03-30-2012, 11:27 PM | #51 |
Re: Original Bucket seats installation????
I just assumed the front mounting points see the most stress because of the lever arm being the longest on the top back of the seat. Amplifies with mild acceleration. But braking reduces the load, without the added leverage on the rear braces. And side loads would be negligible I'd think. I'm gonna install a set of these seats someday, would like to horde away a set of braces along with my console!!! I'm really glad you posted this mcbassin - like I said in one of the early posts - I just thought buckets used the same holes as a bench and I didn't even know there WAS bracing for buckets that benches didn't get. Duh.
04-14-2012, 02:55 PM | #52 |
Sent sameyrasmea72 a PM to see if these brackets are almost ready to ship....
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
04-17-2012, 04:19 PM | #53 |
subscribed
04-17-2012, 10:52 PM | #54 |
Great post. I had no idea they were that different. I am just finishing putting a set of Recaros out a Benz in mine - waaaaayyyyy more work than I ever imagined.
05-22-2012, 08:07 PM | #55 |
Are these reproduction brackets mentioned earlier #48 still a possibility anybody? My PM was never responded too. Seemed the best way to go because they use the existing floor support.
I also really like Mike's install method as it is also one of the best I have seen from my forum research. Really appreciate you posting yours Mike.
05-22-2012, 11:21 PM | #56 | |
Still Learning
05-23-2012, 12:15 AM | #57 |
btw mcbassin - i finally read your build thread for the first time - awesome write up. can't wait to see her all painted up soon. sorry bout the seam sealer! I'd have kicked the dog over that one....
05-29-2012, 11:15 AM | #58 |
Still Learning
Thanks Jocko, no big deal on the seam sealer it's water under bridge now. It did force me into a long weekend off of it though. Just a step back to not get burn out is nice.
06-13-2012, 07:58 AM | #59 |
This is a great thread and I wanted to add these two illustrations as further points of reference.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
06-13-2012, 08:28 AM | #60 |
Still Learning
Great illustrations Tim! thanks for adding them.
06-13-2012, 04:25 PM | #61 |
06-13-2012, 09:24 PM | #62 |
YESSSSS! I've been lookin for that picture! Thanks Tim.
07-22-2012, 09:20 AM | #63 |
subscribed,,,definitely a knowledge builder post!
07-22-2012, 12:23 PM | #64 |
07-22-2012, 03:23 PM | #65 |
Active Member
subscribed
I needed this Calvin |
07-22-2012, 10:05 PM | #66 |
Great info.subscribed !
84 step side 87 swb |
08-19-2012, 12:11 AM | #67 |
Before I send PM's I thought I'd just ask here...
68 TT - did you finalize an idea you'd like to share on an easier approach to fabricating an under floor bracing bar? Duncan & Sons - Did you ever get additional brackets made for resale to us? FWIW - by centering my driver bucket with the steering wheel then measuring for equal distancing from console dimples I came up with the same as I found here - Existing outside front holes for bench seat are key starting references for fitting factory bucket brackets in bench seat trucks: 3/4 to 1" to right of driver outside front hole is good placement and existing passenger outside front hole was good as it stands. All other holes must be drilled after squaring tracks/brackets and marking. Not sure but the passenger seat center may have lined up with the glove box latch... |
08-20-2012, 04:54 PM | #68 |
Moderator
Great thread! To add to Tim's illustrations above, here are two more showing the attachment of the factory shoulder belt retainers that mount to the front of the console, if your truck came optioned with both bucket seats and shoulder belts.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
08-20-2012, 07:07 PM | #69 |
Very cool Leddzepp, I am adding this option to my truck and had no idea about the buckle retainers on the console. I had something very similiar in a 1966 Impala SS I restored not sure if it was correct but I liked them. Do these brackets ever surface on the forum?
Thanks,
01-06-2013, 01:37 AM | #70 |
Any new info if Duncan and Son is making these underfloor brackets?
Jeff 1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt 1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior |
01-06-2013, 01:56 AM | #71 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=557195
01-06-2013, 09:43 AM | #72 | |
Can someone with buckets in a truck please measure center to center the distance shown in this picture. Or maybe Koop can answer how far he moved his over. Thank you. Last edited by 29od1; 01-06-2013 at 03:41 PM. |
01-06-2013, 12:39 PM | #73 |
(007) aka Houdini
Subscribing........This is great info!
Live life one day at a time! |
01-06-2013, 01:27 PM | #74 |
Originally Posted by Duncan and son
Hey Trevor, we have made some of those and they came out very correct even down to the square nuts. We only made a few to test quality etc. Do not have any now but will have more made. Always appreciate you Paul I would like to get a set of these braces from you also .. what are you asking for the set before postage ,, thx
When you learn a thing a day you store up smart. |
01-06-2013, 09:07 PM | #75 |
Subscribing...... Handy info to have around. I'll need this shortly.
octane 1971 C10 Cheyenne - Project Truck 1971 C10 Super Cheyenne - Driver |
