Old 02-27-2014, 03:48 PM   #1
ooimpalaoo
ooimpalaoo's Avatar
pinion angle? level truck?
Hello once again ...i know my truck needs to be at ride hight to set pinion angle ..but does my truck have to sit level. im working on a unlevel floor. and once again thanx to everyone for building my truck...
ooimpalaoo is offline   Reply With Quote
Old 02-27-2014, 04:06 PM   #2
tinydb84
tinydb84's Avatar
Re: pinion angle? level truck?
Do you have the trans in? If so just match the trans angle with the pinion angle.
David
Instagram: myfabguy
Old 02-27-2014, 04:42 PM   #3
ooimpalaoo
ooimpalaoo's Avatar
yes tranny is in ...so i dont need dto have the frame level? just at ride hight and set/weld?
Old 02-27-2014, 05:26 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
pinion angle is about the angles between the trans, drive shaft and rear. You could do it on a hillside it doesn't change the drive shaft to pinion angles.
What does matter is it the ride height being where you want it and is it at the curb weight you want. Don't set it and then decide to put the 800 lbs bed on it.
Old 02-27-2014, 06:07 PM   #5
imjeff
imjeff's Avatar
Spot on. Transmission output and pinion should be offset, but parallel. This gives you equal and opposite joint angles.
Jeff
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 02-27-2014, 09:26 PM   #6
wraprail
wraprail's Avatar
Trans output should be around 3 degrees down and pinion should be the same angle only pointed up, with the frame at ride height. Usually the frame is level at ride height unless you live in Kentucky and drive a ford
maybe.
wraprail is offline   Reply With Quote
Old 02-28-2014, 12:41 AM   #7
ooimpalaoo
ooimpalaoo's Avatar
at ride hight my tranny is at +5 so do i set my pinion at -5 ?,oh and my truck has 2 shafts..sorry
Old 02-28-2014, 12:45 AM   #8
tinydb84
tinydb84's Avatar
Can you raise the tranny a bit to get it closer to -3?
David
Instagram: myfabguy
Old 02-28-2014, 12:49 AM   #9
ooimpalaoo
ooimpalaoo's Avatar
the motor and trans are bolted down.. i added air bags and so i have a diff ride hight.. can i add i shim to the rear trany mount to raise it?
Old 02-28-2014, 12:56 AM   #10
tinydb84
tinydb84's Avatar
Yep. Probably only need 1/2 an inch
David
Instagram: myfabguy
Old 02-28-2014, 01:02 AM   #11
ooimpalaoo
ooimpalaoo's Avatar
i was driving this truck on bags. then did the rear swap to a five bolt. the trany was in the spot it is now and it was great down the road..
Old 02-28-2014, 01:12 AM   #12
ooimpalaoo
ooimpalaoo's Avatar
just want to get it back on the road because i start a new job in 4 days..need to weld her up tomorrow..i hope
Old 02-28-2014, 01:34 AM   #13
ooimpalaoo
ooimpalaoo's Avatar
just found this ...look right?
Old 02-28-2014, 01:35 AM   #14
tinydb84
tinydb84's Avatar
You have a one or two piece drive shaft?
David
Instagram: myfabguy
Old 02-28-2014, 01:37 AM   #15
ooimpalaoo
ooimpalaoo's Avatar
2 piece. oh and thanx for the help tinydb84
Old 02-28-2014, 01:40 AM   #16
tinydb84
tinydb84's Avatar
All the info before is based on a one piece. Mine was 4 down and 4 up in the rear. The driveline was 6.5 for the first and second piece. Both pointing down to the rear.
David
Instagram: myfabguy
Old 02-28-2014, 01:46 AM   #17
ooimpalaoo
ooimpalaoo's Avatar
ive heard that the rear should be down because when driving it will rise.. as of now my front is +5 and my rear is -5.. the shafts look like a V from the side.. just like the pic
Old 02-28-2014, 02:45 AM   #18
dwcsr
Hollister Road Co.
dwcsr's Avatar
If you have trailing arms that does not apply.
Old 02-28-2014, 03:02 AM   #19
ooimpalaoo
ooimpalaoo's Avatar
yes i have the stock trailing arms...so what do i want to do?
Old 02-28-2014, 03:05 AM   #20
tinydb84
tinydb84's Avatar
Read this starting page 10
http://www2.dana.com/pdf/J3311-1-DSSP.pdf
David
Instagram: myfabguy
air bag, c10 2wd fleetside longbed, level, pinion angle, ride height
