12-15-2012, 12:43 AM | #1 |
Factory Rear Sway Bar
EDIT: AS OF MAY 15TH 3RD ONE AVAILABLE...FREE SHIPPING!
This is the identical one pulled from a 1 ton as the ones that member 1774btcrew sold recently. This is the first one I have come across so I think they are pretty rare. I was able to save the u bolt saddles, u bolt spacers, and 2 of the extra long ubolts all of which are included. You will need 2 u bolts and probably new rubber bushings. $150 plus shipping. Thanks, Ray Last edited by KrazyRay; 05-15-2013 at 07:03 PM. |
12-15-2012, 01:42 AM | #2 |
GM Addicted
Re: Factory Rear Sway Bar
Ray think this would work with a flipped axle?
..Mac’s Garage.. 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
12-15-2012, 11:31 AM | #3 |
It would have to go on top and there would not be enough clearance to the frame.
12-26-2012, 06:15 PM | #4 |
Ttt
01-21-2013, 11:34 PM | #5 |
Sale pending to member undr8ed.
Thanks, Ray |
01-22-2013, 01:42 PM | #6 |
Ray,
Glad you got it sold.
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
05-05-2013, 10:12 AM | #7 |
ttt still available undr8ed did not follow through.
05-05-2013, 01:14 PM | #8 |
72 BB C30 Super LongHorn
I have a standard 73 3/4 longbed C/20.
Will this correctly bolt into my truck? I just need to know that it is correct for my truck before I can commit to taking it. Let me know...THX
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS |
05-06-2013, 10:03 AM | #9 |
Yes. It will bolt to your truck. You might have to drill a hole on each side of the frame for the studs to mount on to.
Thanks, Ray |
05-06-2013, 10:32 AM | #10 |
Ok then.
Nothing missing, correct? PVT mssg me the details on paying you. Thx Posted via Mobile Device
05-13-2013, 08:29 PM | #11 |
Here's a 2nd one...$150 with free shipping!
You will need u bolts, washers, nuts and probably new rubber bushings all should be readily available at the store. |
05-13-2013, 08:43 PM | #12 | |
Is it the "flipped" part that makes this unusable on lowered trucks, or is it all lowered trucks?
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
05-13-2013, 09:40 PM | #13 | |
05-14-2013, 12:12 AM | #14 |
I think it is the "flipped axle" that would be the problem because the sway bar goes on the opposite side of the axle from the leafs. So if the leafs were on the bottom of the axle, then the sway would be on top and end up hitting the frame. If you use lowering springs or shackles, the sway bar should work fine. You might have to cut the frame mounting sleeves down to square it up with the lowered truck.
05-15-2013, 07:02 PM | #15 |
2nd bar sold pending payment. Thanks!
I have another bar available. |
11-13-2013, 02:28 PM | #16 |
ttt for midunes
11-13-2013, 06:33 PM | #17 |
Paypal sent look forward to installing this
Thx |
