Old 05-28-2012, 04:49 PM   #1
Kainedogg
Kainedogg's Avatar
Who has a TH350 bolted to a '99 LQ4
Not trying to reinvent the wheel. Just want to know what parts I need to make it work.
Kainedogg is offline   Reply With Quote
Old 05-28-2012, 05:47 PM   #2
clinebarger
Re: Who has a TH350 bolted to a '99 LQ4
1999 & 2000 LQ4's have a longer crank end than other LS engines, This takes care of the crank spacing, Do you have the flexplate? If not buy a LQ4 flexplate. You might have to slot the torque converter bolt holes in the flexplate.
clinebarger is offline   Reply With Quote
Old 05-28-2012, 07:09 PM   #3
Kainedogg
Kainedogg's Avatar
So any flexplate will do?
Old 05-28-2012, 07:10 PM   #4
Kainedogg
Kainedogg's Avatar
I have an extra 5.3 flexplate gathering dust.
Old 05-28-2012, 07:37 PM   #5
clinebarger
You need a LQ4 specific flexplate.
NO other LS flexplate will work.
1999 & 2000 LQ4's are a little different animals.
You do have cast iron heads,,right?
Old 05-29-2012, 10:50 AM   #6
Kainedogg
Kainedogg's Avatar
Indeed I do have cast iron heads. I will scour the junkyard today for a '99-00 specific flexplate. I see you have a Duramax, EfiLive on it? Have an '05 Cummins myself, unfortunately efilive is only available for '06+
Old 05-29-2012, 11:39 AM   #7
gringoloco
A guy with a truck
gringoloco's Avatar
Does not need to be 99-00 specific; you are looking for the flat flexplate, no dish. Like stated above, you'll need to slightly egg the converter holes to accommodate the difference between metric/standard bolt circles. Does the TH350 use a kickdown cable?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 05-30-2012, 08:11 AM   #8
Kainedogg
Kainedogg's Avatar
I am not sure. The last one I had on my Pontiac did have one and needed to be adjusted.
Old 05-30-2012, 11:24 PM   #9
gringoloco
A guy with a truck
gringoloco's Avatar
So, that's another consideration, as well as the dipstick, which mounts to the 'missing' bellhousing bolt.
-Chris
Old 05-31-2012, 06:41 PM   #10
clinebarger
Mine's 100% stock, Untill I build the trans it will stay that way.
Old 06-02-2012, 12:11 PM   #11
Kainedogg
Kainedogg's Avatar
lol, well what are my options?
Old 06-13-2012, 10:36 AM   #12
Kainedogg
Kainedogg's Avatar
None?
Old 06-13-2012, 11:18 AM   #13
gringoloco
A guy with a truck
gringoloco's Avatar
Bowtie overdrives has a kit for a TV cable for 700r4/2004r that may be able to be adapted for the kickdown. I've seen people attach a pipe clamp to the head for the dipstick, or buy an aftermarket, ala Lokar. I think I will try to use some sort of nutsert. Do not drill the block! There is a water jacket there...
-Chris
Old 06-13-2012, 02:04 PM   #14
Kainedogg
Kainedogg's Avatar
Thanks gringo
Old 06-13-2012, 03:02 PM   #15
chebyshortbox65
chebyshortbox65's Avatar
I'm running a 350 behind a 5.3 works ok I had one out of an express van with 80e so had the proper flexplate and spacer if you have a 60e the flexplate will not work as I was told I'm in the process of swapping in a 700 with the bowtie overdrive kit
chebyshortbox65 is offline   Reply With Quote
Old 06-13-2012, 05:47 PM   #16
Kainedogg
Kainedogg's Avatar
Where is the 80E?
Old 06-13-2012, 08:31 PM   #17
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
GM 4 speed electronic overdrive version of the turbo400.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 06-13-2012, 09:56 PM   #18
Kainedogg
Kainedogg's Avatar
Not "what", but "where" is it...lol. Figured he would have bought the trans to go along with the motor.
Old 06-13-2012, 10:25 PM   #19
68GMCCustom
Oooooooooooooops!
Kurt -
Old 06-16-2012, 04:39 PM   #20
Kainedogg
Kainedogg's Avatar
How the heck do I get the last bolts at the top of the trans out? Do I have to drop the trans first?
Old 06-16-2012, 06:25 PM   #21
gringoloco
A guy with a truck
gringoloco's Avatar
What truck is it in? I've had luck pulling them from above in 99-up trucks. Just crawl up on top of the engine and reach behind with an open end wrench...
-Chris
Old 06-16-2012, 08:07 PM   #22
Kainedogg
Kainedogg's Avatar
Its an '84 C10 Gringo. I haven't installed the LQ4 yet, just a sbc\th350 combo.
