Old 07-04-2012, 07:20 PM   #1
wwj75c30
wwj75c30's Avatar
2002 5.3 in 73 c20
i was wondering if i can put this 5.3 in my 73 c20 i had a few questions
would it bolt up to my sm465? would my flywheel from a 350 work
and how hard would it be to convert it to carbed cause i dont wanna deal with computers
any info helps thanks
75 c30 silverado drw 454/th400hd d70 soon to have d60 up front
73 c20 custom deluxe sm465 14bff parts truck
wwj75c30 is offline   Reply With Quote
Old 07-04-2012, 11:58 PM   #2
wwj75c30
wwj75c30's Avatar
Re: 2002 5.3 in 73 c20
seriously noone?
Old 07-05-2012, 08:52 PM   #3
crazy longhorn
Fabricate till you "puke"
I havent gotten too deep into my swap yet,but here goes....your bell will mount right on the ls eng(you will be missing 1 bolt, upper rh side). Mcleod makes a .400 thicker LS flywheel, that will accept an 11 or 12 " clutch plate from your gen truck. It takes an LS-2 pilot bushing/bearing, from my understanding. Your LS starter should fit inside your stock alum bell. Mine wears a cast bell, & did take a little clearance work to fit the LS starter. you will need to fab your own dust cover for the bell. It is my understanding that Oreillys has a cheaper cast flywheel, to fit the app....maybe Leevon will chime in on that. I plan to run as computer/fuelie for the best on mileage, so I cant say much on the intake /carb. Most of the headers or manifolds on the LS, were designed to run a hyd clutch, so you need to watch that closely ,if running the old mechanical linkage (I plan a set of LS streetrod shorties on mine). Anyway back up, for more guys to play crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
