View Poll Results: If you had the option, which of these grills would you use?
Original 66 painted grill 1 20.00%
64-66 C60 painted grill 2 40.00%
an original aluminum grill that needs to be restored 2 40.00%
the repo aluminum grill that is now available 0 0%
Voters: 5. You may not vote on this poll
Old 12-06-2013, 09:50 PM   #351
chevyrestoguy
chevyrestoguy's Avatar
Re: pdx-sanity66
I really like where you're going with this truck. A nice dependable drivetrain combination, and a very slick use of other parts from different vehicles. This is my kind of build!
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 12-07-2013, 06:09 AM   #352
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Originally Posted by Ta2Don View Post
Great work on that Console lid...
Thanks, Don.
Originally Posted by 66farmer View Post
Looking good keep up the good work.
Thanks, man. You did quick work on that suspension mod and the truck looks much better.
Originally Posted by bj383ss View Post
PDX great job on the bead blasting. Are you using a cabinet? Also where do you get you glass beads in different grits?
Bret
Sorry on the mix up the way I wrote what I did. I actually just used an 80 grit glass bead and then the rest was hand sanded to the point it is now. I use the cabinet that I made out of a 55 gal drum and I get my blasting media from a local outfit here in Portland. Very inexpensive compared to retail outfits. I think I paid about $10-$15 dollars for a 50lb bag.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 12-30-2013, 02:07 AM   #353
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
I don't really have anything to show for the last week or so but I have been doing a little work on Sanity. My new trans came with a black paint job that didn't match my vision and there was some casting crud on the case so I decided to strip it all off and prep and paint it over with Eastwood's aluminum paint. The stripping and sanding is done but I ran out of time to get it sprayed. I hope to get it done on Wednesday.
Other than that, I chased down some nuts and bolts I needed and cleaned up the shop. Once the paint dries on the trans I'm pretty much ready to get it mated to the engine and get them installed in the chassis.
Sanity'66
Old 12-30-2013, 04:25 AM   #354
Frizzle Fry
Frizzle Fry's Avatar
Re: pdx-sanity66
Been researching panting cast aluminum myself. Decided to go the route described in post #9 here. Are you going to use a clear coat?
Frizzle Fry is offline   Reply With Quote
Old 12-30-2013, 05:03 AM   #355
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Hey man, good to hear from you. I tried the diamond clear on another piece of cast aluminum and didn't really like the look. Eastwood's Alumablast, however, looks very nice. I painted my serpentine brackets with it and I really like it so that's what I'm going with on the trans.
Sanity'66
Old 12-30-2013, 12:42 PM   #356
TJ's Chevy
TJ's Chevy's Avatar
Re: pdx-sanity66
Looks good but.....it is kinda hard to imagine what it looks like...I mean you know....maybe a picture or two...or three....
Old 01-02-2014, 10:53 PM   #357
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Here's the transmission stripped, sanded, and painted. I also bolted up the flexplate to the engine. The trans needs one more day for the paint to cure enough to mess with it. Hopefully tomorrow the trans will be hooked up to the engine and maybe they'll both get moved into their new home between the frame rails.
Sanity'66
Old 01-03-2014, 07:36 AM   #358
bj383ss
bj383ss's Avatar
Re: pdx-sanity66
Looks great. What brand are using to hookup the 700R4 throttle valve and lockup with?
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 01-03-2014, 05:50 PM   #359
rusty76
rusty76's Avatar
Re: pdx-sanity66
Looks good
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 01-05-2014, 04:08 PM   #360
NurseBen
NurseBen's Avatar
Re: pdx-sanity66
Truck looks very nice. I hate to impose on your build thread but do you have a Suburban for sale in the ad section? Please feel free to PM me with info, thank you, Ben.
NurseBen is offline   Reply With Quote
Old 01-10-2014, 07:53 PM   #361
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Bret
Thanks, I haven't decided yet on the hookups. I've looked at several.
Originally Posted by rusty76 View Post
Looks good
Thanks. I'm pretty excited about getting to this stage.
Thanks for looking in. I sent you a PM about the Sub.
The latest update. The engine and trans are in. I still have to drill the holes and bolt in the trans crossmember but seeing it all sitting in there gives me great motivation to continue on.
Sanity'66
Old 01-10-2014, 07:54 PM   #362
rusty76
rusty76's Avatar
Re: pdx-sanity66
We're slowly starting to see the light at the end of the tunnel. Awesome man.
My build thread
Crossmembers CC
Old 01-10-2014, 11:16 PM   #363
Bomp
Bomp's Avatar
Re: pdx-sanity66
Congrats on getting the motor in. Now slap some fenders on and lets go for a ride.
Bomp is offline   Reply With Quote
Old 01-10-2014, 11:20 PM   #364
bj383ss
bj383ss's Avatar
Re: pdx-sanity66
Looks awesome. Good motivation for me even though I am way behind you. I'm going in the opposite direction. Just pulled both of mine out.
Bret
Old 01-11-2014, 09:39 AM   #365
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: pdx-sanity66
I don't know how I missed this great thread all this time.
One question though. Earlier in the thread you said you didn't know what ratio your rearend was. How did the transmission man set up your 700R4 speedo gears without knowing what ratio you're running ? The only reason I point this out is that it would be easier to deal with that issue now, rather than later when the trans is full of fluid and you're having to crawl under there and swap speedo gears to get it right.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 01-11-2014, 11:14 AM   #366
Ta2Don
Ta2Don's Avatar
Re: pdx-sanity66
Engine and Trans at home...
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 01-11-2014, 03:10 PM   #367
coulter
coulter's Avatar
Re: pdx-sanity66
that engine and trans looks right at home man!!! it looking good man keep it up
bagged 66 longbed build
http://67-72chevytrucks.com/vboard/s...d.php?t=449548
my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918
coulter is offline   Reply With Quote
Old 01-12-2014, 07:22 PM   #368
TJ's Chevy
TJ's Chevy's Avatar
Re: pdx-sanity66
That engine and trans look like they are meant to be in there! Man that looks sharp! Great work!
Old 01-13-2014, 02:48 AM   #369
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
You know how slow I am. You'll probably beat me at getting a running truck.
Bret
Thanks man. It's been a long time coming.
Thanks for looking in. At the time of ordering the trans I wasn't sure what I had for a rear end so I had them put a speedo gear based on a 4:11 rear. Since then I discovered that the rear is a 3:73. The trans shop said they would swap me when I knew for sure what I had but I had forgot that until you mentioned it so thanks for saving me a hassle.
Thanks, Don.
Thanks for the encouragement, man
Thanks T.J. If you get a chance to get to Portland/Gresham you'll have to stop by.
Sanity'66
Old 01-13-2014, 12:01 PM   #370
Jeff La
Re: pdx-sanity66
Like the way the trans looks, better than new and it all looks great sitting in there getting ready to go
Jeff La is offline   Reply With Quote
Old 01-15-2014, 08:39 AM   #371
REEDS 72
REEDS 72's Avatar
Re: pdx-sanity66
Brett, motor&trany looks killer, that's got to be nice to have them in place. Your truck is coming together very nice, not much longer. I can see you and Joanne getting in it and going to breakfast on a nice Sunday moring, anyway it really does look great and a super good build thread on it, I hope you guys had a good Christmas and a happy New Year! Tell the boys hello from us and I will get my build updated ASAP Reed.
REEDS 72 is offline   Reply With Quote
Old 01-24-2014, 06:24 AM   #372
63sbssbbw
UCA63
63sbssbbw's Avatar
Re: pdx-sanity66
Looking awesome Brett
Keep up the good work
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 01-24-2014, 10:27 AM   #373
bj383ss
bj383ss's Avatar
Re: pdx-sanity66
Are you going to run a carb or fuel injection?
Bret
Old 01-24-2014, 10:42 AM   #374
siggyfreud
siggyfreud's Avatar
Re: pdx-sanity66
Looking great. I'm also behind you, at the point of (hopefully) pulling the motor and trans from the frame today .
siggyfreud is offline   Reply With Quote
Old 01-24-2014, 03:07 PM   #375
McMurphy
McMurphy's Avatar
Re: pdx-sanity66
I remember when I was at this stage.... Hang in there buddy.
In the end, it is ALL worth it !!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
