Re: You guessed it, 1950 s10 swap.
Seemed like a lot to me as well. That's from frame to the bottom of the cab, not the mounting point. Being bagged I wanted to maximize my lift/lowering capabilities. And that's what got me the most.
1954 Chevy 3100 5 window, bagged on s10 frame, 6.0 ls swap/4l80e Past build thread http://67-72chevytrucks.com/vboard/s...=531261&page=3 1949 3100 s10 swap 5.3. Instagram -@thejcates |
hey whatever works man. I'm assuming you mean top of frame to bottom of cab floor?
I'm heading down this road very soon. Been gathering parts I need and getting my garage finalized. Can't wait to be where you are. Its a great feeling having everything moched up. Feeling like a truck again. great work
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
1953 3 Window Short Box |
Truck looks killer! I love the way she sits.
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
wow, looking great. Is the one pic your ride height or max lift? how far off you got your running boards from ground?
you running stock or drop spindles? man the patina on them fenders you used on your tubs are awesome, sux you had to cut them up. nice come up on the rims and tires. so fitting.
That Picture is ride height. I made the running boards level with the frame so It would lay on the ground when the frame did. I do have drop spindles as well. The fenders I am using for tubs were really ate up on the bottoms. Not in good shape at all. Im probably going to clear the truck the way it is and roll. I love it
Layedoutsonoma91, looks great. She lays right on the ground.
Shannon
48 Panel Truck 1948 Chevy / S10 1954 Chevy / S10 1951 Chevy / C4 47 Step van Lowered 1996 Dually |
Man i love the look of this truck. Old blue paint is perfect! This trucks look at ride height does it for me! Laid out is cool, just not my thing.
My Lost and Forgotten build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=442712 |
Thanks guys. I hope to keep making progress like i have been the past month until i get it running. Goal is the end of the year.
![]() Join Date: May 2005
Looks great... What did you do with the stock 50 frame?
Thanks for the replies and comments. 1lo67 I sent you a pm. I have decided to go a different route with the motor, I sold my 350 and bought a 5.3/ls1 to drop into it. Its what i wanted to begin with, I was just intimidated. I only want to do this thing once! so why not. Ill post more pics when i get progress done.
wow man it's looking awesome
av8tr33337 AKA Bartman ![]() Bartman's Ad-S10 Chassis Swap http://67-72chevytrucks.com/vboard/s...d.php?t=415418 My First Youtube Video http://www.youtube.com/watch?v=B6hSt...eature=channel More Pics of the 51 Project http://s668.photobucket.com/albums/v...hassis%20Swap/ 1951 3100 Pickup |
Awesome stance
USCG Aviator C-130 1959 Stepside build - http://67-72chevytrucks.com/vboard/s...d.php?t=602386 |
#15 |
Well had a couple set backs in the build. Sold my carbed 350 setup and decided it needed a 5.3. picked up a 04 5.3L from a silverado with computer harness and trans only 750. not a bad deal for around here, Made me make the jump to the LS world. Of course this turns my deadline/goal for the spring time!
![]() ![]() Cleaned it up and got an ls6 intake injectors and all the stuff to make the car intake work with truck pulleys. ![]() ![]()
#16 |
#17 |
nice man, good price. those are only getting more abundant. prolly cause everything those were in rotted out. Thanks GM for garbage metal. looking good.
#18 |
I found that motor and knew what I had to do. So i bought it and sold my 350. Always wanted a ls and the reliability of fuel injection.
#19 |
Layedout,
Truck looks awesome. Nice score on the LS too. I have a few questions if you dont mind... quite a few actually, I'll number them! 1. Did you modify the cab mounts to get your cab to sit 6.5" off the frame? Did you mount the support brackets on the mounts in the same place Jeff suggested at 3.5 and 3.75"? I'm hoping to mount the cab as you did and still lay frame... I want to avoid making a drive shaft cut out. 2. Did the S10 headers interfere with the stearing linkage at all? I'm unsure of which type to get. 3. What gas tank did you use? I was hoping I could use the original s10 gas tank since the LRD 6 (bought the kit) link came with the raised tank cross member... wondering if the cab gets in the way. 4. What size and type bags did you use in the rear? I have RE8's but was told they might be too large for this kit... not sure if the size issue was meant if installed in an S10. 5. What size white walls are you running? 6. What motor mounts did you go with when mounting the 350? I have more questions but don't want to wear out my welcome! Thanks for the updates btw, keep em coming! Eric |
#20 | |
1. I used the blueprints that Jeff made. I used poly bushings which added a couple inches to the top. I mounted it as high as I could and still keep the boards on the ground. 2. Im using ls swap s10 specific headers now, not sure on the clearance yet. I plan on having it in very soon tho. I ordered the 200 dollar stainless headers off ebay. 3. I used the LRD kit out back and I am using the s10 gas tank. I dont have it mounted yet. The tank looks like it will have plenty of clearance by how high I mounted the cab. 4. My kit came with bags, I dont see why any bag size couldnt be used. I am using 2600 up front and 2700 out back i believe. 5. The white walls are porta walls. They are 215 70 15 i believe. 6. On the mounts, i am using a LS motor now. Being the motor has to be back so far its gonna be hard to find mounts that will work. I bought some universal mounts and basically remade them completely. I hope to keep it going. Updates are coming soon.
#21 |
Layedout,
Thanks for getting back with the info. I appreciate it. Hoping to get my project on the road by summer. Wish me luck! Eric |
#22 |
Got a lot of progress done on the truck. Made some motor mounts and got the motor painted and in place. Couple pics.
Got my harness rewired for 3 wire operation and emissions removed. ![]() ![]() ![]() ![]()
#23 |
With shaving the firewall, did you fabricate the sheet metal or was it premanufactured?
#24 |
I just traced the firewall out on some poster board, then transferred it over to sheetmetal.
#25 |
Any body have all the metal diagrams to fit the body and bed to the frame?
