Old 12-13-2013, 05:30 PM   #101
SCOTI
SCOTI's Avatar
Re: How bout some pictures of '73-'87 regular cab dually
Originally Posted by RustedMetal View Post
Sorry guys, The tires are 235/55/19's all around. The wheels are Eagle Alloys. I dont know if they were 19.5's or what.
One more time.... The 235-55's are @ all 4 corners. If you wouldn't mind verifying, what size are the inner rears?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-15-2013, 09:47 PM   #102
clunker
clunker is offline   Reply With Quote
Old 12-17-2013, 05:13 PM   #103
TheChief
any one using the hanger/shackle kit to lower the rear? how much does it really lower by removing the overload leaf and this combo? and if using a flip kit i read it 8" is a notch really neccesary?
08 cc silverado dropped on 24's
82 1 ton c30 Dually
TheChief is offline   Reply With Quote
Old 12-17-2013, 06:22 PM   #104
SCOTI
SCOTI's Avatar
Shackle & hanger combo's typically yield 4" of drop. Removing the helper leaf is prob 1" or less.
When I measured my CC dually for the flip kit it would have left me w/about 1" between the axle tube & the bottom of the frame & a similar amount between the top of the differential (Dana 70HD) & the bed floor.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-17-2013, 06:24 PM   #105
SCOTI
SCOTI's Avatar
Clunker.... What the stats on your build (drop, wheel/tire sizes, mods, etc...)?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-17-2013, 06:40 PM   #106
fun in dirt
fun in dirt's Avatar
Sold about 8 yrs ago & guy just let it set up. Now the new owner has contacted us for details on its build & very excited to have it....good to see someone appreciate it again!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 12-18-2013, 01:09 PM   #107
TheChief
im trying to lower mine single cab and still be able to tow a car trailer, would i still be able to with a flip kit?
82 1 ton c30 Dually
Old 12-18-2013, 02:23 PM   #108
SCOTI
SCOTI's Avatar
No 2 trucks are exactly the same. Knowing there's possible differences & w/o looking @ your exact set-up I'm only answering based on what my truck indicated.
Based on mine, shackle & hangers would work w/a air over leaf helper & stock frame rails for sure. With a flip kit, notching the frame would have been mandatory. But if that was done, towing wouldn't have been an issue since nothing was changed other than the flip.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-18-2013, 02:26 PM   #109
TheChief
gotcha, thanks for the fast responce
82 1 ton c30 Dually
Old 12-18-2013, 04:30 PM   #110
clunker
Stats on my truck. Porterbuilt dropmember upper and lower control arms, and sway bar, 3" western chassis drop spindles. Front tires are going to be 265/40/22. Rear is triangulated four link, 3800# bags behind axle, dana 70hd narrowed 4", big notch. Rear tires are 305/45/22
Old 12-18-2013, 06:58 PM   #111
SCOTI
SCOTI's Avatar
Nice list.... Cool looking set-up from the single pic.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-18-2013, 08:53 PM   #112
clunker
Couple more pics
Old 12-18-2013, 08:55 PM   #113
clunker
Old 12-18-2013, 10:21 PM   #114
witdogg
Looking for a clean low mileage 73-87 single cab dually 2wd. I'm located in California but if the truck is right I will buy anywhere in the US. Must be clean, real clean.
This thread is full of great looking trucks, and this is a cool site. Glad to be here.
witdogg is offline   Reply With Quote
Old 12-18-2013, 11:40 PM   #115
SCOTI
SCOTI's Avatar
Very nice Clunker!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-19-2013, 06:15 PM   #116
LOW1TON
Nice setup clunker! thats going to be a very cool truck. I like the fact you are running a taller tire in the front and rear than are usually ran. keep the pictures and progress coming.
"WIDER IS BETTER" (TRUCKS ONLY)
LOW1TON is offline   Reply With Quote
Old 12-19-2013, 10:17 PM   #117
Don SC
Don SC's Avatar
Man. That framework and suspension is totally awesome Clunker. Thanks for sharing!
Don SC is offline   Reply With Quote
Old 12-23-2013, 04:00 PM   #118
TheChief
any one flipped a rear that has the casted spring perches?
82 1 ton c30 Dually
Old 12-30-2013, 09:45 AM   #119
RustedMetal
RustedMetal's Avatar
Sorry, not on here much. Pretty sure the inners may be stock wheels. I will look when I get home for you. Sorry for the delayed response.
Also my truck has the stock 4.10 gear and at 65mph she is screaming. Should I go with a 3.73 or 3.42? Makes the truck not enjoyable to drive if you have to avoid interstates. lol
1979 C30 Single cab Dually, 454, th400, dropped on 19's.
RustedMetal is offline   Reply With Quote
Old 01-11-2014, 12:52 AM   #120
rs74
rs74's Avatar
Here is a few more off craiglist.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 01-11-2014, 01:51 AM   #121
Tydemater
Tydemater's Avatar
Those all look good.
1985 Chevy cab and chassis. Flatbed 4 speed 350
Tydemater is offline   Reply With Quote
Old 01-11-2014, 09:17 AM   #122
cochino12
It followed me home?
cochino12's Avatar
I just bought this on CL a few days ago to flip, if it doesn't sell in a couple weeks its may get DD duty for me.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 01-11-2014, 09:56 AM   #123
rs74
rs74's Avatar
Same guy owns all of them and are listed on Topeka craigslist. What a lucky guy to be able to own a herd of these squares as nice as those.
Roy
1987 R10 shortie
Old 01-14-2014, 12:26 AM   #124
Bczik84
I just found a 77 on Craigslist looks kinda rough but its a factory black it red interior truck and those look so goodfixed up
Bczik84 is offline   Reply With Quote
Old 01-17-2014, 12:38 AM   #125
TheChief
can someone tell me what shocks to use with the wester chassy flipkit, 82 c30
82 1 ton c30 Dually
