#1 | |
Re: 1996 GMC K3500 DRW, Extended Cab, Flatbed, 454, NV-4500
![]() Nothing much as of late to report, just these. February 3, 2016 ![]() February 20, 2016 ![]() March 3, 2016 ![]() March 17, 2016 ![]()
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
denali/escalade cluster?
putting the miles on, nothing wrong with driving it!
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
#3 | |
Just about every other day is a fill-up and ~250 miles on the trip.
![]() Join Date: May 2004
Love the led look! Was it all that hard to change out?
76/77/78 Cheyenne 1997 K3500 454 soon to be 496 |
Hey, that is an amazing truck that you got there. I got the same NV4500 transmission in my 1972 GMC C30 but nobody on this forum (nor Google himself :-() was able to tell me what PTO will work on the 1996 NV4500. Is there any way you can check the PTO part number on your truck? Please :-)
#6 | |
Thanks for the PM. I gonna post this for reference. 99-00 GMT800 knuckles have a different tie rod taper than 01-07. It is very hard to locate a set of used 99-00 knuckles, and they are superseded to the later ones by gm. I already have a set of 01-07 knuckles.
I will most likely have a GMT400 outer tie rod shortened and machined to M14, and use a standard 01-07 outer tie rod. When I do this, I will post a build thread and parts used. |
Just found this looking for cab swap ideas. I have a 98 k2500 and my only thing I'd the wiring. The 98 is a 6.5 TD and my parts 97 k1500 is a 5.7L. how did you go about the wiring?
Big Nate Carp. Local 224. Buy made in the USA! 03 F350 6.0 Daily Race Truck. 79 C70 366 Project Dump. |
Swapped all of my wiring into the donor cab. Pulled both dashes, set them on sawhorses, removed the ducting and parts I needed to give me access to the harness and swapped them.
Awesome. So it separates then under the dash somewhere? I'm familiar with the 73-87 wiring just not anything this new.
