05-03-2011, 10:21 AM | #1 |
brake swaping questions, need some help!
i am currently building a 68 k20, started with a bare frame and right now im working on the brake system. i am changing from manual 4 wheel drum brakes, to 4 wheel disk and hydraboost!, currently i have all the hydraboost done and plumbed but on my master cylender i am unsure which reservoir controls front and rear, im pretty sure the m/c i have is for disk/drum brakes as it has to different size reservoirs, does it really matter which one goes where now?
05-08-2011, 09:27 PM | #2 |
Restoration Virgin!
Re: brake swaping questions, need some help!
ttt
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
05-08-2011, 09:31 PM | #3 | |
1969 C/20, 307, 4-speed, rusty with manual steering and brakes! |
05-17-2013, 03:22 AM | #4 | |
Still plays with trucks
On 3/4-tons the front of the master is for the rear brakes and on 1/2-tons it is the rear of the master for the rear brakes. The fitting coming out of the master cylinder is a larger size for the rear brakes. Check out your stock plumbing to see which fitting size goes to the rear to know for sure which one you have on there.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
05-17-2013, 03:44 AM | #5 |
What makes you think your disc/drum master has enough fluid volume for a disc/dics application? Start by identifying your master and determine if it is big enough and I'm sure the proper ports will become apparent.
As far as best practice plumbing I'd model it after the stock Hydro Boost truck your parts are from if it was a disc/disc truck.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
05-17-2013, 12:29 PM | #6 |
I'd even consider using the Hydroboost M/C that's designed for this disc/disc system. Then you know you have that part correct...& the luxury of a newer, easier to locate part... Just my .02
05-17-2013, 12:51 PM | #7 |
The large reservoir is for the front disc brakes. If you have a disc/drum master you can use it on disc/disc, just refill the small reservoir down the road as the pads wear, it'll take quite some time to need refilling as the rear pads don't wear very quickly.
