Old 04-30-2013, 08:49 AM   #1
68_Step
Spare Tire Mount - In Bed
If you were mounting a spare tire in the bed of the truck, which back corner would you mount it in? Driver or Passenger side? I have already picked up a mount from LMC, just have to decide where to put it. I have a bed box, so I would like to avoid the front corners. I did a mock-up mount last night with it on the drivers side, pics below. By the way, the mount from LMC looks to be of good quality.
68_Step is offline   Reply With Quote
Old 04-30-2013, 09:04 AM   #2
Sammy
Re: Spare Tire Mount - In Bed
Drivers side like you have it mocked..with the exception of the three holes you can leave bolts in you can move it later.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 04-30-2013, 09:13 AM   #3
KellerMAC
KellerMAC's Avatar
Great mock up 68_Step - I have recently received a mount from LMC and was wondering where it would look the best - it looks like the truck was design with that spot in mind - the the tire and wheel seem to fit perfectly behind the wheel well.
Btw, does the family love themselves some Kikoman Soy Sauce or what? JK
Please post some pictures once you have it installed.
Texas - Don't Let The Size Scare You!
KellerMAC is offline   Reply With Quote
Old 04-30-2013, 10:26 AM   #4
68_Step
I also have 5 gallon buckets (empty!) of "Heavy Duty" mayonnaise . My son-in-law manages a oriental steak house - I get a never ending supply of food safe buckets. Mighty handy for a small farm...
I am planning on installing later this week or Saturday. Will post pics.
Old 04-30-2013, 01:20 PM   #5
SS Tim
SS Tim's Avatar
MY 72 C10 had an aftermarket in that location and it worked out well. The stock location on both the short and long beds was just forward of the left wheelhouse.
But having it in the left rear also proved very useful and a convenient place to stash stuff behind like gloves, tire chains and tie-downs out of your normal sight line.
SS Tim is offline   Reply With Quote
Old 04-30-2013, 03:34 PM   #6
Sammy
I had one in the front driver's side before. Sorta liked it didn't block my view there. Rear corner I think is fine.
Old 04-30-2013, 03:38 PM   #7
tommys72
tommys72's Avatar
That does look good, and a lot easier than under the bed too
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 04-30-2013, 03:44 PM   #8
JointTech
JointTech's Avatar
id do drivers just because when you look over your right shoulder it wont be in your view or hiding that car you are about to run into.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 05-09-2013, 08:39 AM   #9
68_Step
Mounting was a breeze. 3 carriage bolts - but I must admit I was a bit surprised at the 10mm bolts for a 67 Chevy mount!
Old 05-09-2013, 09:23 AM   #10
KellerMAC
KellerMAC's Avatar
Looks great - I see you have a lock on it - what are you locking to?
Great job,
KellerMac
Old 05-09-2013, 01:21 PM   #11
'71 Flame
'71 Flame's Avatar
One could use one of these to scure the wheel.
'71 Flame is offline   Reply With Quote
Old 05-09-2013, 01:54 PM   #12
68_Step
Great job,
KellerMac
Thanks!
What am I locking it to? Not much The LMC kit came with a steel loop that fits over the lug nut - it has a hole in it that lines up with a hole in the black bar that holds the tire in place, lock goes thru both holes. If they are more than a little determined the tire is gone, but last night the lock was handy.
Old 12-03-2013, 11:21 PM   #13
520CheyenneK10
Thinking of getting one of these from LMC for my rig too. 73' Short bed K10
520CheyenneK10 is offline   Reply With Quote
Old 12-04-2013, 12:10 AM   #14
LockDoc
The Older Generation
LockDoc's Avatar
You could always do this...
LockDoc
Leon
Old 12-04-2013, 09:07 AM   #15
MoFormula
That is very cool.
LockDoc
MoFormula is offline   Reply With Quote
Old 12-04-2013, 02:18 PM   #16
mrein3
mrein3's Avatar
LockDoc
For what its worth, my truck came with a spare tire carrier on BOTH sides of the bed, behind the back wheel wells. I had a heck of a time seeing cars over my right shoulder. Since I don't travel where you need two spares like the PO of my truck, I removed the one on the passenger side. You definately want to mount that on the driver's side. Unlike the cell phoners and texters out there on the highways and byways I still care about my fellow travelers.
LockDoc - great idea. The only draw back I can see is does that hinder you from hauling 4x8 sheets of plywood or similar? I still need to use my truck as a truck.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 12-04-2013, 03:14 PM   #17
LockDoc
LockDoc's Avatar
Not my trucks but it shouldn't stick out any farther than the wheel tub...
LockDoc
Leon
