#101 |
Re: How bout some pictures of '73-'87 regular cab dually
One more time.... The 235-55's are @ all 4 corners. If you wouldn't mind verifying, what size are the inner rears?
#102 |
#103 |
any one using the hanger/shackle kit to lower the rear? how much does it really lower by removing the overload leaf and this combo? and if using a flip kit i read it 8" is a notch really neccesary?
08 cc silverado dropped on 24's 82 1 ton c30 Dually |
#104 | |
When I measured my CC dually for the flip kit it would have left me w/about 1" between the axle tube & the bottom of the frame & a similar amount between the top of the differential (Dana 70HD) & the bed floor.
#105 |
Clunker.... What the stats on your build (drop, wheel/tire sizes, mods, etc...)?
#106 |
Sold about 8 yrs ago & guy just let it set up. Now the new owner has contacted us for details on its build & very excited to have it....good to see someone appreciate it again!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
#107 | |
im trying to lower mine single cab and still be able to tow a car trailer, would i still be able to with a flip kit?
#108 | |
Based on mine, shackle & hangers would work w/a air over leaf helper & stock frame rails for sure. With a flip kit, notching the frame would have been mandatory. But if that was done, towing wouldn't have been an issue since nothing was changed other than the flip.
#109 | |
gotcha, thanks for the fast responce
#110 |
Stats on my truck. Porterbuilt dropmember upper and lower control arms, and sway bar, 3" western chassis drop spindles. Front tires are going to be 265/40/22. Rear is triangulated four link, 3800# bags behind axle, dana 70hd narrowed 4", big notch. Rear tires are 305/45/22
#111 | |
#112 |
#113 |
#114 |
Looking for a clean low mileage 73-87 single cab dually 2wd. I'm located in California but if the truck is right I will buy anywhere in the US. Must be clean, real clean.
This thread is full of great looking trucks, and this is a cool site. Glad to be here. |
#115 |
Very nice Clunker!
#116 |
Nice setup clunker! thats going to be a very cool truck. I like the fact you are running a taller tire in the front and rear than are usually ran. keep the pictures and progress coming.
"WIDER IS BETTER" (TRUCKS ONLY) |
#117 |
Man. That framework and suspension is totally awesome Clunker. Thanks for sharing!
#118 |
any one flipped a rear that has the casted spring perches?
#119 | |
Also my truck has the stock 4.10 gear and at 65mph she is screaming. Should I go with a 3.73 or 3.42? Makes the truck not enjoyable to drive if you have to avoid interstates. lol
1979 C30 Single cab Dually, 454, th400, dropped on 19's. |
#120 |
![]() Join Date: Jun 2010
Here is a few more off craiglist.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
#121 |
1985 Chevy cab and chassis. Flatbed 4 speed 350 |
#122 |
It followed me home?
I just bought this on CL a few days ago to flip, if it doesn't sell in a couple weeks its may get DD duty for me.
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
#123 |
Same guy owns all of them and are listed on Topeka craigslist. What a lucky guy to be able to own a herd of these squares as nice as those.
#124 |
I just found a 77 on Craigslist looks kinda rough but its a factory black it red interior truck and those look so goodfixed up
#125 |
can someone tell me what shocks to use with the wester chassy flipkit, 82 c30
