Old 08-08-2013, 12:47 AM   #26
marvgarr68
marvgarr68's Avatar
Re: 68 c10 6.5 turbo diesel
O yea BBC mounts also move it forward about an inch that's another reason I went sbc mounts.
marvgarr68 is offline   Reply With Quote
Old 08-10-2013, 03:10 PM   #27
marvgarr68
marvgarr68's Avatar
Here are pics of the trans build. I had them on another old post when I was going to put a 350 in the truck.
Old 08-10-2013, 03:12 PM   #28
marvgarr68
marvgarr68's Avatar
more pics
Old 08-12-2013, 12:29 PM   #29
marvgarr68
marvgarr68's Avatar
Ok question time what do you think is better stage of paint single stage or 2 stage. What primer should I use the truck is going to be white. I am going to be painting this my self so keep that in mind. I already know that it wont look like a pro paint job. Also people around here can care less if you have a nice paint job. In fact I think they get a kick out of running and banging into a nice paint job.
Old 08-29-2013, 10:56 PM   #30
marvgarr68
marvgarr68's Avatar
well got the one piece driveline. All lines up good tearing it down for frame paint and front end rebuild. I will post some pics of it painted.
Old 09-07-2013, 12:50 AM   #31
marvgarr68
marvgarr68's Avatar
here is the frame all painted came out good also cleaned all the old riveted exhaust brackets of the frame and the rear bump stops
Old 09-09-2013, 03:19 PM   #32
marvgarr68
marvgarr68's Avatar
the frame all painted got the rear end painted poly track arm bushings in new bolts, rear springs what you think?
Old 09-09-2013, 08:34 PM   #33
chevy88
chevy88's Avatar
Well it looks like your going to do it up right starting from the ground up, I'm sure you'll love that diesel motor in there and its cool, its different. I put a 6.2 in mine and wouldn't change a thing...
Kerry
My build thread.
http://67-72chevytrucks.com/vboard/s....php?p=3657823
1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears
1988 Chev Extendacab
2010 Honda VT1300CS Sabre
2005 Buick Rendezvous wife's ride
chevy88 is offline   Reply With Quote
Old 09-09-2013, 08:39 PM   #34
67_C-30
I have a radical idea!
67_C-30's Avatar
Looking good!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 09-09-2013, 10:35 PM   #35
marvgarr68
marvgarr68's Avatar
thanks for the feed back it keeps me moving forward thanks guys
Old 09-10-2013, 03:25 PM   #36
HSRACER
HSRACER's Avatar
Great start so far
HSRACER
Slammed 53 5 window
Blown/Bagged 54 Pickup
Patinaed 67 LS stepside
Supercharged 67 Nova
Bagged 69 Suburban Turbo'ed 5.3 LS
HSRACER is offline   Reply With Quote
Old 09-11-2013, 10:31 PM   #37
marvgarr68
marvgarr68's Avatar
got the engine back from machine shop also installed all the brake lines and found a uncut rear light harness.
Old 09-11-2013, 10:32 PM   #38
marvgarr68
marvgarr68's Avatar
the rest of the pics
Old 09-18-2013, 10:00 PM   #39
marvgarr68
marvgarr68's Avatar
update pass inner rocker rusted out got 18g metal put 90 deg bend in it and weld it in seam sealed the edges. Also undercoated the whole under side of the cab. Also cut out some small sections of rusted out floor and welded in patches. Cut out some heater delete patches and stitch welded them in will fully weld them tomorrow. Put cab back on frame installed poly cab mounts starting to come together.
1976 k20, 350 built, 44/14 axles
1968 c10 6.5 turbo diesel,t5 trans
1977 gmc c3500 dually, crew, 4-53t, 5&3 trans
http://67-72chevytrucks.com/vboard/s...d.php?t=591188
Old 09-19-2013, 10:16 PM   #40
marvgarr68
marvgarr68's Avatar
finished heater delete plates tacked them in for now. also a pic of cab on frame
Old 09-20-2013, 01:17 PM   #41
RenoKeene
Florida Edition
RenoKeene's Avatar
Looks good man, you definitely have skills.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 09-20-2013, 02:53 PM   #42
marvgarr68
marvgarr68's Avatar
Thanks this is my first frame off all the way in build nice to know how I'm doing or what I'm doing wrong
Old 09-21-2013, 03:29 PM   #43
marvgarr68
marvgarr68's Avatar
So I got all the heater delete plates fully welded and started welding up all the little holes. I then ran out of wire for my welder so I got to buy some more. All in all the firewall is coming out good im happy with it looks flat and true. I will post pics of it when im done o yea I ordered all new control arm shafts and ball joints. Im just waiting on my front drop springs to be ordered from my buddy and then I will reinstall the front end.
Old 09-25-2013, 05:41 PM   #44
marvgarr68
marvgarr68's Avatar
got firewall all filled in and smooth and primered to windy to paint. Got the rear wheel cylinders rebuilt and painted also all new front suspension parts.
Old 09-26-2013, 08:36 AM   #45
Lemield
Lemield's Avatar
Really doing some nice work there! Looking great!
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 09-26-2013, 01:59 PM   #46
marvgarr68
marvgarr68's Avatar
thank you still windy today but will get some done today
Old 09-27-2013, 03:27 PM   #47
marvgarr68
marvgarr68's Avatar
got firewall all sprayed semi gloss came out good I think
Old 10-01-2013, 03:44 AM   #48
marvgarr68
marvgarr68's Avatar
Got the a arms all painted with new shafts and ball joints
Old 10-03-2013, 10:26 PM   #49
marvgarr68
marvgarr68's Avatar
Front end almost done
Old 10-10-2013, 06:54 PM   #50
marvgarr68
marvgarr68's Avatar
Got the front springs in rebuilt the front wheel cyls replaced front brake hoses and installed new master cyl and painted it. I also painted the metering valve bracket and column lower support and master cyl cap. I replaced pinion seal also.
