure what to recommend to get it off, however, I have used a product called Forever Black on tires, black plastic trim, rubber seals, etc and it works very well. It "soaks" into rubber and covered up some overspray I had on some old rubber seals.
BruthaMan is offline   Reply With Quote
Old 04-10-2012, 12:42 AM   #3
oldschool18
oldschool18's Avatar
you can try adhesive remover or maybe you a scotch brite pad or a sos pad, I use to put vasoline on the tire and then you can paint the rim and then just spray off the vasoline. but if you forget to cover the tire when you spray the body that sucks
_________________________________
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Members Met......2003Silverado (Dave)
oldschool18 is offline   Reply With Quote
Old 04-10-2012, 02:04 AM   #4
mosesburb
I had a V-8
mosesburb's Avatar
I use the Mothers version of that stuff. It works great for reviving black trim. I think if I had this stuff on prior to the paint it would wipe right off, but I think this paint is too far cured for this stuff.
It is not quite that much. I was painting a couple panels over here and the tires were over there. The paint rode a breeze over to the tires so it is not very heavy/thick. I forgot how evil the overspray from single stage urethane is or I would have tarped the stack of tires. Ugh.
Old 04-10-2012, 06:56 AM   #5
rsavage
rsavage's Avatar
Maybe a little enamel reducer?
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 04-10-2012, 09:11 PM   #6
yfs200p
E.H.F.D Engine #2
yfs200p's Avatar
black spray paint....
-NICK
'72 K10 SWB Fleetside. Avocado Highlander 350-4speed-NP205 Frame Off Re-Creation
'89 GMC V3500 C/C Flatbed Plow Truck 454/SM465/Np205
'15 Chevy 2500HD CCSB High Country Duramax
'22 Tahoe Premier Duramax
yfs200p is offline   Reply With Quote
Old 04-10-2012, 10:46 PM   #7
Willys47
Willys47's Avatar
try paint striper or brake fluid
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 04-11-2012, 12:08 AM   #8
BIGKEV
Have em flipped on the wheel!
BIGKEV is offline   Reply With Quote
Old 04-11-2012, 07:23 AM   #9
cdowns
cdowns's Avatar
i'd try hot water and soap with a brillo pad first
Old 04-11-2012, 04:41 PM   #10
sduckworth13
sduckworth13's Avatar
The Magic Eraser
Scott
sduckworth13 is offline   Reply With Quote
Old 04-14-2012, 07:22 PM   #11
solidaxel
solidaxel's Avatar
Back in the 60's we used brake fluid on suspension rubber parts for a lube, should work great on your tires to remove paint, it will remove the paint on the car, just don't get it on the tread !!!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-15-2012, 02:15 AM   #12
mosesburb
I had a V-8
mosesburb's Avatar
There are some good ideas in here, but I think I am going to try the brake fluid route first. I had a "weekend project" that is currently entering its third week so I haven't had a chance to get after this project. I was talking with a buddy of mine and he said back in the days prior to ArmorAll, his dad would shine up the tires on his vehicle with some brake fluid and we all know how destructive it is to automotive paint, so I figure it is a good place to start. Just curious, why do you say to keep it off the tread??
I will report back with my results in case someone else forgets to cover a brand new stack of tires when they blow several coats of single stage urethane nearby.
Old 09-08-2012, 08:36 PM   #13
scapegoat67
scapegoat67's Avatar
lacquer thinner and elbow grease .
scapegoat67 is offline   Reply With Quote
Old 09-08-2012, 10:45 PM   #14
truckdude239
truckdude239's Avatar
just an fyi brake fuild on tires will dry the rubber out as will lacquer thinner
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 09-14-2012, 12:52 PM   #15
gimpie01
Bug and tar remover works well.
gimpie01 is offline   Reply With Quote
Old 01-17-2013, 01:08 PM   #16
aggie91
I'm just glad to be here!
aggie91's Avatar
I always used enamel reducer on a rag for getting it off the rubber. Afterward, I would clean it with soap and water and then apply a protectant to keep the rubber from drying out. Always worked welll for me.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-17-2013, 04:38 PM   #17
theastronaut
theastronaut's Avatar
Glass bead blasting will work if you remove the tires.
theastronaut is offline   Reply With Quote
Old 01-17-2013, 05:52 PM   #18
LockDoc
The Older Generation
LockDoc's Avatar
No matter how you clean them you need to re-coat them with a protectant. Here is some info I found on the net...
To protect tires, manufactures add a wax compound to reduce ozone and water damage. The wax is designed to sit at the surface of the tire and form a protective barrier between ozone and water, and the tire rubber. The wax only moves to the surface, when the tires flex. This happens every time you drive, and is called “blooming”. Cars that sit for extended periods of time don’t experience blooming, and are unprotected against ozone. Combined with UV light, drying, discoloration and cracking begin very rapidly.
The solution is tire dressings. Tire dressings are designed to protect the tire, restore essential moisture, and condition the rubber.
This is why it is important to use a quality tire dressing. You want a dressing that not only provides UV protection, but also is devoid of chemicals such as petroleum distillates.
Recommended Dressings: Lexol Viynlex, Aerospace 303, Pinnacle Rubber Protectant, Zaino Z-16, and Meguiars Endurance.
LockDoc
Leon
Old 01-17-2013, 08:40 PM   #19
piecesparts
Parts and more parts
piecesparts's Avatar
Frank
Old 01-18-2013, 12:01 PM   #20
gimpie01
bug and tar remover works great
Old 01-18-2013, 10:26 PM   #21
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Since this was initially posted back in April of '12 any updates?
What worked?
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-20-2013, 02:26 PM   #22
mosesburb
I had a V-8
mosesburb's Avatar
LockDoc
That is some great information there Leon. I have wondered about that because around here tires start cracking long before they are worn out. I have talked with tire guys and they claim tires are made the same as they used to be, but I don't remember tires age cracking as quickly, say, even ten years ago. <dunno>
Old 01-20-2013, 02:30 PM   #23
mosesburb
I had a V-8
mosesburb's Avatar
What worked?
Well, one would think there should be an update, but to be honest, I haven't even had a chance to install the panels I painted that created this overspray, much less clean the overspray off the tires. Events seem to conspire against my available time . I do appreciate all of the great ideas presented here and I will definitely post up what I try and whether I can get it to work or not.
Old 02-07-2013, 07:38 PM   #24
DANTES JIMMY
DANTES JIMMY's Avatar
Sand blast em makes em look brand new
DANTES JIMMY is offline   Reply With Quote
Old 02-07-2013, 10:26 PM   #25
AirSpeed
AirSpeed's Avatar
I used Comet cleanser to get urethane off my tire, it worked great. I always use comet to clean my tires anyway, they come out super black and if you have white lettering in them they will turn out very bright white.
AirSpeed is offline   Reply With Quote
