08-12-2012, 07:38 PM | #1 |
Zerk/Grease fittings in control arms
Does anyone have a diagram or photo showing which of the control arm grease nipples (or zerk fittings) are the 90-degree type and which are straight?
I remember that a couple of them at least are 90-degree ones in order to make lube jobs easier, but I didn't keep track of -which- ones are. Thanks! Dave
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
08-12-2012, 09:10 PM | #2 |
Re: Zerk/Grease fittings in control arms
Dave, A quick flip hrough the service manual is showing straight on he lower fwd and 90* on the other three. No telling how accurate that is, as manuals often reuse "close" pictures.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
08-12-2012, 09:43 PM | #3 |
According to the assembly manual... 1971 section:
Straight fittings at all 4 front positions. Right angle fittings at all 4 rear positions. Tops perpendicular to side of frame, pointing outward. Bottoms pointing down/vertical. Jim |
08-13-2012, 08:46 AM | #4 |
best way i know of is to get under truck with your grease gun and to see what will b servicable in your case
