01-13-2014, 01:21 AM | #1 |
1990 Suburban fuel line issue
I am working on a 1990 Suburban with my nephew. Our issue is the fuel line from the fuel filter up to the braided stainless part is rotted out. I have been looking for this line and haven't had any luck. I cant flare the end at the stainless since the line is junk right up to the stainless. GM has discontinued this line, so do any of you know where I can get one? LMC doesn't have it either.
Support your local search and rescue team.... GET LOST! Originally Posted by DURRTY if some is good more is better too much ought to be enough........ |
01-13-2014, 09:53 PM | #2 |
Re: 1990 Suburban fuel line issue
Most auto parts stores have a pre flared line kits that come with 3/8 compression fittings. You can also get a hydraulic hose shop to make you a length of stainless flexible line with 3/8 compression fittings on either end.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
01-14-2014, 12:09 AM | #3 |
Thank you.
I'll try that.
