Old 08-13-2013, 10:15 AM   #1
Alex72nova
Clicking?!
Hey good morning guys,
I have this clicking coming from somewhere, and I cant Figure it out!
It clicks in idle, and when i accelerate. When i put my transmission in park, it stops! It sounds like the speedo cable type clicking but comes from the passenger side of the cab? I have AC, but I can turn it on and off, and it still clicks!
Going 40mph, and giving it gas, it clicks a lot!
I checked my Tranny fluid, and its on the "add" line, but im at work so it'll have to wait till later.
any clues on what this can be? i never have this clicking, the closest thing i ever had to this was an exhaust leak
Alex72nova is offline   Reply With Quote
Old 08-13-2013, 10:57 AM   #2
Spokanistan
Spokanistan's Avatar
Re: Clicking?!
Lifter noise? Check your engine oil level
Spokanistan is offline   Reply With Quote
Old 08-13-2013, 11:15 AM   #3
Alex72nova
Re: Clicking?!
I was thinking that! my lifters need to be adjusted, i have around 10,000 miles
Old 08-13-2013, 11:24 AM   #4
cdowns
cdowns's Avatar
Re: Clicking?!
exhaust leak
Old 08-13-2013, 11:40 AM   #5
jkeady
jkeady's Avatar
Re: Clicking?!
Originally Posted by cdowns View Post
exhaust leak
Ditto.
Josh
'70 Custom Camper / 20
jkeady is offline   Reply With Quote
Old 08-13-2013, 11:42 AM   #6
Alex72nova
Re: Clicking?!
exhaust leak
I was thinking that, but i popped the hood, revved the engine up a bit, and there was no sound of exhaust leaks
Old 08-13-2013, 12:45 PM   #7
Alex72nova
Re: Clicking?!
I was thinking if it can possibly be my Speedo- cable?
My speedo always jumps around like a rabbit, but never made this noise.
Im also leaning towards exhaust leak.
what do you guys think?
Old 08-13-2013, 01:33 PM   #8
Spokanistan
Re: Clicking?!
My drivers side and now my passenger side lifters make noise, because my sb 400 leaks 2qts a week and it runs out when I forget, so I just get to deal with the sound for another 2 weeks till my crate motor is in.
Old 08-13-2013, 02:11 PM   #9
463
463's Avatar
Re: Clicking?!
Speedo- cable , unhook from the trans and test drive and see if the noise stops!
Trueman
463 is offline   Reply With Quote
Old 08-13-2013, 02:18 PM   #10
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Clicking?!
If it's a SBC or BBC... you don't need to readjust the hydraulic lifters... ever. Only time you have to readjust is if they weren't set properly in the first place.
If they are solid lifters... different story.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 08-13-2013, 03:01 PM   #11
Alex72nova
Re: Clicking?!
i leak a quart a month about! stupid chrome oil pan!
Old 08-13-2013, 03:02 PM   #12
Alex72nova
Re: Clicking?!
Gary
its a sbc, flat tappet cam, I think im leaning more towards a pesty exhaust leak
Old 08-13-2013, 03:50 PM   #13
Spokanistan
Re: Clicking?!
I chose to avoid that on my crate motor, I still have my chrome dif cover that I had to take a grinder to, to make it seal.
Old 08-13-2013, 08:38 PM   #14
swamp rat
swamp rat's Avatar
Re: Clicking?!
If the speedo jumps around your speedo cable ether needs to be replaced or could use a little lubrication, check that too.
You said it stops in park but is present in gear, makes me think exhaust leak or something from the tranny. Block the wheels AND get a buddy to stab on the brakes (safety first) while you move about and listen for the sound, if you don't have a mechanics stethoscope use a wooden dowel or a long screw driver and put your ear up to it at different places to try and pin point the noise under the hood and also under the truck. It may not be audible in park as there is no load on the engine?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 08-13-2013, 08:59 PM   #15
68streetrod
Re: Clicking?!
check your flywheel/flexplate if it has a crack in gear with a load it will show up and in park without a load it would go away if not a major crack. Just a thought
68streetrod is offline   Reply With Quote
