Old 08-11-2009, 08:00 AM   #26
Shon
Re: Cable X speedo converter
Originally Posted by lts70 View Post
Shon, it is good to hear they worked out that bug. That is one of the reasons I have been holding off so long in ordering. does the 30 slot mean the unit has more teeth on its gears?
Yes. The way it was explained to me was that the old style 'skipped', ie the 'teeth' did not mesh right and the cable is flexible so unitl it got going it was flaky but they say the new 30slot unit does not have those issues.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 08-11-2009, 01:51 PM   #27
lts70
1970 Daily Driver
lts70's Avatar
Shon & TEXAS 68, thanks for the info. I wonder if with this new setup if having a little bend in the cable is as critical and if it makes less noise?
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is offline   Reply With Quote
Old 08-11-2009, 01:57 PM   #28
Shon
I am going to guess that the staighter the better. even if you look at the factory set up, not any harsh bends in it, or my set up doesnt. As for the motor sound, just a product of the unit which sux but not many other options.....
Old 03-16-2010, 11:55 PM   #29
trenz68
Damage Inc
trenz68's Avatar
to the top...anyone else?
05 CC- magnacharged,LTs,Gt-2 cam,3.73s,tru-trac,tuned-sold
01 ECSB- caddy-clipped,22/24 intros,cammed,layin-frame
04 RCSB-joe gibbs clone,22in billets
68 stepper build
http://67-72chevytrucks.com/vboard/s...d.php?t=332337
trenz68 is offline   Reply With Quote
Old 03-17-2010, 08:44 AM   #30
Shon
I have been using mine as a DD and I like it!
and when you set it up right it's dead on by the radar.
Old 03-31-2010, 07:26 PM   #31
biggreen292
my buddy has one in his 80 malibu with a t56, only problem encountered is the cable was being pushed down a little by the wiring harness behind the dash and the box couldnt overcome the pressure, aka no speedo. got the wiring routed away from it and has been perfect. its mounted on the drivers inner fender for a straight shot to the speedo head. cars too loud to hear anything from that little box
http://i16.photobucket.com/albums/b3...fleet041-1.jpg
71 custom camper/20:292/saginaw, my first pickup
83 cutlass cruiser:307/th250c, lifelong project
96 caprice 9C1:LT1/4L60E, police package
83 buick regal estate: buick 350/m20
69 bel air:250/m21
biggreen292 is offline   Reply With Quote
Old 09-01-2010, 10:49 PM   #32
NZSquare
NZSquare's Avatar
Sorry for digging up an old thread but I thought I'd share my experience.
I installed one of the new style 30 slot cable x's a few weeks back in my 82 c10, its running an AW30-40LE box (jeep cherokee, toyota etc) with a 4 pulse per rev VSS output. This equates to a pulse per mile figure of 760 or so.
My speedo jumps around all over the show for the first 10 minutes driving (it reads bang on double speed for the first couple of miles), this could be due to the very low pulse count or also me not having the cable as straight as it could be. Either way it wakes up/warms up after a while and reads just fine.
I have the box under the dash and haven't really heard it over the engine noise.
Im happy with the unit and will make some changes and see how it goes.
NZSquare is offline   Reply With Quote
Old 05-17-2013, 10:40 PM   #33
71Frankenstein
I was thinking about mounting it something like this but possibly in a waterproof box. So the cable goes in at a straight shot the same pathway as the original.
To Its70 do you have other pics of how you mounted your clutch master from the inside?
71Frankenstein is offline   Reply With Quote
