Old 01-13-2013, 07:58 PM   #76
texastruckjunky
texastruckjunky's Avatar
Re: The Hillbilly Deluxe dually build
Originally Posted by Can't kech me View Post
hey if tx firefighter doesn't want it i do! do you have a pic of it so i can make sure it's what i'm thinking it is?
Here's a picture of the grill.
Life is to short to drive anything else
texastruckjunky is offline   Reply With Quote
Old 01-14-2013, 07:03 PM   #77
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Had to make a run to town today. After driving it to town and back, I am feeling that something has got to give. 4.56 gears and non overdrive is not ideal for my usage. I was in high gear well under 30 miles per hour. I have an extra, very nice, complete 14 bolt cab and chassis 4.10 rearend under my workbench. I could put into it, but I might even be feeling 3.73s more than that. I hate to go to too much trouble and expense to swap from 4.56 to 4.10 and it still not be enough change. I need to do the math I guess to figure out my revs.
Tx Firefighter is offline   Reply With Quote
Old 01-14-2013, 11:07 PM   #78
spudz
spudz's Avatar
I got 410s in my 79 c30.... and its screaming at 55-60. I feel the only way to make one of these traffic friendly is to stick a nv4500 or 4l80 trans.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 01-15-2013, 12:08 AM   #79
Zane M
Great truck, and I love reading about your attention to detail.
Also, thanks for showing what you have done, it will come in handy during my current resto/mod.
My input on the gears: I have a different set up(350/Turbo 400/4:10 gears/265/75/16 tires). I'm turning 3000 RPM at 65MPH. I know it is an Apple to Tangerine comparison, but at least it gives you something to compare to as you contemplate your gear selection.
Zane M is offline   Reply With Quote
Old 01-15-2013, 12:39 AM   #80
Cheng
Junior Member
I really enjoy following your work. It is great stuff, very similar to what i am trying to do, but i struggle on the cosmetic details.
I am using the below link to check engine rpm with different gear ratios or hoping i will find an NV4500 for a good price.
I find it easier than running the numbers by hand each time.
http://www.bgsoflex.com/rpmmph.html
If it wasn't for the last minute, nothing would ever get done.
1953 3800 - SRW C&C Dump - 216/SM420
1985 K30 Scottsdale - SRW - 6.2/SM465/NP205 (Sold)
Cheng is offline   Reply With Quote
Old 01-15-2013, 12:47 AM   #81
bigblock73
yeller
bigblock73's Avatar
Great build Kevin, one of my favorites...keep the info coming!
bigblock73 is offline   Reply With Quote
Old 01-15-2013, 07:42 AM   #82
lolife99
67-72 parts collector,…
lolife99's Avatar
Definitely go to the 3.73's!
Those 4.10 still scream,... unless you drive 55 mph everywhere you go.
Keith
Convert to disc brakes.
Old 01-15-2013, 08:53 AM   #83
ryanroo
ryanroo's Avatar
4.10s really work well with the NV. if that is even an idea you are considering, i would do that. if not, you probably will be best off with 3.73s. if you will be pulling trailers much at all, i would really consider the NV route with 4.10s
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 01-15-2013, 09:29 AM   #84
Tx Firefighter
I appreciate the nice comments from all of you fellas.
As far as the NV4500 thing goes. I'm not leaning that way simply due to the cost. The NV4500 is in such demand lately that the prices are being held pretty high. I could do gears for significantly cheaper than the OD swap. Plus, the SM465 that I have now is my favorite transmission. Can't anyone say they aren't strong and reliable.
I suspect I'll wind up dragging the 4.10 rearend out from under the workbench and tune it up. I could do that pretty cheaply and it would certainly help drop my revs at cruising speed.
Old 01-15-2013, 09:31 AM   #85
Tx Firefighter
Thank you for that link. I just ran the numbers and going from 4.56 to 4.10 will drop my revs by 300 at 60 miles per hour.
Old 01-15-2013, 12:41 PM   #86
aggie91
I'm just glad to be here!
aggie91's Avatar
Sent you a PM about the 14 bolt...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-21-2013, 07:36 PM   #87
Tx Firefighter
Slow progress here lately. My wife drug me to Mexico for some stupid sit on the beach crap. After I finally got that horsesh1t out of the way, I could come home and work on trucks again.
Today I started to get the bellhousing ready to install.
Of course, it started off like all of them, greasy and nasty. That took a bit of scrubbing to get it clean.
The Advance Adapter bracket interferes with the threaded bung where the factory linkage pivot ball screws in to. I had to grind that back some to get the clearance for the bolt holes to line up.
Then to glass bead blast it and powdercoat. I used this neat powder that makes it look like freshly blasted aluminum, which is quite handy for old stained aluminum castings.
Close up of where I had to grind and sand to get the clearance for the AA bracket.
Then to double check all of the bolt holes with a tap and screw the pivot ball into place with loctite. New grade 8 bolts for the trans and bell housing mounting too.
Old 01-22-2013, 07:31 AM   #88
squaredaway
squaredaway's Avatar
Great work! I love the attention to detail!
1987 Silverado
6.0/4L80E
5/7 Drop, 20x8.5(245/45)/20x10(295/45) Coy C5s
squaredaway is offline   Reply With Quote
Old 01-23-2013, 12:01 AM   #89
Greenlee
Greenlee's Avatar
Wow, looks like new!
Greenlee is offline   Reply With Quote
Old 01-23-2013, 12:56 AM   #90
Black 'n' Blue
Black 'n' Blue's Avatar
My truck has 3:73 gears and with 4,500lbs on the back it'll idle along at 1600 doing 80MPH.
-Justin.
The past cannot be edited, or erased. Only accepted.
Loud, proud and country by the grace of god!
Bradley Anderson 1997-2011
Black 'n' Blue is offline   Reply With Quote
Old 01-23-2013, 09:51 AM   #91
881ton
881ton's Avatar
Nice work! I like your attention to detail. Powdercoating looks awesome!
ROB
881ton is offline   Reply With Quote
Old 01-23-2013, 09:19 PM   #92
Tx Firefighter
Short update for today. I spent most of the day powdercoating some wheels for a fellow who is building a neat 53 Ford F100. Since I had the gun loaded with gloss black and the shop was already dirty, I decided to work a little personal project into the workflow.
The bellhousing came with a clutch lever which I'm hoping to use when I swap the bellhousing. But, it needed some real help before I'd be ready to use it.
Notice the giant grooves worn into the ears there....
The grooves were worn so deep that the ears had bent under the pressure since the material was ground so thin.
First step is to straighten the bent ears. Out comes the Crescent wrench and the bench vice.
Then weld up the worn areas and sand smooth with a flap wheel.
Now, remember I said I already had the gun loaded with black powder ? An extra part hanging in the oven never hurt anything so...
One more part ready to go. One piece at a time. Hopefully when the time comes, I'll have all my ducks in a row.
I'm kind of dragging my feet on the bellhousing R&R. I'm going to do a lot of interior work at the same time (reason why will become obvious when I get to that point) so I have a lot of stuff to round up and decisions to make.
Old 01-23-2013, 09:27 PM   #93
Wrecked1982
Wrecked1982's Avatar
thats such a nice thing the advance adapter bracket !
Wrecked1982 is offline   Reply With Quote
Old 01-24-2013, 10:01 AM   #94
aggie91
aggie91's Avatar
Your powder work is better than the "pro" shops around here. Awsome job!
Karl
The LST Challenge:
Old 01-24-2013, 10:10 AM   #95
Tx Firefighter
I appreciate the comment Karl. I put my work up against anyone, but I just hate being a business man so I prefer to just not do much of it.
Old 01-24-2013, 10:54 AM   #96
aggie91
aggie91's Avatar
That all looks great. At least you got the "RIGHT" side of that Honda Trail bike the "RIGHT" school!
Karl
The LST Challenge:
Old 01-24-2013, 11:08 AM   #97
UPNADM
UPNADM's Avatar
Those parts look fantastic... job well done!
UPNADM is offline   Reply With Quote
Old 01-24-2013, 09:38 PM   #98
Greenlee
Greenlee's Avatar
Wow, that looks awesome! I have an old Honda Passport scooter I should bring up there for powder coating. It's got sort of a patina look going on right now.
Old 01-31-2013, 04:03 PM   #99
Tx Firefighter
Little update...
I'm sick as a dog. I'm lucky enough to have both type B flu and strep throat at the same time. So, the doctor has me on absolute bed rest. Fortunately, my wife is gone to work and the UPS delivery came today so I was able to cheat for a few minutes without anyone knowing. I hope you guys won't tell on me.
They are the cheap priced Summit brand ones, but the stickers on the backs are Phoenix brand which are the expensive name brand ones.
The sickness is catching up to me though and I didn't have enough energy to put any Armor-All on the tires.
Old 01-31-2013, 08:08 PM   #100
hgs_notes
GEARHEAD
hgs_notes's Avatar
Won't the wife notice the new bling and question you about how they got there? Take care man. Looks good.
On another note, the "expensive name brand" ones are made in China?
hgs_notes is offline   Reply With Quote
