Old 01-24-2013, 06:06 PM   #1
thump16
thump16's Avatar
in tank fuel line
Do i need to use fuel injection hose in the tank with the ep381 fuel pump or do i need to replace it with fuel injection hose?
thump16 is offline   Reply With Quote
Old 01-25-2013, 03:34 AM   #2
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: in tank fuel line
There is a hose specifically rated to be submerged in the fuel tank... the wrong type of hose will start to break down immediately...
Rich
1972 K5 Blazer CST Click HERE
Old 01-25-2013, 10:09 PM   #3
69sinker
69sinker's Avatar
Thumbs down Re: in tank fuel line
I'll let you know how long it takes to break down, unfortunetly I was mislead and replaced mine with 3/8 fi hose 3 days ago.
My 69 cst lwb 2wd LS1 swap 5.7/4L60e build
http://67-72chevytrucks.com/vboard/s...d.php?t=589869
69sinker is offline   Reply With Quote
Old 01-28-2013, 12:29 PM   #4
69sinker
69sinker's Avatar
Fuel injection hose lasted only 7 days! Just ordered the right type of submersible hose (gates), $26.00 a foot. Wish I had seen this thread before I installed it, wouldn,t have to pull the bed again.
Old 01-29-2013, 02:16 AM   #5
mcmlxix
mcmlxix's Avatar
This is from the Gates website.... HERE
Ordinary fuel line hose is designed to handle fuel on the inside only. The Gates Submersible Fuel Line Hose exceeds the SAE 30R10 rating and is capable of handling gasoline, alcoholextended gasoline or diesel fuel in fully immersed, mobile, stationary and marine applications.
The Gates Submersible Fuel Line Hose contains a special compound called Fluoroelastomer (FKM), which resists gas permeation and retards aging. It is also reinforced with Aramid Fiber—the same fiber used in bulletproof vests and that ispound for pound stronger than steel.
It is this advanced construction that allows the Gates Submersible Fuel Line Hose to exceed the SAE 30R10 rating, which is the standard for a submersible fuel line hose application. It also makes the Gates Submersible Fuel Line Hose the perfect hose for submersed in-tank applications.
Key Features and benefits
Engineered for constant contact with gasoline (and other liquid petroleum distillates) on the inside and the outside
Meets the SAE 30R10 specification for submersible fuel line hose applications
Fluoroelastomer (FKM) tubed cover resists gas permeation and retards aging
Aramid Fiber reinforcement—the same fiber used in bulletproof vests and is pound-for-pound stronger than steel
Rich
Old 01-29-2013, 01:02 PM   #6
dropd80s
dropd80s's Avatar
I think 99% of people swapping to intank setups did this their first time around. You wouldn't think it would matter! Make you think twice about fuel spills or leaks that get on the outside of your fuel line!
"I'm Dirk Diggler enough to own and operate a vehicle of this caliber" -veinbar
Dropped and LS Swapped SWB 87 Build Thread
dropd80s is offline   Reply With Quote
Old 01-29-2013, 02:16 PM   #7
69sinker
69sinker's Avatar
7 days later.......
Old 01-29-2013, 02:18 PM   #8
69sinker
69sinker's Avatar
Old 01-30-2013, 09:07 AM   #9
thump16
thump16's Avatar
well that sucks. Now i gotta buy that hose.
