09-26-2013, 08:14 AM | #1 |
interior always a tan color???
So my truck is a 62 and is light blue on the outside but tan on the inside. I have noticed that almost all of these trucks no matter what color they are on the outside they are almost always painted that tan color on the inside. Any one have any info on this?
Thanks |
09-26-2013, 08:37 AM | #2 |
Re: interior always a tan color???
Fawn was the factory color. You will find some 60-61 is a silverfish color also
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
09-26-2013, 10:25 AM | #3 |
IF you want to get official colors exterior and interior go to www.autocolorlibrary.com you will find them there with codes (Ditzler paint) which is now PPG Kieth
09-26-2013, 03:30 PM | #4 |
i pulled out my carpet last weekend, and sure enough the floor was painted fawn.
09-26-2013, 03:41 PM | #5 |
Some were silver, I have 2 65 cabs, one silver and one fawn.
09-26-2013, 05:44 PM | #6 |
09-26-2013, 06:01 PM | #7 |
Mine is Silver 64 model.
1964 BBC 402 4x4 |
09-26-2013, 07:28 PM | #8 |
Both chevys,
09-26-2013, 08:06 PM | #9 |
All the trucks I have had were fawn. Wiped down the rattle can blue with acetone and found white from the top seam on a-piler to the the rear of seat. Also the dash has wh ite inside gauge area and glovebox. Non deluxe cab.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
09-26-2013, 09:48 PM | #10 |
09-27-2013, 01:22 AM | #11 |
My 60 Chevy c30 panel is silver interior, Was made in the Fremont plant.
09-27-2013, 01:34 AM | #12 |
The 65 cab that was silver was the factory air truck I just sold and I believe it was a freemont truck also.
09-27-2013, 02:00 AM | #13 |
I also have a 62 and am wondering if anyone knows the exact color of the outside of the instrument cluster areas (the off white area)??? Thanks
Posted via Mobile Device |
09-27-2013, 08:44 AM | #14 |
My 61 silver cab was built in St. Louis. My 63 is fawn and is a Baltimore truck
09-27-2013, 12:39 PM | #15 |
Fremont wasn't built in 1960.
1961 chevy K10 my build is------------61K10 build |
09-27-2013, 06:16 PM | #16 |
What was the CA plant in 60 then? I was told it was made in CA and never left. I always assumed it was Fremont.
09-27-2013, 08:08 PM | #17 |
My interior had the fawn tan like color, and one of the rims was the same color. My buck and a 1/2.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
09-27-2013, 11:56 PM | #18 |
It would have been the Oakland plant. Both my 59 and 60 were built there. The plant was located at the corner of 73rd Ave and Foothill Blvd and was in operation from 1917 to 1963 I believe. The location was turned into the Eastmont Mall later and now it's located within the Oakland "killing zone" where there are 100+ homicides a year. My how times change!!
09-28-2013, 12:11 AM | #19 |
1961 crewcab
curious about the silver 65...
I was under the impression that all 60-61 were silver with the charcoal dash, then 62-65 were fawn (tan) with the tan dash, and the 66 was fawn with the brown dash. chev and gmc.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
09-28-2013, 07:08 PM | #20 |
Must have been special ordered?
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
09-28-2013, 11:25 PM | #21 |
Rollin' Old Skool
from everything I've seen & read on here, that's my understanding as well....hmmmm
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
09-29-2013, 02:02 PM | #22 |
It's totally anecdotal, but when I was a teenager I had a 65 that also had a silver interior, it appeared original and wasn't fawn underneath when it was sanded down.
