Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 06-03-2011, 09:53 AM   #1
remist17
remist17's Avatar
Removing oxidation from Aluminum wheels
I recently purchased some slot wheels that are brushed aluminum. There is some oxidation marks on the rims. What can I use to remove this and clean them up? The wheels are not high shine I do not think.
2013 Chevy Silverado, Z71, 5.3L, 4 door
2005 Chevy Silverado, Z71, 5.3L, 4 door, 3.40
Support the Troops.
remist17 is offline   Reply With Quote
Old 06-03-2011, 01:47 PM   #2
DesertCat
DesertCat's Avatar
Re: Removing oxidation from Aluminum wheels
Check the FAQ section, just read quite a thread about polishing
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131
DesertCat is offline   Reply With Quote
Old 06-05-2011, 09:03 PM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I use to use a product called Blue Magic, but it's no longer available in our area the last time I checked.
Anyone else?
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 06-05-2011, 10:06 PM   #4
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
r u sure its not clear coat peeling away
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 06-06-2011, 07:36 AM   #5
cdowns
cdowns's Avatar
easiest quickest cheapest way i've always found for a quick painless cleanup of slotted wheels is BRILLO soap pads
do all 4wheels in about 15-20 minutes at a cost of 50cents or so
its excellent to use wheels like that or a good first step to a final high polish result
Old 06-06-2011, 06:45 PM   #6
Sicklajoie
The Niner
Sicklajoie's Avatar
You could try S100 Polishing Soap available at local Harley dealerships.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 06-18-2011, 11:01 PM   #7
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Cleaning slot wheels:
1st. clean em up. I used oven cleaner and a scotch brite this time. followed with sos pad to get the cleaner off and any left over crud.
2nd. take care of any bumps and scars with agressive sanding. I had to use a file on the lips of a couple.
3rd. start sanding with 600 grit then graduate to 1000, then 1500, then 2000.
If you have a set thats not scared up like these you may be able to go strait to 1000. Usually don't have to spend alot of time with each grade, just enound to remove a fine layer of oxidized metal. The 2000 grit will tell the tale. And then your ready to polish.
4th. I used a buffer with fine cut compound and a sprinkle of water, then followed it with "mother's" on a cloth. could use a "powerball" if you have it. That might even work better.
that's it. It takes a little time, but I love to take something that looks used up and bring it back.
John
1999 Toyota Tacoma 4x4
Old 07-01-2012, 12:14 AM   #8
primrrd
primrrd's Avatar
i know a guy that polished his slots back in the day when we were parked at the river drinking beer with the river bank sand!
just handfulls of the sand and a cloth... no bull- they looked pretty good
primrrd is offline   Reply With Quote
