03-07-2013, 11:51 PM | #1426 | |
Junk Yartist
Re: Finally starting my Longhorn 4x4 conversion
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
03-07-2013, 11:56 PM | #1427 |
6>8 Plugless........
It allows you to move the axle 1" or 1.5". That's why there are 3 holes. You'll end up using 2 holes when you're done. I'm not too keen on the grade 5 bolts they want to use as the new center pin.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
03-08-2013, 01:34 AM | #1428 |
Junk Yartist
Don't cheap out and use the low grade hardware. Check out this problem we ran into at work. Link-a-ma-jig
03-08-2013, 01:46 AM | #1429 |
Use grade 2, it will make things far more interesting when you put the foot to the floor!
1980 K10 - 6.2L Diesel/SM465/NP205 Build Thread 1984 K30 CC Dually - "The Tank" 12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's Build Thread 1960 C-60 Dump Truck Make it road worthy! Thread |
03-08-2013, 04:00 PM | #1430 |
Could be not enough manifold pressure. that was one of the problems the cat 3406 had. Swapping a holset turbo helped.
03-08-2013, 04:17 PM | #1431 | |
03-08-2013, 05:34 PM | #1432 |
Ryan, This is off topic but thought you might like to see this. it is still in the mock up stage on the grill shell. the engine needs to be moved back. and and and....
03-08-2013, 09:19 PM | #1433 |
And and and, sell it to me! Nice progress on the ol girl!
03-08-2013, 09:27 PM | #1434 |
yeah, he is moving right along! the problem is the farther he gets the more my 52 gets buryed
03-11-2013, 11:20 AM | #1435 |
man i just took 4 hours to read this thing and your not done with it!!
03-11-2013, 03:10 PM | #1436 |
Chevy Enthusiast
I think its taken him more than 4 hours to get this far, so...
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
03-11-2013, 08:42 PM | #1437 | |
Uh, yeah, you're totally right. It'd get done if I quit improving on it every time I work on it.
03-11-2013, 08:56 PM | #1438 |
I would use that word "improving" very loosely if I where you
03-11-2013, 08:59 PM | #1439 |
I got some time to work on it this weekend. I got the zero rates installed, and IDK if I'm exactly am happy with it. Before I started the wheel base was 132". After it's 133.5". So it definitely moved. I just don't think it's enough in the front yet. But I only moved it 1/2". I still have the 1 1/2" hole to try. I also stripped the other hole in my diff housing on the RH leaf spring retaining plate. So I'll have to heli-coil them. I had the inserts but no tap. I didn't realize the taps for a 1/2" heli-coil was an odd size. Go figure. I got the kit today though, so I'm good there. Any how, here's some progress pics.
I cleaned the bed out, removed the rear bumper, and slid the bed back. The bed was way too close to the cab for my taste. Next I removed the bed so I can start on the GN hitch, frame boxing, and fuel tank swap. (Thanks for the idea Matty) Almost had a casualty............. No bed. Tail pipe won't work when my hitch is finished. I'm planning on running straight pipe now. Starting on the GN hitch. I'll have a B&W inbetween the 4x4 and 2x4 cross members. Shoot, just this weekend and this morning, I bet I spent 10hrs working on this thing.
03-11-2013, 10:09 PM | #1440 |
Junk Yartist
Exhaust pipe or Ia metro subway!
I agree, I think the axle needs to move forward still.
03-11-2013, 10:10 PM | #1441 |
Suburban Hick
Looking good buddy. Hope to see this one at goodguys this year.
Mathew 1947 Chevy 3600 1951 GMC 100 1969 Chevy C-10 396/500hp TH400 lowered 4" 1968 Imapla Custom 396/325hp TH400 "Grandmas Car" 1976 Crew Cab 4x4 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=488505 1978 Chevy K-10 454 1983 S10 4x4 "Bumblb" (Grandpa's truck) 1993 Chevy S10 V8 conversion 1990 Ford Probe Gt 1992 Dodge W-150 "Old Man's Truck" 1992 Pontiac Grand Prix SE 1992 Mercury Grand Marquis-Mercruiser 2000 Ford F150 (Currently my mother drives this) 1946 Farmall H with Stan Hoist loader 1965 John Deere 110 1961 Wheel Horse " Rat Tractor" |
03-11-2013, 10:25 PM | #1442 |
Looking good! you know i think you are spinning you wheels adjusting that rear axle placement. you know it wont matter when you step up to the plate and link/bag that bad dog...
that gooseneck plan looks good, wish ida thought of that Ryan |
03-11-2013, 11:03 PM | #1443 | |
03-12-2013, 04:04 PM | #1444 |
I was talking about the burb tank sonny boy. I already had the B&W to do this with.
03-12-2013, 04:05 PM | #1445 |
Yeah, you know it. Bye Bye leaves......................
03-12-2013, 04:09 PM | #1446 |
Still Learning
very nice progress Ryan.
03-12-2013, 04:58 PM | #1447 | |
03-12-2013, 08:57 PM | #1448 |
i'm thinkin so.
03-12-2013, 11:21 PM | #1449 |
Mr. Wrencher has a pile of steel hiding in CO...
03-13-2013, 01:48 AM | #1450 |
Junk Yartist
No backing out now!!
