02-28-2014, 01:37 PM | #276 |
Re: What did you do to your truck today? Chapter II
Fabricated and installed a polished stainless steel radiator cover.
02-28-2014, 02:08 PM | #277 |
Looks good Fitz! How long did it take you?
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
02-28-2014, 04:47 PM | #278 |
03-01-2014, 08:29 AM | #279 |
Ready to be put back into service...but, I had a smidgen of forethought as far as spark plug wiring is concerned. Im looking for a "clean" appearance. Considering i just painted the engine and frame. I have hedman long tube headers, already piped to fit, and it seems I have a routing issue with #5 & #6 plugs. the primary tubes from #1 & #2 run so close to the plugs that the wire looms I have won't allow the boot (taylor cut to fit red wires with 90° boot) any clearance at all, were talking 1/8" max. I can only imagine doing this if it was in the truck! So I'm faced with a dilemma. I have a lot of "bling" on top, and I just picked up the wires. I would really like to show off both. Different headers are not out of the question, nor is different wiring, considering I haven't cut any wires yet. Any input is well received!...
1972 C/10 LWB - Mine 1964 C/10 LWB - My Dad's Instagram: Mike_The_Grad Last edited by Mike_The_Grad; 03-01-2014 at 08:32 AM. Reason: amendment |
03-01-2014, 09:56 AM | #280 |
I avoided that problem with my headers by using 45 degree plug boots and the GM wire looms. Should work on yours too.
03-01-2014, 01:44 PM | #281 |
Thanx Fitz. I thought of 45° boots also.But I think I have a solution.I'm gonna try header wrap and just go a little beyond the boots. Plus side is I won't have to wire wheel and paint the headers.
1972 C/10 LWB - Mine 1964 C/10 LWB - My Dad's Instagram: Mike_The_Grad |
03-02-2014, 01:36 AM | #282 |
I repainted my dash bezel today. I used Rust-Oleum black hammered paint & I used silver metallic enamel for the outside trim. I used a silver metallic Sharpie to outline the letters with.
"Now all I need is a shop to go with my shop vac!" |
03-02-2014, 08:35 AM | #283 | |
1970 C10 Short Stepper with 71/72 front clip. |
03-02-2014, 11:29 AM | #284 |
What is a shortie spark plug ?
03-02-2014, 12:12 PM | #285 |
laying low
They are spark plugs that are shorter in overal length to give more room between the header tube and the spark plug for the wires.
I searched Summit and found these right away. http://www.summitracing.com/parts/acc-0576s-4/overview/
03-02-2014, 12:15 PM | #286 |
the straight boots let you control the "curve" some. I was surprised that once set up, the wires stayed where I formed them over time. Mine is w manifolds as opposed to headers but the principal is the same.
Figure out what you want--then figure out what you are willing to give up to get it. |
03-02-2014, 01:23 PM | #287 |
TeX Jake that dash bezel looks awesome. Just gave me an idea for a project during the week...
03-02-2014, 03:03 PM | #288 |
Thanks man! Just a warning, when I went to use the Dupli-color prep-spray before painting it, it removed all the existing factory black from the bezel. That was ok because I was going to re-paint it anyways. I was just not expecting it to remove the factory black paint that fast or that easy. I used 400 grit sandpaper on the edges to remove the old silver paint and of course the prep cleaner removed the black paint for me. I also used the Dupli-Color® Adhesion Promoter before painting it. That Rust-Oleum black hammered paint was great for the bezel because it adds to that textured look that the bezel has on it. And a good prep job is most important for a long lasting paint job. I painted the edges first & let them dry good before masking them off before painting on the black. And the silver metallic Sharpie really was impressive to use to outline the letters, IMO they almost look like the factory did em'.
03-02-2014, 05:31 PM | #289 |
Thanx for the heads up. TeX Jake. I'll keep that in mind.
03-02-2014, 06:00 PM | #290 |
Boom! Took my steering column apart today. Going to rebuild it hopefully it goes back together ok. This was in the bed of the truck when I bought it. It was all rusted and froze up. I'm not sure what year the steering column is, they guy I bought the truck from just threw it in because the truck has a trans am tilt column in it and I didn't like it. Is there any way to tell what year the column is?
03-02-2014, 07:40 PM | #291 |
03-02-2014, 07:58 PM | #292 |
MSD 8653 distributor on my 350 !!
'67 K-20 longbed 4X4, 350, SM-420, Vortec heads, flat top 4-brow pistons, Eaton 4.55's, Qjet, MSD 8365, Comp XE250H, Dynomax duals |
03-02-2014, 08:01 PM | #293 |
Finally on the last leg of painting the 67. Got the bed assembled this week and Painted today!!!
Only the hood is left.
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
03-05-2014, 12:01 AM | #294 |
Wood installed today
Chrome wheel housing - Purchased from Southern Kentucky Classics http://sokyclassics.com/product.php?skcid=1002476
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour Last edited by colgad; 03-08-2014 at 12:56 AM. Reason: Added link to Chrome Wheel Housing |
03-05-2014, 12:12 AM | #295 |
RAT1968 '68 Cab/'71 Parts
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
03-05-2014, 02:03 AM | #296 |
took a 2 tailgates dented smashed up tail gates and made one just for me
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
03-05-2014, 03:56 AM | #297 |
Location: Sassafras. Victoria. The beautiful Mount Dandenong Ranges
Found some repro mirror heads for a 69 Holden. Took the crappy sports mirror off the arms and installed the new bits. Not super flash and eventually want to get the squarish mirrors on the longer 66 style arms. The original mirrors were useless inasmuch as I couldn't get enough angle on the right hand side and when your driving on the wrong side of the truck on the right side of the road (being the left) you wanna know who you're about to cut off!
CLASSIC 1970 C20 WITH A RUMBLIN' V8. IT'S MY MID-LIFE CRISIS ONLY IT AIN'T A LITTLE RED SPORTS CAR OR A HARLEY! IF YOU'RE GUNNA SKATE ON THIN ICE, YOU MAY AS WELL TAP DANCE! |
03-05-2014, 07:24 AM | #298 |
03-05-2014, 07:52 AM | #299 |
Checked a few more items off the list. Picked up some goodies from being powder coated. Also got the ft and rear bumpers done !
1967 C10 SWB Owner - Rustbelt Restorations |
03-05-2014, 09:03 AM | #300 |
[/URL]
Full comp cam valve train installed.. |
