#101 |
Re: '72 chevrolet c20 custom camper build "Craig"
thanks mike,and will do
Dean 1972 Custom Camper c/20 5.3 LS swap in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=610187 in God we Trust ![]() |
#102 |
thanks scott
#103 |
got the cab corner and rocker tacked up. also got the door shutting like new
#104 |
![]() Join Date: Jul 2012
Aw shucks. I was hoping you'd make the cab corner out of the barrel, too
![]() Just finally got around to going through your thread here. Looks great! I really struggled with my LMC cab corners getting them to fit right, and had to do lots of hammer work on the rockers, too. Nothing like a nice closing door. I don't know if you are doing it or not, but you can drill an alignment hole through the hinges into the a-pillar once you get it working perfectly so when you remove it later you can line it back up using the drill bit or equally sized rod. Got that idea from Mr. Duckworth for mine. Can't get over the fact that I'm not looking at pictures of Mustard when going through your thread. Sort of surreal. Keep it up!
Nick Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986 http://67-72chevytrucks.com/vboard/s...d.php?t=545356 Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck. |
#105 |
Nice work Dean! Its a real challenge to get everything lined up right, but you did a nice job.
Funny you mention that Nick, because I was searching my drivers side door pillar the other day for my door alignment holes and I guess I forgot to drill them in. lol
Scott |
#106 |
^^ What he said! ^^
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#107 | |
#108 | |
#109 |
#110 |
i also slammed the truck last evening..............
#111 |
NOT!!!!!... LOL did anyone fall for it?
#112 |
#113 |
#114 |
No but cool pic tho..
#115 |
not too much done today. got the welds ground down on the cab corner
#116 |
awww shucks
#117 |
alright guys, so today i was able to finish up the drivers side. im calling it finished on that side. exept finishing touches(i lost my seam sealer so that will have to wait, also i need to clean up the welds underneath but that will wait too) thrue on some rattle can etching primer to hold it over until i can put the real stuff on
#118 |
i cant get over how clean the frame is! i may only sandblast areas where neccecary
#119 |
also picked up this good old craftsman 220 3hp 30gal compressor for 50 bucks. hoping i can shoot some primer with it
#120 |
its a two stage
#121 |
now the WHOLE other side!!!
#122 |
So the first side was just a warm up.... LOL!
Nice compressor, i need a dual stage, i was stupid and listened to the ass sales guy at sears, he talked me out of it, said look at the Scfm ratings,what are you using it for? you'll be fine, Bla Bla Bla..... Long story short every time i pull a trigger on my die grinder it fires up and runs non stop...
#123 | |
yeah the dual stages are nice...especially the cast iron oil kind like this. they are MUCH quieter and last longer. what size is yours?
#124 |
Mine would be the very noisy discontinued model of this one, I had to pull the cover off for a recall and they sent me a new cover, guess some were over heating, it was exactly the same as the cover i took off except it had none of the compressor info on it so i threw the replacement housing in the trash and kept the old one with the info. I was amazed because i looked at the size and stroke of the piston, it was about 1.25 diameter, stroke of about 1".. cheesy as hell..
http://www.sears.com/craftsman-33-ga...72000P?prdNo=1
#125 |
Still Learning
Very nice progress Dean. The driver side looks really good. Half way down. Nice score on the compressor!
