Old 12-11-2012, 03:33 PM   #51
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
now for the problem areas...
Problem number one. Little Roof rust.. this is the only spot on the roof. Not sure if I should try to fill in with my mig, or cut a peice out from another cab I have.
Jimmy
.69SWB Build.
~Whitey~ is offline   Reply With Quote
Old 12-11-2012, 03:36 PM   #52
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Problem #2 -- little bit of floor needs replaced. It looks like someone just welded over rust. I'll fix that.
Jimmy
.69SWB Build.
Old 12-11-2012, 03:41 PM   #53
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Problem #3 -- big problem... there was A LOT of bondo in the pillar. I'm not sure how to go about fixing this, except by cutting out the pillars from my other cab and using them. I do not want to fill it all back in with bondo. Also the the floor in this can has been replaced as well as the cab corners and the PO did not align it right.. both cab corners flare out on the back wall of cab... It is something that my OCD won't allow, so I must fix this.
Also attached is a pic of the CAB i will be cutting sections from. Though it doesn't have any bondo in it.. it is not as solid as this one. Floor is gone, cab supports are gone and the top has a slight bend in it... But I believe I can get what I want from it and not have to use a scud of bondo to cover up damage.
Jimmy
.69SWB Build.
Old 12-11-2012, 03:42 PM   #54
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
I'm sure my neighbors love me for the junk I drag up and park at times.
Jimmy
.69SWB Build.
Old 12-11-2012, 03:53 PM   #55
thesledhead
thesledhead's Avatar
Re: Project 69SWB
very nice!!! it looks like deja vu!
thesledhead is offline   Reply With Quote
Old 12-11-2012, 04:03 PM   #56
Chev71
Chev71's Avatar
Re: Project 69SWB
Haha same here man, neighbors called the city on me, I had a ticket on my front windshield after 2days. Good progress... Mines at sandblasting shop rite now I hope I don't need a donor cab lol
Chev71 is offline   Reply With Quote
Old 12-11-2012, 04:31 PM   #57
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Thanks... I get deja vu everytime I look around on this site. :-)
I hope you don't either...
What's the best tool to use to cut sections out of the other cab. I have a 4 1/2 angle grinder, a 3in cut off wheel, and a reciprocating saw? (Which I think is way to big for this kind of delicate cutting.) from past experience if I try to use these tools for this job.. It's gonna get ugly.
Jimmy
.69SWB Build.
Old 12-11-2012, 04:59 PM   #58
Xeen
Xeen's Avatar
Re: Project 69SWB
Holy smokes that is alot of damage on the back corner of the cab, you might be able to use various hand dollies and a hammer and get some of it pretty straight, but it might be easier to cut other parts of it out and replace it.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 12-11-2012, 05:01 PM   #59
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Oh I definitely plan to cut and replace. I want to put as little bondo back in this as possible... That was the problem with the paint in the first place. The person who did the work before just laid the bondo too thick and it cracked.
Jimmy
.69SWB Build.
Old 12-11-2012, 05:32 PM   #60
RWB-713
RWB-713's Avatar
Re: Project 69SWB
Your build brings back alot of memories of the last couple years for me! I went through alot of the same process as far as clean up & prep & rebuild on the frame & suspension, talk about time consuming, definately ALOT of work!
I wish i would have had the awareness to take pictures and document all that work, sure would be nice to have them on my build thread if nothing else
I have a soft spot for lime green & black, and that's probably an understatement, lol. You have a great build going on here and it seems like you are making great progress, I'm really close to the same stage wit my '67 as you are now, and I've had that truck torn apart for several years now, I seem to have found a sudden super interest in it again tho, thanks to a good buddy of mine who has a build very near completion ( Portmod7 ), and many of you guys here on this forum have furthered that inspiration in the last couple of days. So hopefully. I'll be making progress and be back on track here pretty quickly!
For most of my sheetmetal cutting on my cab we used a combonation of a 3" cutoff wheel on a die grinder, an airsaw (basically an air operated jigsaw), and a die grinder with a small (2") 36 grit grinding disc. Use the cutoff wheel and the airsaw to make the inital cuts, and leave just enough left to go back with the 36 grit and fine tune the line until it's where it needs to be so you can start working with your patch panel. It's a painful, tedious task at best, and it's my least favorite part of a build by FAR. (probably why my build has taken so many haults over the last couple years ). My biggest advice is to plan two steps ahead in every area, and measure 4 times & cut once, otherwise you find yourself going farther and farther into good metal, and it gets old REAL fast. Seems like you have a good amount of patience tho, take your time, don't get discouraged, and it'll all come together nicley in the end!
Definately subscribed! I'll pitch in any advice from past experiences I can, if nothing else, I can sure give lots of "what not to do" examples
" I strive for a level of perfection that I do not possess the skillset to achieve. "
Ariel <> '67 C10 Shorty Stepside *** Build On Hold ***
First Ride <> '81 C10 Long Fleet *** Current Project ***
RWB-713 is offline   Reply With Quote
Old 12-11-2012, 10:54 PM   #61
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Thanks a bunch.. That's all great advice and I put it to use this evening. I just took my time, cut slow, used the 3" cutoff and an orbital jigsaw and it all cut pretty good. I will need to go back with the die grinder like you said and clean up my line. Will post some pics in a few... I found some more work under all that ugly on the pillar.
Jimmy
.69SWB Build.
Old 12-11-2012, 11:01 PM   #62
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
I figured if start on the worst part so hopefully this gets easier as I go. :-)l
On my phone right now and I can only upload 1 pic per post.
Jimmy
.69SWB Build.
Old 12-11-2012, 11:03 PM   #63
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Bad section cut out, but still need to clean up the line.
Jimmy
.69SWB Build.
Old 12-11-2012, 11:06 PM   #64
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Looks like more work, but not too bad really. It'll give me a chance to remove the rockers and cleanup any rust underneath.
When I repair the bottom of that pillar I imagine I should support it before I go cutting on it.
Jimmy
.69SWB Build.
Old 12-12-2012, 03:40 AM   #65
Xeen
Xeen's Avatar
Re: Project 69SWB
Wow man you have no fear, thats a big job right there.
No Guts no Glory right?
Old 12-12-2012, 10:50 AM   #66
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
LMAO! Well it's not going to get done if I don't dive in and do it. hahaha
Jimmy
.69SWB Build.
Old 12-12-2012, 11:41 AM   #67
RWB-713
RWB-713's Avatar
Re: Project 69SWB
Yeah, the cab floor & cab supports right there are notorious for always having cancer too, definately had to cut that out on mine as well. I didn't quit have to go as far up the cab as you did tho.
Supporting that corner definately is a good saftey measure considering how far up the cabside you had to go, i didn't support mine, but there's still alot of structural stability left in it.
Good work so far!
Old 12-12-2012, 12:08 PM   #68
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Good work so far!
Thanks RWB-713. I'm gonna try to get all this metal work done as quick as I can so I can get some epoxy primer on it.
Question?: Should I epoxy prime after the metal work and before any body work? Or do my body work on the bare metal then epoxy prime afterwards?
Jimmy
.69SWB Build.
Old 12-12-2012, 12:17 PM   #69
RWB-713
RWB-713's Avatar
Re: Project 69SWB
I'm doing all my body work on the bare metal and using guide coat primer in the spots i'm workin on. After all the work is done, I'll go back and epoxy prime the whole cab. I'd think epoxy priming the whole thing now would just cause you more work in the long run.
I'm not 100% that i'm doing it the "right way", but I've also learned that everyone approaches body work differently. I have a buddy who runs a body shop up here that basically does collision repair only (he's definitly helped me out alot), and their approach sometimes varies from someone who specializes in shaving, filling, & other custom work. Both usually seem to turn out just fine in my experiences. I think it's a "to each their own" scenario really, as body work is one of those things I'll add to my list of "Black Arts".
Old 12-12-2012, 12:29 PM   #70
67cheby
67cheby
67cheby's Avatar
Re: Project 69SWB
great progress !
67cheby is offline   Reply With Quote
Old 12-12-2012, 01:33 PM   #71
Xeen
Xeen's Avatar
Re: Project 69SWB
In my opinion you should always epoxy bare metal ASAP after it has been cleaned so it doesnt rust at all while you are working on it, and you should spot epoxy any areas you are working on at the end of each day.
Old 12-12-2012, 02:15 PM   #72
RWB-713
RWB-713's Avatar
Re: Project 69SWB
That's not a bad statement by any means. Better safe than sorry is a time tested statement. I think your working & storage area may be something to think about too. Half my cab has been exposed bare metal for years, and there's not a sign of (new) rust at all, not even "wipe off" surface rust. My cab has also always been inside a very dry shop building the entire time tho.
Old 12-12-2012, 02:21 PM   #73
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
I know epoxy is like concrete and really hard to sand after it cures. From what I understand there is at most a 7day window after you spray it to add anything on top of it without have to scuff it. That's one of the reasons I am not wanting to do it just yet.. It's going to take me longer than that to finish this metal work with only being able to work on it an hour pr two here and there... If I start seeing surface rust I guess I'll speed things up or just go ahead with the epoxy.
Originally Posted by 67cheby View Post
great progress !
Thank ya sir.
I've heard that from several people and it makes sense. I would definitely do this if I was able to get everything done in a few days so as not to have to go back over the epoxy and rough it up... For now I'm gonna take my chances but will keep an eye out for surface rust forming and if it does I'll just go ahead and lay down a coat of epoxy.
Thanks for the input fellas.
Jimmy
.69SWB Build.
Old 12-12-2012, 02:30 PM   #74
Xeen
Xeen's Avatar
Re: Project 69SWB
Heres a pro tip for you.
Epoxy and darn near anything else is no match for an 4-1/2" Polycarbonite disk on a 11,000 RPM side angle grinder.
You can pick up these disks for a reasonable price at harbor freight, they hold up really well and are my favorite sanding medium by far.
Old 12-12-2012, 02:46 PM   #75
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Thanks for the tip. I've got the angle grinder and several different grits of flap disc.. but I DO NOT want to go over the entire cab with them. :-) My garage is pretty dry... So I'm hoping I'll be fine... after I spray the epoxy all I want to do is lay build primer on top of it.
Jimmy
.69SWB Build.
1969, black, custom 10, fleetside, shortbed
