Old 01-28-2013, 01:09 PM   #176
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Originally Posted by RWB-713 View Post
Lol, I don't know why it keeps surprising me when I see other people having the same problems / decisions I have, at least I know I'm not alone! That's exactly what I had to do to my rockers, and the same thing on the cab corner/rocker junction. I welded mine up, no filler on it yet or any finish work of any sort, but I really like the way it looks, glad I went that direction.
Actually you're one of the people I seen that did that and I liked the way it looked too.
Jimmy
.69SWB Build.
~Whitey~ is offline   Reply With Quote
Old 01-28-2013, 01:12 PM   #177
67cheby
67cheby
67cheby's Avatar
Re: Project 69SWB
nice metal work !
67cheby is offline   Reply With Quote
Old 01-28-2013, 02:10 PM   #178
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Originally Posted by 67cheby View Post
nice metal work !
Thanks a bunch Mike. You've been down this road before huh?
Jimmy
.69SWB Build.
Old 01-28-2013, 07:26 PM   #179
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Well I was off work today so I decided to chop up the drivers side and see what I had in store for me. Pretty much the same as the passenger side, but I won't be replacing the upper cab corner. Time to order some repair parts. I already have the rocker and cab corner, but looks like I will need the inner rocker, front and rear patch pieces for the pillars, and the front piece for the floor. The supports underneath look ok and I didn't worry about supporting the pillar before cutting all this out. It's not really necessary as I found out on the passenger side. Here's some pics of the nasty.
Jimmy
.69SWB Build.
Old 01-28-2013, 08:41 PM   #180
RWB-713
RWB-713's Avatar
Re: Project 69SWB
Whole bunch of fun! But at least you have the harder side out of the way! I ended up not having to use the "inner rocker" replacement, the floor pieces i used had a ton of extra folded down the side, so they served the same purpose, just an FYI. I still have those if you need them and you'd be interested, but they're so cheap I bet it'd still be cheaper just to add to an existing order your making time I shipped them.
Lookin forward to seein some more great sheetmetal repair!
" I strive for a level of perfection that I do not possess the skillset to achieve. "
Ariel <> '67 C10 Shorty Stepside *** Build On Hold ***
First Ride <> '81 C10 Long Fleet *** Current Project ***
RWB-713 is offline   Reply With Quote
Old 01-28-2013, 09:05 PM   #181
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Thanks man, I appreciate the offer, but yeah would cost more to ship than their worth! I decided to save $10 and just cut a piece from a sheet of 16 gauge I have here, from what I see they don't come with the drip holes in the so I'll have to get creative to make those. I ordered up the floor piece again (ugh!), the front and rear pillar patches and the kick panel all from LMC since it all worked out okay for the passenger side, except the floor piece, but I couldn't find that anywhere else. Everything else I'll just patch up from the steel I have here or from pieces from the other cab.
Jimmy
.69SWB Build.
Old 02-05-2013, 10:49 PM   #182
Bomp
Bomp's Avatar
Re: Project 69SWB
Have some serious metal skillz
Bomp is offline   Reply With Quote
Old 02-06-2013, 11:10 AM   #183
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Thanks Bomp! .. after skimming through your build thread.. That is a GREAT compliment coming from you. You have no fear! I'm subscribed.
I'm about done with the drivers side on this.. will post pics soon.
Jimmy
.69SWB Build.
Old 02-18-2013, 12:25 PM   #184
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Finally got around to finishing up the drivers side. I had made a crucial mistake by welding in the rocker without checking it against a hung door... man I won't do that again EVER. So I had to cut the rocker back out and redo it... I was able to salvage it, but it took some delicate surgical cutting to get it out without ruining it. Thankfully I had not welded it to the inner rocker/floor piece. I knew better, but just got in a hurry. Anyway.. I replaced both pillar bottoms, part of the floor, part of the inner rocker, kick panel, rocker and cab corner for this side. I have one small repair to the top of the drivers door seal left and another small repair to the roof, then I'm going to move on to doing the undercoat on the floor, still haven't decided what to use on that yet.. bedliner or actual undercoating.
Jimmy
.69SWB Build.
Old 02-18-2013, 12:29 PM   #185
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
PS. That's you're corner/contribution Scott! Thanks again!
Jimmy
.69SWB Build.
Old 02-18-2013, 12:45 PM   #186
sduckworth13
sduckworth13's Avatar
Re: Project 69SWB
Looks great Jimmy, like brand new.
Scott
sduckworth13 is offline   Reply With Quote
Old 02-18-2013, 07:31 PM   #187
gdavis
gdavis's Avatar
Re: Project 69SWB
Don't feel too bad my friend I did the same thing. I couldn't wait to see it on the truck and like you I knew better.
gdavis is offline   Reply With Quote
Old 02-18-2013, 07:40 PM   #188
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Thanks for the solidarity brother!
Jimmy
.69SWB Build.
Old 02-18-2013, 07:51 PM   #189
yote1234
yote1234's Avatar
Re: Project 69SWB
lookin good !!
1971 K5 CST Blazer
1965 Chevelle Malibu 283 (sadly sold)
1968 Camaro 327
1968 Honda mini-trail z50a #377
1966 uh 1-D Huey
yote1234 is offline   Reply With Quote
Old 02-26-2013, 10:47 PM   #190
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Originally Posted by yote1234 View Post
lookin good !!
Thank you!
I finally got to the underneath of the cab and have a little cleaning up to do, but should get it covered this weekend. I decided to go ahead and go with Herculiner instead of trying something else, I've used it on a couple different Jeep tubs and I just can't imagine anything holding up better than it has.
Here's where the cab is now. Little grinding to do, then I can spray the Herc.
Jimmy
.69SWB Build.
Old 02-27-2013, 12:03 AM   #191
jmking9
jmking9's Avatar
Re: Project 69SWB
Hey! Lookin good Jimmy!! Almost didnt recognize your build with the new name.
1970 SWB Build
jmking9 is offline   Reply With Quote
Old 02-27-2013, 08:56 AM   #192
Low Elco
Re: Project 69SWB
Metalwork looks great!
Low Elco is offline   Reply With Quote
Old 02-27-2013, 10:12 AM   #193
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Thanks Jonathan! I kind of rushed through the process when I joined up, so finally got it to what I wanted.
Thank you Low Elco... What as great find on that little black truck link in your sig.
Jimmy
.69SWB Build.
Old 02-27-2013, 10:35 AM   #194
Low Elco
Re: Project 69SWB
Thanks! It's a bucket, but it's my paid for bucket!
Old 03-03-2013, 06:46 PM   #195
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
The undercoating is done.
Here's all the stuff I used.
First I washed it all up with some Eastwood Fast Etch & Metal Prep and then used Eastewood's PRE to wipe it down. I let it all soak into the seams and air dry with a fan on it overnight. I then used 3M Seam Sealer and sealed up anywhere I had done welding or had gaps.
I also welded up the gas line holes.... so it's now official -- I won't be putting a tank back into the cab. :-)
After the Prep & PRE
Jimmy
.69SWB Build.
Old 03-03-2013, 06:52 PM   #196
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
I stuff cotton into all the holes where bolts went so I didn't accidentally get Herculiner into them then I laid down the first coat with a brush because I wanted to make sure I had enough Herculiner and also that I was able to get it into places the spray gun wouldn't fit. Also I broke out my headlamp so I could make absolute sure I was getting good coverage while doing the brush coat.
Total I used 2 quarts... The brush coat took just under a quart. The sprayed coat could have taken less, but I just went ahead and used it all up.
I just went at it in sections.. DAB DAB BRUSH BRUSH STIR STIR REPEAT!
Jimmy
.69SWB Build.
Old 03-03-2013, 06:55 PM   #197
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
I couldn't be happier with how it turned out. I've used Herculiner on a couple Jeep tubs before and knew it was a good product. The texture came out great in the spray coat using the Harbor Freight texture gun, the smallest nozzle, no thinning, and the compressor on 35psi... I let 2 hours elapse in between coats.
I still have to spray the UV protection.. I'll post another pic after that... Got bored waiting, so here I am. Have to let it all dry a few hours before I can do that.
Jimmy
.69SWB Build.
Old 03-03-2013, 08:10 PM   #198
Fattback
Fattback's Avatar
Re: Project 69SWB
looks great
Rob
Fattback is offline   Reply With Quote
Old 03-03-2013, 09:00 PM   #199
Xeen
Xeen's Avatar
Re: Project 69SWB
Wow man that came out really nice, that wont be rusting again for a long long time.
A suggestion if I may, I noticed you are using a UV topcoat, since it will never see any sun you might want to use a less expensive product on that part, and save the UV topcoat for another application.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 03-03-2013, 09:10 PM   #200
67c10rustbuket
67c10rustbuket's Avatar
Re: Project 69SWB
Cab turned out great! awesome job replacing the whole corner of the cab. If you don't mind how exactly did you get the cab up on its back? I have a few ideas in my head but getting a few other opinions on methods before I do it.
I am concerned that someone stole your identity and changed your name Keep up the great work!
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
1969, black, custom 10, fleetside, shortbed
