![]() Join Date: Apr 2012
Door panel ?
I'm replacing my window regulator and figured I'd replace the few other parts in that area. I ordered a set of the Escutcheon in black. But from the diagram below. It goes on the outside of the panel.
When I removed my panel. They were installed from the inside out ![]() ![]() Why would they offer them in colors if you can't see them? It seems my panels are missing some cover /ring around the handles. The indentation is marked on the panel. I thought it was the Escutcheon I ordered. ![]() Posted via Mobile Device |
Re: Door panel ?
If you look at the numbers (7 or 8) it appears that they are both escutcheons, but one is for padded panels which only came in 72, according to that guide. Not sure if this is what you are talking about or not. Also, mine doesn't have those at all, but there is a serious gap between the handle and the door panel, so I imagine it goes in between there as opposed to behind the door panel.
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
Re: Door panel ?
number 8 is for steel panels mounted from the outside number 7 is for 72 the number 8 is also still available from gm
Fuzzy |
#4 | |
Re: Door panel ?
Actually no.. I just looked over the diagram more carefully and there is a # 7 for 67 and 72. notice there is a #7 for 67' then theres a list of # 8 with all the different colors and then theres another # 7 with 72'
Not sure if Im making sense.. Looks like the 67 and 72 use both 7 and 8. weird thing about 8 is it goes from the inside out yet they are color matched.. hopefully someone else that has done this can chime in.. Quote:
Re: Door panel ?
I don't think you can push the window crank on if you use "part 8" with a padded door panel. My 70 has padded panels & uses #7, my 69 has steel panels & uses #8's. Not sure if they left the factory that way, but's thats the way I got them.
Re: Door panel ?
Number 8 goes inbetween the handle and dooor panel with out it there you would have a big gap.
I also have number 7 on mine so that the handle spins smooth and does not grab on number 8. Posted via Mobile Device |
![]() Join Date: Feb 2011
Re: Door panel ?
I bought this from these guys. http://www.classicparts.com/1967-71-...ctinfo/18-045/ It pushes on from the outside. It has tabs on the inside that hook to the steel door panel. It looks like it might be #8
I'm sorry I called you stupid. I thought you knew already. 67 C-20 Custom Camper 68 Nova 396 it does wheelies 2005 Buick Century the one the wife drives 1989 Toyota Tercel to drive when I can't put gas in the first 2. Last edited by Daddy Brim; 08-21-2012 at 10:10 PM. |
#8 | |
Re: Door panel ?
This is exactly what my panel looks like. And those are the same pieces i have. I guess the PO installed those parts incorrectly and put them from the inside out making no sense. Hence the handles still wobbling all over causo g the extra wear on the splines on the regulator. I will get some pics up tomorrow.
![]() Join Date: Sep 2006
Re: Door panel ?
i had a 70 blazer with steel door panels it was original and the #8 was used
Re: Door panel ?
You also need part 7 in there as well other wise the clip that hold the handle inplace will drag/catch on part 8.
Re: Door panel ?
So 7 goes between 8 and the clip? Sorry if this seems dumb, but none of those were on my truck when I bought it haha
Re: Door panel ?
Mine has the door panel then number 8 then number 7 then the handle, number 7 protects number 8 from the clip and acts like a bushing as it spins with the handle where number 8 does not.
Re: Door panel ?
Hey 69, Thanks! I just got done redoing mine the way you said & it works fine. The ugly gaps I had are gone. Thanks again.
Re: Door panel ?
might be ordering some sets soon then. Thanks!
