09-12-2012, 10:38 PM | #51 |
Re: 72 BB AC/PS/Alt Brackets, Pulleys, Exhaust manifolds, Carbs, Shroud
How about $25 shipped on the 7042218 carb that is in pieces?
09-12-2012, 11:14 PM | #52 | |
Loves all GMC trucks
Sorry it will take at least 15 to ship it in a large FRB. I'll have to keep it for a future build. I will come down to $35 if your ok with it coming in a regular box and not a FRB. (I'm trying to come your way some) lol MIKE Posted via Mobile Device |
09-13-2012, 09:33 AM | #53 | |
09-13-2012, 09:50 AM | #54 |
09-13-2012, 01:30 PM | #55 |
Shipped! Tracking numbers added to PP for your item! should be there by Sat or Mondy at the latest.
Shipped! Tracking numbers added to PP for your item! should be there by Sat or Mondy at the latest. Mike |
09-13-2012, 11:34 PM | #56 |
Chance
Would you do $50 shipped on the 7042206 carb?
1968 Chevrolet Stepside BB 396 w/TH400 1972 Chevrolet 3/4 Ton 4x4 BB 496 w/TH400 |
09-14-2012, 12:51 AM | #57 |
09-14-2012, 08:37 AM | #58 |
Chance
Sounds good. If it is all complete with all the linkage and with all the choke linkage you got and deal.
09-14-2012, 09:42 AM | #59 | |
I brought it with me today to work in case you wanted it so I could box it up. If you PM me your phone number I can send some additional pic's. If youd rather me post them here Ill do that as well. Its kind of tough to load on base. Mike |
09-15-2012, 11:13 PM | #60 |
09-16-2012, 12:18 PM | #61 |
Dantip/all,
Pics of 2 sets of BB exhaust manifolds and BB heat stoves. Dont forget I have the heatshields on the first page of the post as well. Smog manifolds are both 3994045 Left and Right Non Smog Manifolds are 3994045 Left and 353030 Right V/R, Mike |
09-20-2012, 04:38 AM | #62 |
I tried to pm you but got a message that your mailbox is full
Do you happen to know if the pulleys and ps brackets for a 68-71 big block are the same as 72? The reason I ask is I have a complete set up including the alt brackets off a 70 truck but decided to install it in a 72 and want to use the correct 72 alt brackets. I wishihad decided before you sold the ones in the thread where I bought the oil peessureline vacuum hose and clams! Do you happen to have another set? Posted via Mobile Device |
09-20-2012, 06:59 AM | #63 | |
Sorry about my box being full. It's fixed now. As far as the brackets go... IIRC pulleys and ps are the same but the alt top bracket is different on the 72 from the rest. If you search the board for bb alt brackets you should be able to find the comparison from Duncan and sons. I may have the picture but I'm getting ready to leave for work. I'll look when I get to work if you don't find it. I do have another 72 bb truck I'll be parting this coming week and it has the alt bracket on it if you need it. Mike Posted via Mobile Device |
09-20-2012, 08:49 AM | #64 |
How much are the exhaust heat shields in the last picture?
09-20-2012, 09:35 AM | #65 |
09-20-2012, 01:56 PM | #66 | |
Keep me in mind on the 72 alt bracket (s) Posted via Mobile Device |
09-26-2012, 11:29 PM | #67 |
09-27-2012, 12:40 AM | #68 |
do you still have the power steering pump and brackets
and hoses.???????? |
09-27-2012, 07:05 AM | #69 |
10-04-2012, 03:26 PM | #70 |
Ttt
10-05-2012, 09:48 AM | #71 |
425hp409
I will take the best exhaust manifold heat shield.
Charles Posted via Mobile Device
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
10-05-2012, 03:35 PM | #72 |
10-11-2012, 09:53 PM | #73 |
TTT
Here's whats left so you dont have to go through the entire thread ! 72 gas pedal with 400 switch. $50 Vacuum Port for intake with 2 ports. $20 Shipped 2- Sets of BB Exhaust manifolds $120 shipped BB High Hump $80 Shipped Carb Spacer $25 Shipped 5-BB Heat Shields $25 Shipped BB Fan Shroud W/Clips $80 shipped BB Waterpump and crank pulleys $80 Shipped V/R, Mike Last edited by Cash3481; 11-13-2012 at 10:17 PM. |
10-22-2012, 10:18 AM | #74 |
Ttt
10-23-2012, 07:51 PM | #75 |
Ttt
