Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > Review Board > Vendor Reviews
Old 05-15-2013, 07:05 PM   #1
weider1717
Question Was I scammed on ebay on this grill? need help
Ok i purchased the grill in the link below you can obviously see it's in an genuine gm box with the part number etc..however, the grills i received is in a sealed bag unlike whats in the photo and in a plain box no gm stickers no nothing on it. and also it isn't the same part number! the one in the ad is 15554911. The one I received in the center tab of the grill on the top says 15554912. It looks the same just different part number what gives? is this a NOS grill or not? I don't think so I think I was scammed. REALLY pissed!
http://www.ebay.com/itm/181131728002...&tid=0&vxp=mtr
weider1717 is offline   Reply With Quote
Old 05-15-2013, 07:11 PM   #2
CHROMAHOLIC
CHROMAHOLIC's Avatar
Re: Was I scammed on ebay on this grill? need help
Does the one you received have the holes in the center for the Bowtie to bolt through
CHROMAHOLIC is offline   Reply With Quote
Old 05-15-2013, 07:18 PM   #3
JCampbell
Why not post pics of the one you got to compare? Regardless...it's not a bad price, even if it's an aftermarket piece.
I know, I know, it's not the point...
JCampbell is offline   Reply With Quote
Old 05-15-2013, 07:31 PM   #4
weider1717
Ok guys here is it shows both sides of the box that label is just the shipping label. I wanted an nos real gm grill if someone can tell me although this isn't the one on the ad if it's a nos grill i'll be good.
Old 05-15-2013, 07:37 PM   #5
ont_guy_38
ont_guy_38's Avatar
15554912 looks like a legit GM number
1985 C10
2004 Avalanche
ont_guy_38 is offline   Reply With Quote
Old 05-15-2013, 09:14 PM   #6
jasonw
You probably got ripped....you got a grill from rockauto.com
they sell them for about $30.00
if you look at the back side of the grille, real gm has 1/4" speed nuts holding the chrome trim on...the replacement has tiny tiny machine thread clips that take a 5.5 mm socket to remove (the stud is smaller than the lead in a #2 pencil)
I used the rockauto grill...but I had trouble making the lmc grill trim inserts fit and had to do a little modification where the bowtie goes in the middle.
jasonw is offline   Reply With Quote
Old 05-15-2013, 09:18 PM   #7
sdailey
The Few, The Proud
sdailey's Avatar
According to the listing the seller has a 14-day money back policy.
Shannon
sdailey is offline   Reply With Quote
Old 05-15-2013, 09:19 PM   #8
Outlaw87
Outlaw87's Avatar
I would say you got a better deal than what was described. the 15554912 part number is what's on my original grille in my 87. I've looked and looked for that same NOS grille and never have found it. All I can find is the 15554911. I saw this listing an passed it up because he had it listed as the 4911. If i would of known i was gonna get the 4912, i would of snatched it up quick! good score.
Outlaw87 is offline   Reply With Quote
Old 05-15-2013, 09:23 PM   #9
Keith Seymore
Keith Seymore's Avatar
The part numbers seem legit.
Sometimes there is an embossed number which represents the base part (like the casting number on a cylinder head or block, or exhaust manifold). Then, after machining or updating in some way the final assembly part number increments to something else (often the next sequential number).
In plastic parts this would also be known as the "less finish" number; then the specific colors (red, blue, green, whatever) would have a separate and distinct part number incrementing up off the less finish.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 05-15-2013, 09:32 PM   #10
weider1717
here is the top center tab can you guys tell by this if it's a rock auto grill as mentioned or a real gm one? if it's a real gm nos piece i don't care that it's not the actual one pictured it jut gives me the feeling of i got screwed yanno just being sure.
if he is right about the speed nuts i got screwed no speed nuts!
Old 05-15-2013, 09:40 PM   #11
jasonw
Well....I forgot..the rockauto grill didn't have the square holes in the top that you press in the screw inserts. I had to use those little springy screw clips like you find holding in the speedometer bezel.
That may in fact be a real GM grille.
Old 05-15-2013, 09:44 PM   #12
weider1717
does mine have what your talking about? these rectangle deals? didn't come with new ones to pop in though do you just use your old ones?
Old 05-15-2013, 09:59 PM   #13
jasonw
hopefully someone can confirm whether it is a gm part or not...but it is not exactly the same as mine....but I will also add that rockauto uses various manufactures to supply parts.
And....I have ordered lots of parts from rockauto that are rear gm parts...some say gm mexico too.
Old 05-15-2013, 10:13 PM   #14
weider1717
that would be nice but some jerk deleted my post on the general topic area heck i thought this was a general topic!
Old 05-15-2013, 10:55 PM   #15
Outlaw87
Outlaw87's Avatar
weider1717, these are the markings on my original grille...
Old 05-15-2013, 11:32 PM   #16
weider1717
looks like yours here some pics
Old 05-15-2013, 11:36 PM   #17
Outlaw87
Outlaw87's Avatar
Looks like your good, bud. I would much rather have that grille you got than my brand new one I got from GM with the 4911 part number.
Old 05-15-2013, 11:48 PM   #18
weider1717
so your new grill actually says 15554911 on the center tab? weird if theres no difference.
Old 05-16-2013, 12:04 AM   #19
Outlaw87
Outlaw87's Avatar
Yep! I actually have two NOS grilles and neither have the the same number. I know some come with the 4 aluminum inserts and some don't, i think that makes a difference in part numbers.
Old 05-16-2013, 07:28 AM   #20
wraprail
wraprail's Avatar
Looks like you got a Smoking deal on a factory part.
Just don't try cooking on it!
wraprail is offline   Reply With Quote
Old 05-16-2013, 12:37 PM   #21
N2TRUX
Happy to be here
N2TRUX's Avatar
Your post wasnt deleted, it was moved. That "jerk" is a staff member doing there job. I understand your frustrations over the grill issue, but don't compound your problem by calling out the staff for doing their job.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-16-2013, 01:25 PM   #22
weider1717
I understand the job of a moderator but the deal is that was a legitimate topic for this section it was a question about a grille for an 87 to see if it was a GM nos grille or not! It should not have been moved.
I bet the teachers loved you in school
