05-14-2012, 11:48 AM | #51 |
Re: 1969 Blazer...To be my daily driver
I haven't updated this in a while so here is where I am at now...
I have installed the carpet, the sound deadener, jute combo worked out great and even with the top off it is quite! I am very happy with the out come. I re-hung the doors temporarily and bought a nice set of Southern California rust free truck doors to convert in the coming months. I swapped out the ignition, heater control and cig lighter (need to charge the phone), mirror and door panel/handles. I also cut the free double wall top up and took the front for the roll bar bimini top (so no drilling the windshield). The top is actually being made today so I will post some pics of that soon. I used window/door foam inside and bondo to fill (fiberglass would have been better but time and experience with it prevented it). Next up, I need to swap out the hood hinges, install rear side panels and the ORD zero rate leafs to correct this: |
05-14-2012, 12:55 PM | #52 |
Looks good Dustin!
Just an FYI, I used zero rates on my 4" lift also, but you may have to have the driveline extended when you do it. Mine moved about 2" further out of the slip joint. I still drive it some, but I really need to get the driveline lengthened soon. I think the lift companies locate the leaf spring pin so that you don't change the driveline length much. Although you will be a lot happier with the wheel centered with the zero rates. I know I was. Keep up the good work! |
05-14-2012, 01:42 PM | #53 |
Thanks 29od1!
The Blazer had the stock leafs and a 4" block when I bought it (so about 5.5"-6") and it had a driveline vibration when coming to a stop. I will have to see how it does with the additional 1". Did you leave the shims on the leafs packs or remove them? Mine are very thin and am planning on leaving them on. I have been going back and forth that if I need to lengthen the drive shaft that I may just drop down to a 2.5" or 3" lift as that is what I would have put on it if it were stock... decisions decisions. |
05-14-2012, 01:59 PM | #54 |
When I put the zero rates on, I left the tapered shim in. Mine was a skyjacker lift and I haven't noticed any vibration issues with it after about 500 miles.
05-14-2012, 09:52 PM | #55 |
So I picked up the Blazer a few minutes ago and am very happy with the soft top that Orange Auto upholstery made for me. It is a canvas much like an outdoor umbrella, I only got up to about 45 mph on the way home, but there was no flapping in the wind, it cut the wind down significantly also.
The only thing that I think would make it look better is if the snap buttons were screwed into the windshield, but that's not going to happen. |
05-14-2012, 11:12 PM | #56 |
GEARHEAD
I like how they made those flaps to wrap around the bars. Good idea there. Looking real nice overall.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
05-15-2012, 09:18 AM | #57 |
I agree I think it looks really good. I like the functionality of being able to unbolt the front and not putting screws into the windshield frame.
Now get the wife and kiddos into that thing and drive it! |
05-15-2012, 09:57 AM | #58 |
Thanks guys. My boys, 1 and 3 years old, love it... it's Dadda's MONSTER Truck, lol.
My wife has cursed this Blazer since the day I decided to pull the motor (day 2), after going for her first ride the other day I swear I saw a smile and think she is coming around Last edited by DustinU; 05-15-2012 at 11:52 AM. |
05-19-2012, 02:24 AM | #59 |
I just finished the ORD zero rate leaf spring install, it was pretty simple and fast. I used the 1.5" option and the wheel sits much better in the wheel well. No more saggy butt now either, I didn't mind it actually kinda liked it but who can complain about a truck sitting level. I will take some pictures this weekend...not in the driveway
New side markers were also installed. I installed an alarm with a proximity sensor yesterday. It doesn't go off until you stick your arm in the cab. Between this, the cable lock and car seats it will take at least a couple minutes to steal the rear seats while the horn is blaring. Still to do sooner than later: Fix gas gauge (3 o'clock problem) Tach hook up ampmeter troubleshoot hood hinges Tilt column Steering wheel (this 13" wheel is driving me crazy) Side panels Differential and trans fluid change Cargo box for rear Down the road; Cut truck doors down align body, doors and hood. hard top restore rocker panels and torsion boxes Amp and speakers |
05-26-2012, 12:05 AM | #60 |
Ok I said no more driveway shots but I was too busy driving!
Before and after of the ORD zero rate moved back 1.5" and the truck sits level. |
05-26-2012, 12:13 AM | #61 |
By installing the zero rates it stretched my drive shaft out further than I liked (3 1/4" compression left and only 3/4" extension). I used a longer drive shaft slip yoke (longer by 1 3/8") and it put everything back to normal with 2" extension and compression available for the shaft. The longer slip yoke was cheaper than lengthening the shaft. Hind sight, I bought the yoke first, when I went to get the u joints pressed the shaft was dented and bent so it was replaced anyway and could of just been lengthened. I had no felt vibrations from the drive shaft previously.
Before: After: Last edited by DustinU; 05-26-2012 at 12:18 AM. |
05-26-2012, 07:20 PM | #62 | |
Make a custom soft top windshield frame bracket for a more cleaner slick look.. just get some snaps from a boat place or upholstery place. http://coloradok5.com/forums/showthr...=256502&page=6 |
05-27-2012, 01:41 AM | #63 | |
See it here if you haven't already: http://67-72chevytrucks.com/vboard/s...8&goto=newpost If I used that fiberglass top mold, I would get softtoppers snap bar so I could use my "bimini" and/or a soft top. Thanks for another great idea though! |
05-27-2012, 02:14 AM | #64 |
Man thats clean looking! It would look good on your ride!
How do you like driving the old girl for a daily driver? |
05-29-2012, 03:20 AM | #65 |
How do you like those front seats? Anything you would have different? Do they adjust back forth at all? I'm lookin at buying a pair of the same seats on CL, so I just gotta know if this is the way to go and install shoulder belts or go with the front seat 2000-2003 style with integrated seatbelts. Thanks! And great looking Blaze!
05-29-2012, 11:49 AM | #66 | |
I used the plastic "sleeve" for the receiver Plenty of room to get in the back: Oh and I installed a different NP205 shifter and knob... finally |
05-29-2012, 01:37 PM | #67 |
nice soft top and roll cage
Chuck |
05-30-2012, 10:56 PM | #68 |
05-31-2012, 07:49 AM | #69 |
That first picture is what it's all about! That's the reason we got our Blazer, nothing else like it.
10-05-2012, 02:57 AM | #70 |
this thing is radd!! what lift do you have in the front??
10-05-2012, 03:00 AM | #71 |
i stay in orange as well, just bought a pair of superlift leafs for my front end, installed it like 3 hours ago.. i dont know if i like it yet.
10-05-2012, 12:41 PM | #72 |
I love that cage, any more info on it? Where did you get it built and if you dont mind what did it run you?
72' CST K5 Blazer |
10-05-2012, 07:05 PM | #73 | |
The cage was built by Steve at Roughneck Offroad in Wildomar, CA he did a great job on it and is a good guy. I left my Blazer with him for a week and he bent it up, I know metal and overhead increase/change over time but I think I paid just under 2K (Too scared to look at the receipt folder, lol). It is not mounted to the frame, but I used grade 8 bolts and large heavy gauge steel plates under all the seats and roll cage mounting locations. |
10-05-2012, 07:22 PM | #74 | |
Post up some pics of your ride, maybe I'll see ya around town. |
02-04-2013, 02:11 PM | #75 |
How much fat mat and jute did you order to cover your hole rig? Im getting ready to do my interior, and fat mat is a way better price then dynamat. Did fat mat work good for you?
