#226 |
Re: SPID Picture thread?
So does a factory cruise control set up show up on the SPID?
Also I remember some Air Force trucks at a junk yard in Monroe Washington in the 1980's (always short boxes or step sides for some reason) which had some real short SPID. Usually special order and maybe foam seat was on it. Bare basic trucks that were used and then some by the air base.
Vancouver Bob |
#227 |
The SPID would show V30 for a factory, production line installed cruise control. But a GM accessory kit installed by the dealer would not.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
#228 |
Another for the collection. '71 GMC, purty plain :-)
By the way, what's up with the dark green glove box door and medium green body paint ? I've seen some medium green trucks here thave matching glove box. I am going to freshen my girl up and want it to be right. Just seems odd to have the different glove box in this instance, maybe just adding contrast.. ![]() |
#229 | |
Posted via Mobile Device Posted via Mobile Device
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=563712 Instagram: http://instagram.com/rockylakekustoms Rocky Lake Kustoms Russ |
#230 |
Thanks for pointing that out and you are correct as K01-L99 are engine range upc codes. Now I am trying to figure out where my V came from, hope it is just a typo.
#231 | |
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 03-12-2013 at 11:07 PM. |
#232 |
ok, thanks Tim ;-) It will remain that way then.
#233 |
Did my truck come with carpets
Posted via Mobile Device Posted via Mobile Device |
#234 |
No, while your truck does have the RPO Z62 Custom Comfort and Appearance package it did not include carpet. In your case black rubber floor matting is correct. If you have carpet it was added.
#235 |
![]() Join Date: Feb 2013
Here is mine... 72 GMC 1/2ton 4x4 short bed
#236 |
Florida Edition
![]() ![]() Join Date: Oct 2010
I can't remember if I posted mine up in here or not so here goes....first is my Custom Camper parts truck, second is my BB stepper (thanks Chipflyer) and the third is our 70 GMC BB Sierra Grande (in line for resto...finally got the org title in hand WHOO HOO!)
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#237 |
Ok, I have a question. Were white wall tires standard on any level of truck? I would think Cheyenne and Cheyenne Super, since all the old pics of them they seem to have them, but they're not listed. You see optional tire sizes often, but mine has H78x15 belted white for an optional tire. Is that an optional size, or just the white wall option? My truck is a Custom Deluxe.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#238 |
Both actually. The H78/15B tires were upgrade sizes and sometimes a required option dependng on how the truck was ordered. They were available as blackwall highway and/or on/off road tread and also as white stripe highway tread tires. The RPO PV6 you have is a set of five H78/15B bias belted white stripe highway tires.
As far as I know white stripe tires were not standard on any of these trucks nor at any trim level. However there may have been "specials" that included them but not the Inflation Fighter (YF7) nor the "Highlander Package" trucks (YG6,YG7 or YG8). BTW: Thanks for leaving the year and plant codes up.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 03-13-2013 at 06:44 PM. Reason: higher word count |
#239 |
Speaking of Inflation Fighters, here's my old dark blue one.
Also, I don't usually get too worried about posting VIN numbers on SPIDs, but the green one is my own personal truck, so I just blocked off the last part of it. I saw where you had asked for people to leave the first part and I didn't see any harm in that. This truck I don't have anymore, so you get the whole number.
#240 |
Here's mine. 72 BB 3/4 Sierra. Not the most optioned truck. But not bad. Interesting though they used the Cheyenne designation on the SPID.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold ![]() 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
#241 | |
Who Changed This?
![]() Join Date: Jan 2013
#242 |
I like it! Considering something similar for a custom build I am doing.
I may have too many Chevys... Is that possible? ![]() 68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713 |
#243 |
Cluster King
![]() Join Date: Nov 2012
Here is mine. 72 Cheyenne.
#244 | |
So being as your is such a low number I'd say it was a 9/69 build. What date are you showing on the block ID stamp and did you find a broadcast/build sheet? See posts 202, 205 and 210 for the back story here.
#245 |
Proprietor of Dale's Corner
Here is blues spid
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
#246 |
Funny I was searching for this thread with no luck, hijacked a thread to ask SSTim for a link, he responded then it's at the top thanks to Ol Blu K20. Anywhoo here's a few from some dearly de-parted trucks and a Blazer I gutted, the Blazer was one of the rustiest I've ever seen.
#247 |
I saw your hijack and remembered I never posted mine so it's your fault I found it..
#248 |
Here's the one from the '70 Custom Camper 20 I got recently that is now becoming a K20...
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
#249 |
And the one of my '72 GMC parts truck
#250 |
![]() Join Date: May 2010
Here's mine on my 69 CST/20. When I bought this truck new one of the conditions of the sale for the dealer (Barton's Chevrolet in Yorba Linda, CA) to install power brakes prior to delivery. So, I wrote "Power Brakes" on the SPID. How was I to know I should have written "Brake Booster Equip". Hell, I was just a kid!
