Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 05-10-2012, 09:26 AM   #226
RdoubleU
RdoubleU's Avatar
Re: D52 Caliper Rear Disc Brake Brackets
Capt'n - sorry I was referring to the D52 brackets I got from you, I've been unsuccessful in my search for finding any of the caddi parts
Haha I don't think you've dropped the ball, but i'm thinking im going to keep moving forward with the the rest of my build and wait on you to slam dunk these brackets
Originally Posted by Captainfab View Post
Sorry about dropping the ball on this guys. Working 7 days a week just doesn't leave much extra time. I'll make a better effort to see about getting these done. I have the levers already laser cut, I just need to get them formed up.
RdoubleU, the brackets you mentioned, are those the D52 brackets you got from me, or are you talking about the e-brake cable brackets?
RdoubleU is offline   Reply With Quote
Old 05-10-2012, 12:35 PM   #227
suttoncurt
suttoncurt's Avatar
Hey Guys - Quick question . I ordered the captin Fab brackets as soon as they were done and i'm just now putting them on . I will be running the Astro rotors as described in the first post on the rear of my truck . My question is what is the correct part number for the rear wilwood calipers ? I ordered 120-10938 bk but CPP sent me 120-10939 bk . Any help is greatly appreciated
suttoncurt is offline   Reply With Quote
Old 05-10-2012, 04:13 PM   #228
Nobby
Nobby's Avatar
My wilwood caliper part # is 120-10936....with no problems
Nobby is offline   Reply With Quote
Old 05-10-2012, 04:23 PM   #229
suttoncurt
suttoncurt's Avatar
Thanks Nobby !! That's the same caliper I'm going to run on the front . I was trying to figure out my rear caliper situation . But I think I have it solved .
Old 05-11-2012, 12:18 AM   #230
Captainfab
60-66 Nut
You should be running smaller diameter piston calipers on the rear than are on the front. The 2" bore calipers on the front, and the 1-1/4" bore on the rear
suttoncurt, you were correct, you will need 120-10938 on the rear. The 120-10939 that CPP sent you are for 1" thick rotors. The Astro rotors are 1-1/4" thick rotors. The 120-10936 are 2" bore calipers for 1-1/4" thick rotors on the front.
Old 05-12-2012, 03:16 PM   #231
suttoncurt
suttoncurt's Avatar
Thanks Capt !!! Got 4 black D52's on the way and there the correct part #'s . Ill post up some picts when i get them on . Can't wait !!
Old 05-12-2012, 10:34 PM   #232
mercuryman788
PM and payment sent.
mercuryman788 is offline   Reply With Quote
Old 05-12-2012, 10:56 PM   #233
Captainfab
60-66 Nut
Payment received and PM returned. Thanks
Old 05-16-2012, 07:29 PM   #234
lts70
1970 Daily Driver
lts70's Avatar
Has anyone found matching drilled and sloted rotors for both the 71-72 front rotors and the Astro rears? I have a thread stared any help would be apriciated. See below link.
http://67-72chevytrucks.com/vboard/s...d.php?t=524902
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is offline   Reply With Quote
Old 05-25-2012, 11:25 AM   #235
Gus350
68 C 10
Gus350's Avatar
The PO of my truck put a front end out of a 84 on my 68 I will have to measure the front rotors but I beleive they are the 1 inch will have to check this weekend . My quistion is if this is the case is it okay to run 1 inch in the front and the 1 1/4 in the rear?
Kevin
"Life is Hard But its Harder when your Stupid"
John Wayne
68 C10
70 C20
http://67-72chevytrucks.com/vboard/s....php?t=602326#
Gus350 is offline   Reply With Quote
Old 05-25-2012, 11:18 PM   #236
Captainfab
60-66 Nut
The thickness of the rotors really doesn't affect the braking bias. That is done with sizing the caliper pistons and regulating the fluid flow thru the use of a proportioning valve, either fixed or adjustable. So to answer your question, you should be fine with 1" rotors on the front and 1-1/4" on the rear. Let me know when you are ready for a set of these brackets.
Old 07-02-2012, 03:12 AM   #237
The_BullDog
The_BullDog's Avatar
Got a question for you capt. I have an extra front set of brakes from a 82 C10 can I use these to just swap the front brakes from the 82 to the rear of my 77? If so what else would I need to finish the swap?
The_BullDog is offline   Reply With Quote
Old 07-02-2012, 03:31 PM   #238
Captainfab
60-66 Nut
By brakes do you mean the calipers? If so then yes you can use the front calipers as long as they are for the 1.25" thick rotors. In addition to the calipers you will need the brackets, rotors, pads, hoses, a disc/disc or an adjustable proportioning valve, a disc/disc master cylinder, and some miscellaneous small parts.
Old 07-23-2012, 01:28 AM   #239
Project82
Bretzke Racing Inc.
Project82's Avatar
Thumbs up Re: D52 Caliper Rear Disc Brake Brackets
Hey Captainfab, i was doing some researching on Wilwood's website, and after reading this entire thread, I really like the idea of having the Wilwood D52 calipers on all four corners but i really have to retain a parking brake for safety inspection. What do you personally think about the Wilwood kits for the rear of my truck? I'd like to use the Wilwood D52 up front since i have Powerstop drilled rotors already, (Chevy Caprice 1" front rotors). So i need the 2" front piston dia. D52 calipers. I guess my question is, you would think one of Wilwood's rear kits would work in "harmony" with their own front replacement calipers...??
Here's the URL to the page i was looking at on Wilwood's site.. http://wilwood.com/BrakeKits/BrakeKi...olet&model=C10
I really like the D154 rear kit they mention for $750 since it matches their front calipers but they say it won't fit with 15" wheels...
And i like the Dynapro low-profile but the calipers in that kit are 4-piston, but that setup fits a 15" wheel.....
...Also after looking at their internal parking brake drum style setup it doesn't look that complicated to incorporate it into your brackets, then we could use D52 rear calipers, 1.25" dia pistons, and have their parking brake setup but that leaves what rotor to use?.... hmmm..
Any thoughts from anybody whose had experience with these setups??? or similair setups?
Thanks, Kris
1982 Chevy Silverado C-10 RCLWB - IN PAINT - Inferno Orange Metallic
Lowered 4.5/6 - 358 SBC 10.5:1, Comp XE268H cam, Aluminum heads, 650 Double pumper Holley carb, 2400 Holeshot Converter, upgraded T/h350 Trans. Stock Rear end for now (3.08 gear)
2004 Chevy Silverado 1500 LS RCSWB - Dark Spiral Gray Metallic
Lowered 2/4 - 4.8L V8 4L60E 10-bolt. some goodies --- NEW DD 11/9/12
"Expect the Un-expected"
"Gas, Grass, Or Ass...No one rides for FREE!"
Project82 is offline   Reply With Quote
Old 07-23-2012, 11:36 PM   #240
Captainfab
60-66 Nut
I don't have any experience with any of the Wilwood kits, so I really can't give an opinion.
I realize there is a definite need for a kit with an e-brake, and I do plan on working on one, but I just don't know when as I am still working 70-80 hrs a week with no end in sight.
Old 08-01-2012, 10:46 PM   #241
CSoliz
Torn between 66 and 78
CSoliz's Avatar
I've been cruising Autozone checking for parts and I'm a little confused. I keep reading the d52's are on 71-87 trucks but the parts differ on AZ's website. I did run across a note on the 84' calipers that says it is for J5 brake system. Is this what we would use?
http://www.autozone.com/autozone/par...vice=234655186
Or will the ones they show for my truck work, I have a 78?
CSoliz is offline   Reply With Quote
Old 08-01-2012, 10:58 PM   #242
Captainfab
60-66 Nut
That Autozone link does not specify which thickness rotor that caliper is for. An '84 could have either the 1" thick rotors or the 1.25" thick rotors. I'm pretty sure the '78 only came with a 1.25" thick rotor. You want the D52 caliper for a 1.25" thick rotor. One way to ID a D52 caliper is that the center to center of the slide bolts is aprox 7" and typically has a 2-15/16" diameter piston. The JB/JD7 calipers have a 3-5/32" diameter piston.
Old 08-01-2012, 11:04 PM   #243
CSoliz
CSoliz's Avatar
So 78 should be a d52, correct?
Old 08-02-2012, 12:13 AM   #244
Captainfab
60-66 Nut
Yes. All '71-'87 C/K series use the D52 calipers. But some are for the 1" thick rotor and some are for the 1.25" thick rotor.
Old 08-02-2012, 09:04 PM   #245
CSoliz
CSoliz's Avatar
Thanks Captainfab, I will be ordering a set from you real soon.
Old 08-10-2012, 03:50 PM   #246
gringoloco
A guy with a truck
gringoloco's Avatar
Do these require a longer wheel stud, or is the rotor hat of similar thickness to the drum?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 08-10-2012, 11:27 PM   #247
Captainfab
60-66 Nut
The rotor hat is thicker than a drum. Some guys are running the same wheel studs, and others are changing to a little longer studs. I'd say it depends on what wheels you are running.
Old 08-21-2012, 10:39 PM   #248
CSoliz
CSoliz's Avatar
Captainfab,
I'm gathering parts for this conversion and I am curious what master cylinder too use. Is there an easy way to find an MC that is disc disc that will work on my 78? It looks like I have a 1.125 bore.
Thanks.
Old 08-22-2012, 09:43 PM   #249
CSoliz
CSoliz's Avatar
I believe I got it. I think I am going with this one.
http://www.napaonline.com/Catalog/Ca...BLV_0355990714
Old 08-22-2012, 10:01 PM   #250
Captainfab
60-66 Nut
One of the most common master cylinders to use for a disc/disc conversion is a Corvette master cylinder. You will also need either a disc/disc proportioning valve or an adjustable valve in the rear line.
