Old 04-16-2012, 10:35 PM   #201
Rods57
Rods57's Avatar
Re: Rods 57
Originally Posted by 55Cameo View Post
Read your entire build thread. Love the clean frame and motor. Great work so far. Coming along real nice.
Thanks for comments its been a long time since I started, hope I get it done soon so i can drive it.
Rods57 is offline   Reply With Quote
Old 04-17-2012, 12:25 AM   #202
55Cameo
55Cameo's Avatar
Re: Rods 57
Always a great feeling when you can drive your project. I hated taking mine off the road. A lil here a lil there and it'll get done
55Cameo is offline   Reply With Quote
Old 05-03-2012, 12:46 AM   #203
Rods57
Rods57's Avatar
Re: Rods 57
So here is where I am at, some stuff primed, some stuff not. also found some donor fenders, thanks to Jay in Kuna, and they are great, the picture makes it look like there is a big dent at the front part but its just the way the sander left a mark. one has a small dent at the headlight area the other is on the wall on top and is all but perfect.
Old 05-03-2012, 05:42 PM   #204
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: Rods 57
Looking good, but it looks like a parts supplier exploded in your garage. Its raining body parts and thats a good thing.
Kabwe is offline   Reply With Quote
Old 05-03-2012, 08:32 PM   #205
Rods57
Rods57's Avatar
Re: Rods 57
Ha Ha, yes the shop is full, my son in-law has his 67 cougar in here as well so its really full....
Old 05-03-2012, 09:28 PM   #206
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Re: Rods 57
Fenders look good! You'll have to modify the 57 grill for it to fit with'em!
ChuckDriver is offline   Reply With Quote
Old 05-03-2012, 09:32 PM   #207
Rods57
Rods57's Avatar
Re: Rods 57
Actually I am going to make it a 55, I have a new grill and the hood is form a 55 as well.
Old 05-03-2012, 09:39 PM   #208
ChuckDriver
Re: Rods 57
Sweet!
Old 06-03-2012, 11:39 PM   #209
Rods57
Rods57's Avatar
Re: Rods 57
I stripped all of the paint off all of the body parts today, messy messy. Pictures are the before shots , got to quit a bit for a break as my 7 year old wanted to build a sweet, tye-dye dinosaur so got to take a good break for that...
Old 06-10-2012, 11:04 PM   #210
Rods57
Rods57's Avatar
Re: Rods 57
finally filled the big hole in the firewall, and finished the steering wheel mount.
Old 06-20-2012, 12:52 AM   #211
Rods57
Rods57's Avatar
Re: Rods 57
got a visit from the parts fairy today, I love it when i get home from work and there is a box waiting at the door to see me...
Old 07-23-2012, 12:06 AM   #212
Rods57
Rods57's Avatar
Re: Rods 57
Ok its been a really long time since i posted, life has been happening to me. so here is where I am at. I screwed up and gave myself to opportunity to re-do the fender that i cut from two. here is how I did it. use 1" tape and start at a certain bolt hole, I start on one side of the hole for the front and the other side for the back of the bolt hole. Made a second and third strip and then remove one from one of the fenders to give myself a clean edge on each side to cut up against. The fender closest to the front in the picture is the back half I used. You can see my massive screw up on the front....
Here they are together for the first time...
and final fitter before welding
Old 07-23-2012, 02:23 AM   #213
Kim57
Kim57's Avatar
Re: Rods 57
That's looking good. Now get to the welding.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 07-25-2012, 08:58 PM   #214
Rods57
Rods57's Avatar
Re: Rods 57
put some heat to the fender here is the process I used:
used clamps and this small streight edge to keep the two halves level
started at the top inside where the inner fender bolts on
played connect the dots, i still have to grind and fill pin holes but I am letting it cool between
Old 07-25-2012, 11:13 PM   #215
Kim57
Kim57's Avatar
Re: Rods 57
Looking good.
It's time consuming but worth it in the end.
Kim
My build thread
Old 07-26-2012, 11:57 AM   #216
Rods57
Rods57's Avatar
Re: Rods 57
So while I was waiting for it to cool I decided to put on a few body parts to start fitting them. That got out of hand quickly and the truck is all in one piece.
Old 07-26-2012, 11:58 AM   #217
Rods57
Rods57's Avatar
Re: Rods 57
Originally Posted by Kim57 View Post
Looking good.
Kim
thanks for the comment Kim, it is time consuming and hard to wait but well worth it.
Old 07-26-2012, 02:36 PM   #218
_Ogre
_Ogre's Avatar
Re: Rods 57
nice work on the fender
i'm amazed that you've had your truck in bare steel over a year with no rust...
we have 85% humidity today that would rust anything bare
i think i can hear truk rusting in the barn from here and truk is painted (and 200 ft away)
shop air compressor timer
Old 07-26-2012, 02:57 PM   #219
Rods57
Rods57's Avatar
Re: Rods 57
It's that thing you call humidity? What is that? We live in the desert, its pretty cool. Thanks for the comments, its been ten years since it was one piece.
Old 07-26-2012, 04:52 PM   #220
ChuckDriver
Re: Rods 57
Nice work, it's really looking good!
Old 07-26-2012, 05:29 PM   #221
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: Rods 57
You've done a great job buddy.
Old 07-26-2012, 05:57 PM   #222
Rods57
Rods57's Avatar
Re: Rods 57
thanks, now it looks like a 55, now that i have the right fenders on it.
Thanks, kinda looks a bit cool all metal no paint. now i gotta do something about the height its way to tall in front, that's gotta go....
Old 07-26-2012, 06:52 PM   #223
OrrieG
OrrieG's Avatar
Re: Rods 57
We are blessed with a very dry climate. I stripped down most of my truck in 2000 and it sat bare steel inside until 2007. When I got ready to etch prime it I just hit the whole thing with combination of 80 grit on a da and 3M Purple shredded wheat pad. Now if it is outside, we do get rain and snow so where it can get into cracks and crannys and not flash off right away it will rust.
Old 07-29-2012, 10:34 PM   #224
Rods57
Rods57's Avatar
Re: Rods 57
Finished the welds on the fender today. Looking like I am done with it
Old 07-29-2012, 11:04 PM   #225
_Ogre
_Ogre's Avatar
Re: Rods 57
great. add idaho to the list...
texas, arizona, new mexico and now i-da-ho
i hate you all
all we get here is 55 rust, 56 rust, 57 rust... you get the idea
i guess i should have brought some parts home when i was out there last aug.
bro-in-law in twin, sis in moscow and son in pullman.
maybe my son can get a good 68 elco body while he's out there.
