Old 12-05-2012, 11:46 AM   #326
FnLow69
FnLow69's Avatar
Re: [PROJECT] Laidout53 Part II
Thanks Northern 85
FnLow69 is offline   Reply With Quote
Old 02-27-2013, 01:38 AM   #327
FnLow69
FnLow69's Avatar
Well Ive been working on the truck alittle over the last couple weekends so heres an update.
First i finished the floors by remaking the front of the seat pan area.
Then I bought a set of front fenders, and started fixing the rust. The back edge full of rust and the mount was gone so i cut that part out and used the old fender to patch it, also the front corner was gone so i made a new one. I also removed the rivets that hold the mount to the fender.
And all welded and smoothed( both are done, just no picture of the other one up close)
Next i got some G78-15 tires and wheels on it to make sure it sat low on there proper height tires and throw a fender out back to see what it will look like with the rear fender lip modification done.
Next i modified the shift lever so i can bolt on a customs shifter when i make it, then i built one out of wood to see if it works and look good. Heres what ive come up with, there will be speed hole in it and it will be chrome when done.
what do you guys think?
Justin
Old 02-27-2013, 01:44 AM   #328
VA72C10
VA72C10
VA72C10's Avatar
Great work and LOVE the rear fender idea.....I always like symmetrical fenders.
Shifter should turn out nicely also!
Old 02-27-2013, 12:56 PM   #329
thor
thor's Avatar
Always top notch!
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 02-27-2013, 10:58 PM   #330
northern 85
northern 85's Avatar
Over the top!!
northern 85 is offline   Reply With Quote
Old 02-28-2013, 01:27 AM   #331
FnLow69
FnLow69's Avatar
Thanks man, I hope it turns out like i invision it too!
Originally Posted by thor View Post
Always top notch!
Originally Posted by northern 85 View Post
Over the top!!
Thank you!
Old 03-01-2013, 03:45 PM   #332
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Love seeing your wiork..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 03-02-2013, 02:04 AM   #333
FnLow69
FnLow69's Avatar
Thanks frenchblue72
Old 03-15-2013, 08:02 AM   #334
CURSED GEARS
Read your whole thread. I'm a big fan. Love those hubcaps, hope you keep them. The tranny hump is a thing of Beauty. Do you own your own bead roller? Lowering that front windshield was genius. I kept staring at it, still not sure how you fixed it, but you did. Anyway, I will look forward to more. Now I'm off to check out your other build.
CURSED GEARS is offline   Reply With Quote
Old 09-09-2013, 11:36 PM   #335
FnLow69
FnLow69's Avatar
Wow I haven't updated this in Months!
Well good news here is an update.
So the next order of business was to tub the firewall...
and done with some clearance...
So after that I hade to move the gauge over about 2 3/4" to center up with were the steering column would be...
Then I pushed it out side to get a good look at everything...
I decide to use the button for the glove box, so I centered it to make it look right
Old 09-09-2013, 11:36 PM   #336
FnLow69
FnLow69's Avatar
Now it was time to start on the front bumper, man this was a big job for just a bumper. Anyways I cut up the front and rear bumpers for a 51 ford car. the ends are from the rear bumper and the middle section is the front. I wanted the contour to run full length.
Here are the pictures
the parts needed...
tacked
once welded you can see the ends don't line up
after some cutting and grinding they do
Next it was time to make mounts
and mounted and smoothed
Continuing with the frontend I started to modify the 54' ford headlight bezels so the were removable. First I TIG welded a tab of stainless to the backside on the bottom to hold it in.
then I bent up a mounting tab for the top for the screw to go into
together, had to add a tack on either side of the tab to keep it from moving around (still need to counter sink the screw hole a little more)
Now I decide to mount the steering column. First up I made a steering column clamp mount
welded one half to the dash
bolted together
and seen from the engine bay
sand lastly I fab a little panel to hold the key switch and headlight switch
Ok now this is up to date! Ill try to not go so long next time...
Thanks for looking, let me know what you all think?
Justin
Old 09-10-2013, 04:50 AM   #337
CURSED GEARS
Your a metal God! So precise. No miss cuts, then fixing with extra metal and weld. Looks like you cut once to make a perfect match, then welded seemlessly. Its one thing to cut up a old rusty bumper, then weld it to the way you like, but it looks like you started with a new, perfect bumper. That took a pair. Good stuff!
Old 09-10-2013, 05:21 AM   #338
northern 85
Insane,such nice work! It will be a shame to paint anything.
Old 09-10-2013, 08:58 AM   #339
tommys72
tommys72's Avatar
Awesome man. .. just awesome
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 09-10-2013, 09:09 AM   #340
hyatt
You got some Skills
1946 car hauler
1948 surburban
1937 chevy sedan
1940 olds sedan (project)
1967 ss396 chevelle
1999 dually crewcab(24000 miles)
hyatt is offline   Reply With Quote
Old 09-10-2013, 09:54 AM   #341
67ChevyRedneck
67ChevyRedneck's Avatar
I had to go back to the first few pics to see what it started as, it's changed so much. You have good taste, it's hard to make a dodge look bad ass, and it does.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 09-10-2013, 10:22 AM   #342
69CST-V
69CST-V's Avatar
I agree with all the previous fella's. Great work.
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
Old 09-11-2013, 12:41 AM   #343
FnLow69
FnLow69's Avatar
Wow thanks man, however I've made many of mistakes I've just cut them out and or redid them. and the bumpers where pretty good but they were old chrome and were kind of peeling. Thanks again!
Originally Posted by hyatt View Post
You got some Skills
Thank you guys very much!
thank you very much, yes It has changed a lot
thank you, how's your build going?
Old 09-11-2013, 10:21 AM   #344
69CST-V
69CST-V's Avatar
It should be picking up here in the next few weeks.
Keep posting up those pic's. I have seen lots of great ideas on how to simplify certain processes. Again awesome work.
Bryce
Company Trucks
Old 09-11-2013, 12:01 PM   #345
noonzor
just awesome, you got skills!!
69 c10 Shortbox Build
http://67-72chevytrucks.com/vboard/s...d.php?t=360622
noonzor is offline   Reply With Quote
Old 09-11-2013, 11:52 PM   #346
FnLow69
FnLow69's Avatar
thanks and I will...
thanks man
Old 09-12-2013, 12:59 AM   #347
Flames97
Flames97's Avatar
Ok, I've been watching this build from time to time for quite awhile and I really like everything your doing with it. Your work is top notch!!! Love the dash btw.
-Aaron
-Aaron
'15.5 Chevy Duramax LTZ/Z71, LML, CC/SB
'77 Chevy K10, 4" lift, 33-12.50, 350/350
'55 Chevy Short Box (In Pieces)MII,4-link,Bagged,383 Stroker,700r4,3.73posi (SOLD)
My 55.2 Chevy 3100 Build
Flames97 is offline   Reply With Quote
Old 09-13-2013, 12:06 AM   #348
FnLow69
FnLow69's Avatar
-Aaron
Thanks Aaron!
Old 11-29-2013, 03:43 AM   #349
FnLow69
FnLow69's Avatar
I've been working on the inner fenders lately. I wanted them to cover all the suspension to give it a clean look. They were going to be smooth but that just looked to plain. so I came up with a simple design to bead roll into them. The inner fenders utilize factory bolt holes and are completely removable.
Next the steering u-joint was right were the driver side fender needed to go so I decided to make a cover for it.
Here is the firewall support/mount that ties into the lip around the firewall
Well after bead rolling the fenders the firewall now looks to flat so here is my proposed design for it?
Next was time to make the triangle pieces that go under the floor of the cab.
Passenger side
Drivers side
View from inside the fenders
thanks for looking, let me know what you think...
Justin
Old 11-29-2013, 04:33 PM   #350
Flames97
Flames97's Avatar
Wow, that's coming out really nice. Great work your very talented.
-Aaron
