#76 |
Re: 47 Step van
Shannon
48 Panel Truck 1948 Chevy / S10 1954 Chevy / S10 1951 Chevy / C4 47 Step van Lowered 1996 Dually |
#77 |
![]() Join Date: Mar 2011
Re: 47 Step van
Hey Shannon, what gauges are you running in the van...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#78 |
Re: 47 Step van
the metal magician is at it again!!
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#79 |
Re: 47 Step van
Oldman3, the main gauges are dolphin brand and the air ride are air lift brand.
99 to life, thank you. Tomorrow I will get the steering back together now that everything is painted. I also want to mount the pro portioning valve and finish up the brake lines. I will have pictures tomorrow. Shannon
#80 |
Re: 47 Step van
I made the rear master cylinder mount because there was some flex in it. Then I mounted the pro portioning valve. After that I made my brake lines to where I did not finish when I did the frame. I had bought a blue point flare kit and it works great if anybody is looking for a good one. I then put the steering all back together. I only thing I had to put in is the steering column. I was able to put the wheel well back in too.
Shannon
#81 |
Re: 47 Step van
Shannon
#82 |
Re: 47 Step van
This is a very cool build with lots of impressive fabrication too! What ever happened to the 6 cylinder?
87 Crewcab Dually 66 Cadillac Sedan deVille 55 Chevy Belair 33 Plymouth sedan 03 S-10 86 S-10 Blazer _____________________________________________ IG drivewaycustoms |
#83 |
Re: 47 Step van
Drivewaycustoms, thank you, I do not know if it came with the motor when Ken bought it.
Shannon
#84 |
Re: 47 Step van
Shannon
#85 |
Re: 47 Step van
More pictures
Shannon
#86 |
Re: 47 Step van
Last ones.
Shannon
#87 |
Re: 47 Step van
Shannon, looks great...Jim
#88 |
![]() Join Date: Oct 2007
Re: 47 Step van
Shannon what size step die do use on your floor pans and gauge of metal? Your work looks fantastic. Another question do you have any issues with putting a bead in a transmission tunnel then running it through the slip roll to give a curve. Thanks for the tips you give and the work you do.
Ryan |
#89 |
Re: 47 Step van
wickid demon, I made both 1/8 and 3/16 step dies for my bead roller. On my steel floored projects I use .o60, or 16 gauge. This truck is aluminum and is 14 gauge or .080 thick. Big thing in doing it is making to tight of a radius, because it wants to drag on the edge of the die and shears the corner. I use the lid from the smaller coffee cans for the template for my corners. On the tranny tunnels, when you put it in the slip rolls it does flatten out the indented part but the line from the bead roller is still there. No problem on the tips, always glad to help everyone.
Shannon
#90 |
Re: 47 Step van
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#91 | |
Re: 47 Step van
Shannon , AKA Metal Master ...sweet work as usual !!
48 GMC Burb 51 Chevy AD 3100/C 4 byShannon 74 Chevy P 10 48 Double Duty 04 SS Burb 01 Springer HD |
#92 |
Re: 47 Step van
_Ogre, haha, it was nice when you could post 5 pictures at once. Now with the resized photobucket one sometimes you can not even do two.
48 GMC BURB, thank you, that is right you did have the engine and tranny. Well nothing done on the truck outside in the driveway because it was like high of 15 degrees today. I am so over this cold snowy weather, and spring can not come soon enough. So I was working on some stuff inside my heated garage. The truck was missing the side cowl. So I made an air scoop for it. It will have a sliding closer in the inside of the cab so that the fresh air will be able to come it. I still have to cut out the hole on the back side but other than that the outside is done except for a little sanding. Shannon
#93 |
Re: 47 Step van
Pictures
Shannon
#94 |
Re: 47 Step van
More pictures
Shannon
#95 |
Re: 47 Step van
Last ones
Shannon
#96 |
Re: 47 Step van
Shannon that scoop turned out awesome. Your attention to details are second to none.
#97 |
Re: 47 Step van
Shannon, they will know you didn't pick that up at the local hot rod store, super nice job...Jim
#98 |
Re: 47 Step van
Wickid demon, thank you.
Oldman3, thank you. I still have to mount it. I used some duct tape on the back to hold it there. Had to see how it looked. Shannon
#99 |
Re: 47 Step van
Shannon, Build is looking great. My first time seeing the offset steering, looks solid.
Shawn
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=582647 |
#100 |
Re: 47 Step van
awesome, so sick. did you perforate that or can you buy it like sheets like that?
