![]() Join Date: Dec 2011
67CST rebuild down under
hi everybody i got my truck back from the painters today , now i have to do some work to put it all back together . i dropped it off at the painters dec 09 i had a cash flow problem but that is ok now so here we go
Re: 67CST rebuild down under
the first job i have to do is put it up on jack stands and take the diff out . i have tubbed it to the chassis rails and i have 15x10 centre offset centerlines with a hoozier 29 x15.5 for the rear. i have to order new moser axles . i have c clip eliminator kit , diff brace ,30 spline eaton trutrack ,rear disk brake, short stroke shockers,and new lowered springs i will post pixs of the parts tommorow every thing has been in storage for 3 years. its good to see my stuff again.
the pix did not load mabe this time.
Nice truck mate, but it seems your steering wheel is on the wrong side. (Just Kidding) Lew
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart 1998 Chevy 1/2 ton ex cab V-6 5 speed 1967 Chevy SWB - project truck; not started just yet |
yes i know, i would rather of left it left hook but our road laws are if lhd it has to be all original even down to the wheels. i wanted to lower it and put centerlines so i had to convert the truck and i got a bb for it as well so rhd it had to be
Sofa King Crazy!!
The laws are as crazy there as they are in Canada, I hope James (Nuke1) chimes in on this thread!!! It is looking sweet already, of course we are looking for some technical frame cutting and tubbing advice from you! Great start to an awesome project!!!
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() |
that is a great color and looks teriffic being the steering is on the wrong side it gives a real good view of the ditch to the driver.
today i dummy fitted the diff with the new lowered springs and the one inch lowering blocks . took some measurements and worked out i need to shorten the diff two inches. i noched the chassy 3/4 in to fit the bb motor stands . fitted a 71 e brake ass . started to dummy fit the front stabilizer. mounted the power booster and started to mount the accelerator pedal next job is to mount the t400 crossmember.
here is a couple more pix
looks like it is going to be a sweet ride. I will check back often to see how things a progressing.
hey brian, bet you dont send many parts down under thanks for your help bud
![]() Join Date: Feb 2011
Looking good mate!! Pitty bout the laws in SA. Keep it up. I'll be watching this one. Cheers
Check out my Rigs! 69 C10 getting bagged baby!! http://67-72chevytrucks.com/vboard/s...d.php?t=465547 78 K10 http://67-72chevytrucks.com/vboard/s...d.php?t=527664 |
I like the progress since I was here last.
thanks for the kind words
#15 |
I unpacked a few more things today the dash cluster and the diff cover . I went to my diff guy today and ordered two new moser axles
#16 |
I am running power windows from Nu Relics , they where really helpful . there 67-72 power window kit does bolt straight in and the switches look good too.
#17 |
one more
#18 |
here a pic of my mew hood letters nos
#19 |
here is an aussie ute
#20 |
Sofa King Crazy!!
The black on your Ute is super slick Mark, great bodywork. Glad to see you got a thread going too. You are gonna be overwhelmed with all of the help you are gonna get by doing this thread! Keep the pics comin bro!!
#21 |
i finnished doing the dummy set up on the diff so now i am going pull it all apart. the diff is going to get shortened . i have ordered new 3.90 gears and i am going to start prep work to paint the chassis i get the front rotors back tomorrow , i had longer studs made and 1/2 in instead of 7/16 for extra strength because the extra weight of the bb
BOWTIE OR NO-TIE |
#22 |
here is the front rim and tyre combo 15x 8.5 with 265/80/15
BOWTIE OR NO-TIE |
#23 |
enjoying your build
#24 |
thanks bud
BOWTIE OR NO-TIE |
#25 |
BOWTIE OR NO-TIE |
