View Poll Results: best tranny
th350 3 60.00%
th200 1 20.00%
th400 2 40.00%
muncie 4 speed 2 40.00%
muncie 5 speed 1 20.00%
power glide 1 20.00%
Multiple Choice Poll. Voters: 5. You may not vote on this poll
Old 10-22-2012, 04:00 PM   #1
lukes63chev
tranny problems and questions
i have a 1963 c10 with a 283 sbc and right now i have a granny gear 4 speed, in it and the tranny is out but bellhousing is still in. how do i take out the clutch and flywheel with out damaging both of them.
also i have a turbo 350 that im going to bolt up to the 283. what i wanted to know is , ive heard about to two click think with the torgue converter. i just want to know if that is true or not and if theres any advice about both i would be very greatful
thanks lukes63chev
lukes63chev is offline   Reply With Quote
Old 10-22-2012, 04:33 PM   #2
ChuckW
ChuckW's Avatar
Re: tranny problems and questions
You'll need to block the rear of the engine. Then remove the Bell and rear mounts. I have the same combo. So far as I know this is the easiest way. Suppose you could try removing by taking the lower cover off (flywheeh) then turn the engine by hand to access the bolts.... That seem pretty labor intensive.... Good luck.
I'm not an automatic guy so can't help you there... C
ChuckW is offline   Reply With Quote
Old 10-23-2012, 10:52 AM   #3
Rich 5150 69
Rich 5150 69's Avatar
thanks lukes63chev
Just start unbolting the pressure plate then flywheel, should not be an issue, before you install auto, slip torgue converter on to trany, rotate it while lightly pushing into trans, you`ll feel the torque converter lock into place, then raise the whole package into place at once, be careful not to let it slide forward on splines and loose its position, bolt trans bell housing into place lightly, then by rotating engine with a prybar against the flexplate to install converter/flexplate bolts ( use a new flexplate they are cheap insurance ) then go back and tighten all bellhousing bolts. Note: flexplate only goes on one way, they are marked as such...!
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 10-23-2012, 11:21 AM   #4
padresag
I don't see why you can't tighten up the bellhousing bolts right away. that way one does not forget. the torque convertor does have room to move forward and rotate freely. if it doesn't there is something wrong.
remember that you have to remove that crossmember
ron
padresag is offline   Reply With Quote
Old 10-23-2012, 11:28 AM   #5
Rich 5150 69
ron
Just ensuring that he does to make it easier...
c10, chevy, th350 installion, tranny question
