Old 01-08-2014, 11:20 AM   #1
Flatpat
Flatpat's Avatar
'88 Jimmy with 5.3
Well, I had a friend who really wanted a TDI Jetta I had so he sweetened his offer with a ’88 Jimmy he was using for parts on his ’86 Blazer. I had a 5.3l out of a wrecked ’02 Tahoe I acquired in previous trades. I was looking to put it in something so fate brought it all together.
The Jimmy didn’t run very well, didn’t have interior, and had a mixed set of bald (2 of them flat) tires. It did have 6” lift springs on it though. A search through CL and $250 later I had a used set of 36” swampers (about 25% left) with aluminum wheels. I also grabbed some new shocks for it from Offroaddesigns.
I used motor mount adapters and the 700r4 adapter kit from Advance Adapters. It was almost a drop in affair. I did have to remove the passenger side exhaust manifold to get it in. I reused the stock radiator with mechanical fan. I’m not running a heater so I capped the feed from the pump and adapted the steam vent to the return. Put in a EP-381 fuel pump and used some metric to AN adapters from the fuel lines and AN to LS fuel rail adapters to get it fuel. I reworked the 5.3 harness and stock fuse block using the guides from LT1swaps, pretty simple after I got my head around it. Runs really good and uses a lot less fuel than the other trucks out mudding with me.
It’s pretty much for chits and grins. I finished it the weekend before I headed to Afghanistan.
My friends and family took it out over the Christmas break. Still running great! Here’s my friends 5 year old driving in the mud with his Aunt.
Flatpat is offline   Reply With Quote
Old 01-09-2014, 01:25 PM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: '88 Jimmy with 5.3
That's a sweet toy for something you made out of what showed up. Do you know what gears it has?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 01-09-2014, 02:01 PM   #3
Flatpat
Flatpat's Avatar
Honestly I didn't look, they don't feel real low so maybe 3.73s. I'm planning on swapping a D60 and 14B when I get back.
