Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 11-26-2012, 03:02 AM   #1
stocker96
stocker96's Avatar
tricks for removing paint swirl and light scratches
What do some of you guys use to remove paint swirl and or light scratches. my truck looks awful in the sun because of them It's also sometimes called "spiderwebbing" any trick, proceedures or product recommendations much welcomed.
stocker96 is offline   Reply With Quote
Old 11-26-2012, 06:07 AM   #2
bk2life
Re: tricks for removing paint swirl and light scratches
waxing helps alot.
and if you havent had it buffed in a while, get it buffed. compound to clean it up, finesse then some swirl remover..
then wax again.
bk2life is offline   Reply With Quote
Old 11-26-2012, 10:52 PM   #3
stocker96
stocker96's Avatar
I don't think the truck's been buffed since 2000. just been waxed alot. I'm thinking that alot of the swirls have come from that.
Old 11-27-2012, 03:18 AM   #4
A.Bursell
I always start milder and work towards more aggressive if needed. That means start with a polish, it may just need to be cleaned up. Then go to a compound if it's not showing signs of improvement. Are you doing this by hand or with a machine? Machine makes for a much nicer (and faster!) finish. The swirls probably are from washing, or if from waxing then from the material you used to wax and buff. If that's the case, I would think a mild polish would be all that you need.
Adam
A.Bursell is offline   Reply With Quote
Old 11-27-2012, 03:20 PM   #5
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I would use an electric buffer (beware buffing through the clear coat or paint) to remove the swirls. You can use different compounds some of which are more abrasive than others to give you a good base to work from.
Check out this:
http://67-72chevytrucks.com/vboard/s...d.php?t=533527
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 11-27-2012, 03:31 PM   #6
LEEVON
LEEVON's Avatar
Check out autogeek.net (no affiliation). They have some great tutorials, there is a forum also I think. I have a PorterCable 7424 dual action polisher, which is pretty much the detailer's standard. To remove swirls, depending on how bad and what color and type of paint I start with a wash and a claybar rub. Then work the paint with a heavy or medium swirl remover on an agressive pad. I might step up to a lighter swirl remover, then a polish, then a glaze or sealant. It's not cheap or easy to do it the right way, but rewarding. It takes me the better part of a weekend to do a whole car like this, which is why I don't do it often. On my '71 which gets driven hard and put away wet, every couple of years I'll just do the hood and maybe the tops of the fenders where the reflections are seen.
Bottom line is that you actually have to cut the clear coat (or paint if single stage). Filler type waxes don't work. Also, some people may be able to make those furry pad rotarty buffers work, but in my opinion they do more harm than good. The worst spiderwebs I've seen come from dealerships or detail shops who do those on a quick "detail".
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 11-27-2012, 09:20 PM   #7
stocker96
stocker96's Avatar
Yeah, I only hand wax, but these swirls are getting hard to ignore.
Old 12-01-2012, 06:45 PM   #8
big mike71
big mike71's Avatar
Try 3M machine polish, #05996, it's what my paint shop said to use and it good for me. It's $40.00 for a quart, but it goes along ways.
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline   Reply With Quote
Old 12-02-2012, 04:02 AM   #9
stocker96
stocker96's Avatar
I'll check that out thanks Big Mike.
Old 12-11-2012, 02:47 PM   #10
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
pay the 150 bucks have it done by pro detailer or repaint the truck
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
