Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 06-06-2013, 07:21 PM   #1
Masstowingllc
1985 Chevy c60 ramp truck with a 1970 454, early sm465, & 2 speed Rearend????
I have 1985 Chevy c60 ramp truck with a 1970 454, early sm465, & 2 speed Rearend. So can I change the Rearend gears so when in high I can go like 65 mph and get better mileage also I am trying to figure out how to get better. Mileage and highway speeds out of this big truck? Thank you in advance
Masstowingllc is offline   Reply With Quote
Old 06-06-2013, 08:40 PM   #2
C10 - C90 Bill
C10 - C90 Bill's Avatar
Re: 1985 Chevy c60 ramp truck with a 1970 454, early sm465, & 2 speed Rearend????
Finding the higher gears would be the biggest problem. You might try calling a Chevy truck dealer to see if any are available, or if they were ever available.
If nothing works out for you, you could try taller tires, especially if you are running low profile tires now.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill is offline   Reply With Quote
Old 06-06-2013, 08:47 PM   #3
Masstowingllc
This has 20 inch rims its a big tow truck this is one step down from a big rig basically I just wanted to know if I could leave low the way it is and change the high gears to something better for gas or like use the high as low and change the high to make it do way better on highway
Old 06-06-2013, 09:00 PM   #4
C10 - C90 Bill
Well, I would still check with your local dealer on the gear question.
The 20 Inch wheels are the norm on your truck, but what size tires are you running?
And are you sure they aren't Low Profiles? Believe it or not, tire size can make a notice-able difference, and a cheaper way to boot.
GMC 9500 Fan
Detroit Diesel Fan
Old 06-06-2013, 09:23 PM   #5
Masstowingllc
No they are ply tires not radials
Old 06-06-2013, 10:12 PM   #6
66Submarine
66Submarine's Avatar
I'm not an expert on anything, much less the "heavies". But, if you already have the two speed rear I think you probably already have 6.40/8.72 ratios, which were pretty much standard. The low range is a planetary reduction of the high/direct range, not another gear set.
You might could find an axle out of a diesel truck with ratios like you like, given that a diesel rear will be designed for lower engine speeds. Or you could look at finding an overdrive five speed trans out of another big truck. You could also consider swapping out the thirsty BBC for a smaller 350 or something if you don't need all the power. You'll still be screaming along at 3,500+ going 65, but you should use less fuel doing so.
Hope this helps.
66Submarine is offline   Reply With Quote
Old 06-06-2013, 10:48 PM   #7
ky-donzi
Why not go to a 5 speed od trans? Would be cheaper and easier probably
61 GMC 4x4 1-ton flatbed 4bt cummins, ranger od, sm465, np 205, d60F, d70R 4.11 10,000 ramsey PTO winch.... SOLD
73 k5 gm crate 350-265 / sm465 / np205 3.73 posi
ky-donzi is offline   Reply With Quote
Old 06-07-2013, 08:02 AM   #8
alabama mike
alabama mike's Avatar
does it have Budd wheels or Dayton wheels? and the reason I ask is if it has budds you can get the centers cut out and put into 22.5 wheels, then you have a large number of sizes to choose from, Might be some up front expense but would be worth it in the long run!
Disabled Vet, Desert Shield/Desert Storm Veteran
"Proud to have served"
1965 C-10, 1965 C-60, 1966 C-10, 1975 C-20, 1986 M1009 Blazer, 1987 GMC 1/2 ton suburban, 1995 1500 Suburban 4x4, 2001 2500 Suburban 8.1L
alabama mike is offline   Reply With Quote
Old 06-07-2013, 09:34 AM   #9
C10 - C90 Bill
I've always known them to be real hard to find. Something that would bolt right in anyway.
GMC 9500 Fan
Detroit Diesel Fan
Old 06-07-2013, 12:45 PM   #10
ky-donzi
Np540 would be, but how bout a nv4500, it would be strong enough, probably less effort than swapping gears in the rear,,,
Old 06-08-2013, 05:21 PM   #11
C10 - C90 Bill
A few years back, I tried to find an Overdrive for my '72 C-10 as well as my '68 C-30. I just love the idea of having a 5-Speed with an OD in my trucks. I didn't check into it very deep, but deep enough to realize that there was no easy way, unless I received the wrong or incomplete info. I mentioned the NP540 to some very knowledge-able guys and didn't get a big green light. I did a quick research just now and found this below. Although I'm a member over there and have talked about the subject over there, this is not my post.
Hopefully it will clear up some info and I welcome anything that anyone can contribute as it is a subject that I am still very interested in. Also notice another poster also saying that the OD Trans is "hard to find".
http://www.stovebolt.com/ubbthreads/...&Number=814855
GMC 9500 Fan
Detroit Diesel Fan
Old 06-08-2013, 06:14 PM   #12
Masstowingllc
Well i would rather not change tranny since i have put a lot of work into it and tbis in 4th is 1 to 1
Old 06-09-2013, 02:21 PM   #13
mrolds88
I think the trans option would be the best route. Look at a Spicer 3053A (I think thats the right variant). They came mostly in military trucks. It might be the best option.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
