#26 |
Regular Joe
Re: Dana70HD Dually disc brakes
Found this in case anyone is interested:
http://www.pirate4x4.com/forum/showthread.php?t=875390 Really considering this swap.
Jason SuperSub© - '88 K20 Suburban, TBI 350/TH400/NP208, 3" lift on 35's The Sled® - '77 C35 Crew Cab Dually, TBI 454/TH400, 6"/9" drop, '81+ front clip Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=351386 Shorty™ - '84 C10, 305/700R4, 5"/7" drop Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=539961 Report A Post Club - Non-Member #2 "Snitches get stitches" |
#27 | |
I did have to get them to make me a spacer so the calipers would line up.
___________________ 78 ccsb dually 5.3 4l60e http://67-72chevytrucks.com/vboard/s...d.php?t=491551 |
#28 | |
Did this swap space the wheels out?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 90SWB Driver All Fleetsides Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive... like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar. Cubic inches is like Indiana Jones with a cheap pistol.... |
#29 |
I don't think it did, but i swapped from the 14bolt to the dana at the same time so i couldn't say for sure.
I could take a measurment if you need me to.
#30 |
I was considering running some different steelies. The diff wheels will space the wheel out a little more vs. the GM 16" steelies so I'm pushing the envelope on clearance w/the amount of drop it will have. No need to get dirty measuring as I'm just running a pros/cons checklist.
#31 |
Regular Joe
Any issues with proportioning, or was fine as-is?
Also, how did you make your hardline-to-rubber line brake hose connection? Any pics?
#32 | |
I just made a tab with a hole in it and used one of the push retainers like the front uses. Sorry no pics.
#33 |
Regular Joe
Picked up my rotors today. lol!
| Bookmarks |
| Thread Tools | |
| Display Modes | |
